  • PCW
  • PCW's Avatar
04 Jul 2025 16:16
Replied by PCW on topic [Solved] Mesa 7i96 Spindle PWM
Category: Driver Boards
When LinuxCNC is running and you have the spindle on and set to say 1/2 speed.
what does:
halcmd show all spin*
report?
Also, you can get an idea of PWM operation independent of any add-on cards
with just a voltmeter, as the voltmeter will read the average voltage which will
be proportional to the PWM duty cycle.
  • kworm
  • kworm
04 Jul 2025 16:09
Replied by kworm on topic Servo Driver Plasma Retrofit
Category: Plasmac
I contributed the support for the 7i95t in pncconf. I don't have any 7i97s to try but if there is a similar card already supported in pncconf I could add support for it...I'm just not sure if it supports analog servos though.
I also did some initial work to add qtplasmac support to mesact but there are some fairly major internal assumptions about encoder 0 going to drive 0, etc. and I didn't want to make backwards compatible breaking changes without hearing from JT.
  • SebastianM
  • SebastianM
04 Jul 2025 16:05
  • PCW
  • PCW's Avatar
04 Jul 2025 15:59
Replied by PCW on topic Raspberry Pi 4 with Mesa 7c81
The 7C81 only has the option of all pullups and all pulldowns
on its I/O ports.
Simplest solution would probably be to add a stiff pulldown (say 620 ohms)
on the relay I/O pin. There is a firmware option for fixed parallel port type I/O
but currently its global (not per port), This firmware makes the parallel port
output pins default to outputs instead of inputs at startup or watchdog bite
What firmware are you using?
  • PCW
  • PCW's Avatar
04 Jul 2025 15:22
Replied by PCW on topic Servo Driver Plasma Retrofit
Category: Plasmac
I'm afraid ChatGPT will just be a time-sink here.
I suspect the easiest current path would be to make a pncconf  QTPlasmac/THCAD configuration
for a 7I95T (This requires updating to the very latest LinuxCNC master as 7I95T support was just added
about 1 week ago) This configuration will match as far as encoders, inputs, and outputs go (though will show
more inputs than the 7I97T has, so just don't use any inputs beyond input 15)
When creating the 7I95T configuration, setup step/dir axis.  and encoder feedback. This will create the
basic PID loop structure  required for changing over to the 7I97T PWM/analog axis configuration.
When this is done, you will have a step/dir configuration for a 7I95T and QTPlasmac/THCAD.
Next you will need to change the card name in the ini file to "7i97".
then the created hal file will need to be edited to change the PID feedback input from stepgen
position to encoder position and the PID output from stepgen velocity to PWM value.
There are also enables and some PWM setup needed. I can help with these when you get a basic
hal file setup.
You can use this example of basic 7I97/7I97T PWM hal file setup:
File Name: basic7i97_...7-04.zip
File Size:4 KB
  • Aciera
  • Aciera's Avatar
04 Jul 2025 15:10 - 04 Jul 2025 15:23
Replied by Aciera on topic Gmoccapy 3.5.1
Gmoccapy 3.5.1
Category: Gmoccapy
I start the program with an external button.
Well, yes but what hal pin do you use to start the program?
I presume 'halui.program.run'
  • HansU
  • HansU's Avatar
04 Jul 2025 14:59
Replied by HansU on topic Gmoccapy 3.5.1
Gmoccapy 3.5.1
Category: Gmoccapy
Suggestion / request:
Overrides
When starting a program running (cycle start): user is prompted that an override (rapid, feed, or spindle) and asked whether they want to continue with override, or want to reset to 100%
I could imagine make an optional warn dialog with a settable limit. For all overrides? Feed, rapid and spindle?
  • whyme
  • whyme
04 Jul 2025 14:57
Replied by whyme on topic Raspberry Pi 4 with Mesa 7c81
Maybe a stupid question, but how do you use the relay on those cheap MACH3 BOBs with the 7c81?
For the inputs to work I need to enable the pullups on the 7C81.
But enabling the pullups makes the relay close as soon as the BOB is powered.
Ideally I would want the relay to be open until linuxcnc is started and I tell linuxcnc to close the relay.
But the relay closing by default due to the pullups makes it unusable, or did I miss something?
  • kworm
  • kworm
04 Jul 2025 14:39
QTplasmac material database enhancement
Category: Plasmac
I cut a lot of thicker material that needs a ramp pierce.  I am thinking of adding ramp pierce parameters to the material database along with adding ramp pierce to the conversational area of QTplasmac.   My purpose for this would be to keep all the cut info in one place and to be able to use the conversational on thicker parts vs having to CAM simple things.   Just thought I would see if there was interest in this from others and/or other thoughts on it.
  • PCW
  • PCW's Avatar
04 Jul 2025 14:27
MESA 7i76U inputs changing state without changes to config
Category: Basic Configuration
Normally you would use a NC switch for Estop and the you would use the true (no -not)
input to sense it. This is so that when Estop is not activated (switch = closed circuit),
iocontrol.0.emc-enable-in will be true so no Estop. Then when Estop button is activated
(switch= open circuit), iocontrol.0.emc-enable-in goes false, signaling an estop event.
Did you verify that estop-ext changes state when you change the Estop button from on to off?
  • besriworld
  • besriworld
04 Jul 2025 14:23
Replied by besriworld on topic Gmoccapy 3.5.1
Gmoccapy 3.5.1
Category: Gmoccapy
This time, the spindle didn’t stop. However, when exiting the editor, the graphical interface shows that the program is not running
youtube.com/shorts/axVyF3tfrcw?si=d6pKXhjEwYUU1QWp
youtube.com/shorts/ay-Nz62fcPs?si=QHA_4l6xV2o7P6Ro
  • kn612
  • kn612
04 Jul 2025 14:15
Replied by kn612 on topic Servo Driver Plasma Retrofit
Category: Plasmac
Thank you, the wiring is making much more sense and less challenging now.
Im using linuxcnc_2.9.4-amd64.hybrid.iso that I downloaded here.  It installed qtplasmac 2.9.  Is it recommended to install 2.10?
What is the easiest way to configure a 7i97t and a couple thcad2 for plasma?  I dont see 7i97t as an option in pncconf and in mesact there isnt an option for qtplasmac.
I asked chatgpt to create a quick ini for qtplasmac and a 7i97t and it came up with this pretty quick:
File Name: mesa_7_i_9...smac.txt
File Size:1 KB
  • dunnitagain
  • dunnitagain
04 Jul 2025 13:37
Recommended New Install of LinuxCNC coming from EMC2 and Ubuntu 10.4
Category: Installing LinuxCNC
Created the Boot USB STick . both machines recognize the stick on the desk top. But dont recognize it in Bios settings . All the bios settings are set to boot from the stick , but it doesnt show up in the boot drive order.
  • Tim Bee
  • Tim Bee
04 Jul 2025 13:37
Dear meister:
Thanks for your repay and fix it,thanks again.
Tim
  • besriworld
  • besriworld
04 Jul 2025 13:25
Gmoccapy 3.5.1
Category: Gmoccapy
Displaying 511 - 525 out of 25342 results.
Time to create page: 0.297 seconds
