  • notJamesLee
  • notJamesLee
23 Apr 2025 16:38
Tangential Cutting Path - Post Processor/ Filter File?
Hi Friends,
I've spent the last few months modifying a chinese cnc with a mesa 7i96s and a custom cutting head I've made with the end goal making it a tangential cutter  I've long dreaded this part because i simply do not know where to start. I am working on tuning the error in the cutting motor but this is next on the list.  I am going to lay out what i would like the machine to do, and hopefully you guys can point me in the right direction.
Attached is a cad screenshot with a visual of the cutting head. There are two pneumatic cylinders that can deploy the cutting head down or up with a solenoid valve controlling them both. I wanted to leverage some of the 7i96s auxiliary outputs or the torch up/down to control this valve.
I am not sure what cad program that will be outputting these, probably fusion or solidworks in the long run so i am leaning towards a filter file or i guess this is technically a post processor, as mentioned in this post, but i didn't see really any progress so here i am.
forum.linuxcnc.org/38-general-linuxcnc-q...n-of-travel-possible
My fundamental issue is i don't understand what node is doing what. I haven't ever uploaded a file to LCNC but i imagine its Gcode.
So my simple brain wants to understand;
- Cad program - > outputs generic 2D gcode
- **NEW FILTER FILE** -> magic happens here?
-LCNC - > doesn't know the difference, its just following orders.
Requirements (will probably grow):
-be able to set "cut depth' (the z position with 'torch down')
-set cutting motor to only find angle in one direction (not sure if i can or should do this on LCNC and not the filter file) because belts aren't very good pushers..
-I'd like all travel movements and find next angle to happen with the torch up, and it only go torch down only when the next angle is good and its in position
-BUT i would like arcs and angle to be smooth, i need to differentiate between lines with arcs an endpoints.
also sorry i am rambling, can you tell i've thought about this.
  • Hakan
  • Hakan
23 Apr 2025 16:11
Replied by Hakan on topic EtherCAT Servo cannot set to OP state
Category: EtherCAT
What did I do :) ?
  • Grotius
  • Grotius's Avatar
23 Apr 2025 15:30
Replied by Grotius on topic LinuxCNC S-Curve Accelerations
Hi Rod,
The Cia-402 i have seen the source code. It does not much.
It sends and recieves position, velocity, torque  trough a can protocol?
  • Grotius
  • Grotius's Avatar
23 Apr 2025 15:25
Hi Tia,
when i change to tpmode=scurve
It is : tpmod_scurve
And check if you use values for the trajectory :  vel + acc.
 [code]# Trajectory planner section --------------------------------------------------
[TRAJ]
TPMOD = tpmod_scurve
COORDINATES = X Y Z
LINEAR_UNITS = mm
ANGULAR_UNITS = degree
DEFAULT_LINEAR_VELOCITY = 208.33
MAX_LINEAR_VELOCITY = 208.33
DEFAULT_LINEAR_ACCELERATION = 350
MAX_LINEAR_ACCELERATION = 350
POSITION_FILE = position_mm.txt
[/code]
I just isnstalled debian 13 on the desktop pc and installed the same software, but the ethercat-master from the codeberg repo.
It also runs ok. So that's a good sign.
  • besriworld
  • besriworld
23 Apr 2025 15:03 - 23 Apr 2025 17:11
Replied by besriworld on topic OLD Lathe conversion to a CNC
Category: Turning
Today I ran some more tests. I can now reproduce the issue described in the other thread with 100% consistency. I noticed that when the Z-axis is moving, G96  doesn't seem to be working. I recorded a video showing that the spindle speed doesn't change at all during the movement.
PS. I think there might be something wrong with the HAL configuration. I just noticed that when starting LinuxCNC, I need to go into the calibration settings and re-save the PID values for the spindle (I enter test). If I don’t do that, the PID control is soft– under higher spindle load, it triggers a hold  .Also, if I leave LinuxCNC running idle (without running a program) for about an hour, and then start program execution again, the axis movement speed during a G1 command is once again higher than what was set.
  • fletch
  • fletch's Avatar
23 Apr 2025 14:58
Linuxcnc & the Raspberry Pi (4 & 5) Official Images Only!!!
Category: Installing LinuxCNC
That would be lovely - the CM5 has one but then you need a carrier board and I don't know if the LinuxCNC image would run on the CM5/eMMC? With the right carrier board would be perfect though...
  • unknown
  • unknown
23 Apr 2025 14:54
Dunn why RPi doesn't add a connector for an external antenna.
  • fletch
  • fletch's Avatar
23 Apr 2025 14:35 - 23 Apr 2025 14:37
Just for completeness and to save anyone having to mess around with compiling kernel modules, here is what looks like a fairly comprehensive (at least until 6.13) list of in-kernel USB WiFi devices: github.com/morrownr/USB-WiFi/blob/main/h...in-kernel_drivers.md
Discovered it a little late but I think only one has an RP-SMA connection.
  • tiagounderground
  • tiagounderground
23 Apr 2025 14:00
Replied by tiagounderground on topic LinuxCNC S-Curve Accelerations
tried here, it works with the original trajetory planer on the rip install, when i change to tpmode=scurve i need to desable homing on the gantry axis and i can do jog movements but when running gcode the machine seens to be stoped but it is runing with an extremaly low aceleration, near 1 minut to move 1mm
  • PCW
  • PCW's Avatar
23 Apr 2025 13:49
Mesa CT 2.1.7 and Mesa 7I97T setup running Gmoccapy
Category: Configuration Tools
net estop-loopback => hm2_7i97.0.ssr.00.out-00
should probably be:
net estop-loopout => hm2_7i97.0.ssr.00.out-00
  • emresensoy
  • emresensoy
23 Apr 2025 12:12
Replied by emresensoy on topic EtherCAT Servo cannot set to OP state
Category: EtherCAT
- Solved -
There is a startup sequence in control word,
set bit number 1 2, 0 to 1
then if you set bit 3, drive goes to enabled state,
Thanks a lot
  • rodw
  • rodw's Avatar
23 Apr 2025 11:38
Replied by rodw on topic LinuxCNC S-Curve Accelerations
Great! Don't worry about the cia402.comp as it needs work to work with the homecomp features. In fact it needs rewriting  from scratch I think...
  • emresensoy
  • emresensoy
23 Apr 2025 11:10
Category: EtherCAT
Thank you mr Hakan,
I added them,
  • fletch
  • fletch's Avatar
23 Apr 2025 10:36
As the image is a custom one, only the kernel is built from RPi Sources.
This pretty clear, I would have thought.
To one well versed in building distributions, yes, but not necessarily to one who has only used distributions! Not until now, anyway ;-)
Where as you were attempting to install headers from the Debian repo
I was but at that point, didn't realise the significance of the kernel being sourced from a different place to the base distribution.
The kernel should load the drivers without any user intervention.
It does now load on boot.
Thank you.
  • Grotius
  • Grotius's Avatar
23 Apr 2025 10:26
Hi Tia,
It seems the .img won't work ok.
Today i tried the scurve + ethercat on a desktop pc and it runned ok.
It's using a EK1100 + 3x EL2124 on a stepgen component.
Jog speed was around 15000 mm/min wich i find not optimal, but ok for ethercat.
The config:
1x linuxcnc iso from : linuxcnc.org/downloads/
1x ethercat installation : ethercat install
1x linuxcnc + scurve, using makefile build system : codeberg.org/skynet/linuxcnc
1x linuxcnc-ethercat, codeberg.org/skynet/linuxcnc-ethercat.git
Running the config : config link
Now i can not try the cia-402 component myself as i dont have the hardware for it.
But maybe you are able to try this again.
Displaying 6301 - 6315 out of 24060 results.
Time to create page: 0.364 seconds
