  • unknown
  • unknown
27 Apr 2025 13:23 - 27 Apr 2025 13:29
Replied by unknown on topic comparing to Grbl, or FluidNC
Category: Milling Machines
Verilog & VHDL are text files ;)
And there were also (still there) PAL & GAL text files again.
Tho I might be a little special in the head, I didn't use a schematics when wiring the control box for my mill...I can kind visualise things in my......not to the level of Dr Hawking,most of physics confuses me.Quantum Mechanics just requires not trying to relate it reality as we experience in day to day life. Maybe if I did more than 3 and a bit years of high school and was less interested in playing Rugby.
27 Apr 2025 13:21
Replied by tommylight on topic Using POSIX realtime
Category: EtherCAT
That is correct.
27 Apr 2025 13:20
Replied by tommylight on topic converting a tos/intos fngj 40
HAL: ERROR: function 'hm2_7c81.1.read' not found
./intos.hal:16: addf failed
should be
hm2_7c81.0.read
  • jackdavies
  • jackdavies's Avatar
27 Apr 2025 13:18 - 27 Apr 2025 13:19
Magnetic scales on new gantry mill was created by jackdavies
Hi all,
I am designing a new machine and would like to use Ditron magnetic scales on X & Y.
  • The Y axis has dual motors, should I use a scale on each side or just one?
  • Any recommendations of mesa boards to use here? 7i95T + 7i84U or 7i96 + 7i85
  • Whats the process for setting this up in LCNC?
  • I don’t believe these scales are differential signal, should I look for that?
    Many thanks for your help!
  • pgf
  • pgf
27 Apr 2025 13:18
Replied by pgf on topic comparing to Grbl, or FluidNC
I hadn't gotten to the "asking for help" part yet. I only started last night. ;-) And much of that was trying to work around bugs in pncconf. Yes, I'll report them.
It's definitely a programming language -- you just find it easy, since apparently you have a background in electronics. I do too. But there's a reason circuits are designed graphically, and not in text files -- they're easier to understand that way.
  • unknown
  • unknown
27 Apr 2025 13:13
Played around with grbl a while ago, my little 3 axis BangGood thingy uses grbl, but even that I use that for a test bed when working on stuff, mainly getting hostmot2 firmware running on various Spartan6 dev boards......I can't even explain the time I've spent to getting a working Ethernet setup going. Got a bit to learn about designing PCBs.
The thing is I've worked as either a builder's labouer or civil labourer (road works) the most complicated thing we have to use is a spirit level and string line when grade checking.
  • unknown
  • unknown
27 Apr 2025 13:02 - 27 Apr 2025 13:08
Another good perspective. You're clearly a LinuxCNC guru. How much time have you spent using Grbl or FluidNC?
You mention no need for coding skills: I'd say that any time you open up a HAL file, you're coding, designing arbitrarily complex digital "circuits" in a text file. An incredibly powerful feature, but where's the UI? It's a graphical concept, one that should be supported via a schematic capture tool. But there's no easy way to even display a HAL file, let alone construct it.
I'm not a guru, I've just made enough mistakes and been frustrated enough and most of the time it's a stupid typo or not interpreting the docs correctly, my issue, not anyone else's. Even with the tools we have for creating the amd64 & RPi4 & 5 images I still mess up when creating images (RPi4 & 5 are the ones I work, it takes a couple of iterations), and it's not a 5 minute job waiting for the tools to do their job.
Pen or pencil if you can't visualise in your head, or you could use a CAD package, although they're not really that complex. There was an attempt to do something with Eagle a few years back. I'd disagree, it's just a bit of configuration. Look at logically.....many of us when we first made our entry into electronics there was no readily available software for designing circuits, like the constipated mathematician we "worked it out with a pencil". I still use pencils, pens and notebooks, sometimes it's just quicker, every so often I have to wipe down my desk to make room for new notes.
"A little respect", how about taking a bit of constructive criticism, to tell the truth the comment wasn't particular to you, it was a general thing. Then again I can't be held responsible for how you take things. And if you're having trouble it's easy enough to ask for help.
  • Roger S
  • Roger S
27 Apr 2025 13:00
Using POSIX realtime was created by Roger S
Category: EtherCAT
Hello everyone,
i have completed the Ethercat installation according to rodw
forum.linuxcnc.org/ethercat/45336-etherc...-how-to-step-by-step
The installation went smoothly and the final test was positive:Component Pins:
Owner   Type  Dir         Value  Name
     4  u32   OUT    0x00000001  lcec.conf.master-count
     4  u32   OUT    0x00000004  lcec.conf.slave-count
The following version of Linuxcnc is installed:
6.1.0-30-rt-amd64 #1 SMP PREEMPT_RT Debian 6.1.124-1 (2025-01-12) x86_64 GNU/Linux
When I check if /sys/kernel/realtime exists, I get /sys/kernel/realtime
When I check the module cia 402 (halcmd loadrt cia402 count=1), I get Using POSIX realtime
Am I wrong as a layman if I assume that this is not real real time and that there may be problems with some modules?
  • FPM
  • FPM
27 Apr 2025 13:00 - 27 Apr 2025 13:01
Replied by FPM on topic converting a tos/intos fngj 40
I have connected everything and flashed the bitfile from PCW. But it looks i have not configured the second card in the hal properly.
Attached the output of mesaflash readhmi, the hal and the crash report from lcnc
any ideas?
thanks in advance.
File Name: readhmi.txt
File Size:7 KB
File Name: intos_2025-04-27.hal
File Size:10 KB
File Name: linuxcnc.txt
File Size:9 KB
  • Surmetall
  • Surmetall's Avatar
27 Apr 2025 12:25
WEMAS MT 32 CNC Lathe -> LinuxCNC - Mesa or EtherCAT?
Category: Turning
I have a lot of mechanical work on the machine. Cutting and welding on the housing to get it smaller. maybe i will post pictures later if you are interested.
The plan for the drives at the moment is to use the SIEMENS Drivers if i can manage them to run... i think at least the Step Dir Config via SMC30 should be possible. But i would love to use ethterCAT like in this example.
support.industry.siemens.com/cs/document...p-pn-?dti=0&lc=en-WW
I have some experience with Mesa. After learning LCNC and help of great people like Talla83 and many more, my Deckel FP3NC runs really nice with it.
But i am a complete NOOB with EtherCAT. And to be honest, i am a little bit afraid of it. :D
So i hesitate to buy a used few hundred euro PCB for something i have no glue of :D
  • pgf
  • pgf
27 Apr 2025 12:04
"Not a Linuxcnc issue, but a user issue."
A little respect, please. There were fundamental changes, and a small attempt at automating the upgrade. I did read the docs, and I did make the manual changes I thought were required, and it did work... most of the time, and then it would stop working. I think maybe I'm trying to jog the jog the joints instead of the axes. Or else maybe that's fine, and the problem lies elsewhere. But either way, I have a debugging problem on my hands, and after a couple of hours, I'm still not done.
  • pgf
  • pgf
27 Apr 2025 11:58
  • unknown
  • unknown
27 Apr 2025 11:37
Thank you! Your's was exactly the voice of experience I was hoping to hear from.
I love/hate LinuxCNC. On the one hand, I spent hours last night trying to figure out how to get my USB gamepad "wand", which worked fine under 2.7.4, to work reliably under 2.9. On the other hand, it's likely that Grbl/FluidNC wouldn't support the gamepad at all.
I've wondered, too, about whether the Grbl comm protocol could be implemented on the front of LinuxCNC. I know the folks driving industrial mills would be horrified, but it might be a good solution in some cases.
Again, thanks for the feedback.
There were major changes to jogging from 2.7.x to 2.8, so any pendant would need work, that's why one should read the docs to see what has changed before upgrading. Once a again, not a Linuxcnc issue as such but a user issue.
  • unknown
  • unknown
27 Apr 2025 11:26
Linuxcnc & the Raspberry Pi (4 & 5) Official Images Only!!!
Category: Installing LinuxCNC
If you're going to use a CM5 & carrier board you'd be crazy not to use an NVMe drive. It's fast, like really fast. I use one with mine Rpi5.
  • Tom369
  • Tom369
27 Apr 2025 11:23
Allgemeine Frage und Problem:hm2/hm2_7i96s_0: error finishing read! iter=1256216
Hallo,
Kurz zu mir, habe mich heute hier bei euch regestriert weil ich nicht weiter komme und glaube noch öfter hilfe brauch.
Bin der Tom 35Jahre ich habe minimal Linux vorerfahrung, hab ein Prusa MK4 und eine Bernado 550 Dreh Fräs kombi mit nachgerüsteten DRO
Habe die Zahnräder zur Zug-leitspindel hin ausgebaut und will die jetzt mit nen nema24 - cl57t - mesa 7i96s - ace minicomputer - joystick oder controller/win11rdp steuern.
Hab alles fertig angeschlossen! Netzwerk zu Mesa eingerichtet jetzt kann ich die karte pingen mit ca. 170-200ms
Gehe jetzt in den pncconf wizard und mach nur das nötigste xz lathe der Motor test der X-achse funktioniert Motor dreht sich!
Speicher alles + desktop verknüpfung!
Wenn ich jetzt die Verknüpfung startet kann ich die Mesa karte nicht mehr pingen...
Karte leuchtet 4xGrün 1xGelb(der obere)
Jetzt kann ich den Motor 5min lang bewegen...
So dann nach ca. 5min leuchtet jetzt der unter dem gelben auf der karte Rot und ich bekomme im program unten rechts die fehlermeldung:
Jetzt kann ich auch den Motor net mehr bewegen.
Hab natürlich schonmal gegoogelt anderer Kernel macht mir schon zu viel probleme bei der Installation.
Gibt ja hier bei euch nen thread mit 34 seiten, wo ich echt nich mehr durch blicke...
Muss doch nen Fix geben weil es ja anscheinend erstmal geht^^
Möchte der effiezens wegen noch ne 2 Frage mit zu geben
Ich lass den originalen Schlosskasten mit zug/Leitspindel drin bedeutet das ich den schrittmotor einmal im dauerbetrieb
eine richtung fahren lasse(wenn ich nur den automatischen vorschub brauche) und einmal ganz normal mit eingelegter
schlossschraube zum gewinde schneiden...
Ist das möglich? Weil die position nach manueller arbeit ja sozusagen nicht mehr stimmt...
Kann ich LinuxCNC die Position vom DRO geben bzw. das DRO als endschalter benutzen?
Vielen Dank
Gruß Tom
Displaying 6121 - 6135 out of 24071 results.
Time to create page: 0.546 seconds
