  • Aciera
  • Aciera's Avatar
03 Dec 2025 02:30
Ursviken Pullmax Optima 130 press brake retrofit with 4 axis backgage
Category: Show Your Stuff
Have a look at the 'extra joints' feature. You might have to configure at least one regular joint/axis for motmod to be happy but that still leaves 15 to be used as 'extra joints'. Homing extra joints is handled just like regular joints but are controlled through hal pins after homing. For more info see links in this post:
forum.linuxcnc.org/24-hal-components/577...h-push-button#338305
  • unknown
  • unknown
03 Dec 2025 02:17
Replied by unknown on topic Linuxcnc Image for Raspberry Pi 3
this link has only pi 4 images, not any oi 3. what need doing can use pi 3 and linuxcnc, what is patch and how need doing, or what need doing, not understand , ready to install pi 3 image only need how need patch or what this mean and how change kernel if need no understand anything linux and code, secret engineer language all.
This is getting silly, 3 times you post, I did try to help you with your first post. You didn't say you were using RPi3B to begin with. I did politely ask what your native language was, so we could find someone to help you, as it quite clear English is not your first language.
First of all I think you need to find some Linux info in your own language, this forum is not here how to teach people how to use Linux takes way too much time. Anything Linuxcnc we can help.
  • masawee
  • masawee
03 Dec 2025 01:54
Installing LinuxCNC 2.8.4 on Raspbian 10 (Buster) tested on Raspberry Pi 3B+, Pi
Category: Installing LinuxCNC
what this all code have ??? not understand anything. have linuxcnc image what can add to SD card and run rpi3 ready to use, i not understand this all secret code anything, what need doing or how doing and were doing.
need only image who working and can run rpi 3 board and connect stepper drivers DM556 to rpi and run nema 23 motors. whit linuxcnc.
  • masawee
  • masawee
03 Dec 2025 01:35
Replied by masawee on topic Linuxcnc Image for Raspberry Pi 3
  • masawee
  • masawee
03 Dec 2025 01:29
not understand what is compile and how need do ? or have ready to use image to rpi3.
i looking make rpi3 linuxcnc small cnc my son.
or how kernel need use or how can change kernel or what need doing. too hard all linux system but have only what can use good whit linuxcnc and rpi3 board. not want buy old computer and paraller port use this.
  • endian
  • endian's Avatar
02 Dec 2025 22:03
Replied by endian on topic Reduce read-all timing 7i76e + 7i77
If gentelmen have any other tips for reducing latency .. share it please
I did changes for my machine and it runs for few days at 3khz without problem...
Reading the datas take less then 250us with timeout 100000ns and 250us is now limit... + Other stuff in the thread and we are under the 300us
Motion is smoother by the sound and scope profile and compensation of position in the velocity mode is faster==smoother ... It is real difference now
  • EdWorks
  • EdWorks's Avatar
02 Dec 2025 19:05
  • EdWorks
  • EdWorks's Avatar
02 Dec 2025 18:59 - 02 Dec 2025 19:02
  • NWE
  • NWE's Avatar
02 Dec 2025 17:48
I'm trying to figure out my options for homing everything. Originally my plan was to launch it with:
cd /home/titus/linuxcnc/configs/pullmax
halrun -I -f config.hal
within that hal I load everything else including:
loadusr gladevcp -Wn pullmax -H ui.hal pullmax.ui
also hostmot2, mesa, ethercat, etc.
This leaves me without motmod (motion), homing, etc. It is just a simple Glade + hal app.
I would like to use the full linuxcnc system instead of writing my homing and slave axis (ram control) from scratch. Maybe avoid reinventing the wheel.
I am currently studying how to load everything with like:
linuxcnc pullmax.ini
Progress is coming in small increments. Currently struggling to get past this:
USRMOT: ERROR: command timeout
emcMotionInit: emcTrajInit failed
Waiting for component 'inihal' to become ready............USRMOT: ERROR: command timeout
full error attached
the ui comes up and works (I only got the position readouts hooked up at this point and encoder scales all at 1.0, servos all disabled yet, bumped each axis with my hands and got counts.
I'll keep poking at it. I'm learning as I go.
  • elovalvo
  • elovalvo
02 Dec 2025 17:11
Replied by elovalvo on topic Raspberry with LinuxCNC direct interface
I wonder, is there a Raspberry HAT that can direct interface with a stepper driver ?
Jonh.
www.instructables.com/LinuxCNC-on-Raspbe...i-With-GPIO-Control/
  • Dudelbert
  • Dudelbert
02 Dec 2025 16:27
Considering a Full Rewire on a Working Schaublin 125 CNC
Category: Turning
You are absolutely right about most of that, and it’s certainly many months in the future.
But one nitpick: what I want is not a perfectly synced machine/CAM system. It’s more a system where we don’t have to care about the sync. But let’s leave that aside for now. I can revisit it in due time and see whether it works the way I think it will or not.
Martin
  • RotarySMP
  • RotarySMP's Avatar
02 Dec 2025 16:04
Category: Turning
The sort of thing you are imagining is a bit of a fantasy for our kind of lathe and use case. A perfectly synced tool table in CAM and LinuxCNC is unlikely to work, as you will never have enough tool holders to never have to edit them. Think drills. I can say from experience that the next size drill you need is never the one loaded.
Maybe on those big machining centers with chain type 60 tool magazines, but it is not going to happen on our set ups.
In practice, there are two scenarios.
- You are making one off home shop/ tool shop parts. You have enough tool holders for  the most common tools, and you have assigned them pockets where they are most often used. For these jobs, you will often not program full multi tool programs, but use a mix of simple programs for more complex bits using a single tool and Lathe macros for simpler paths where you also manually swap in tools.
- You tool up the machine for a production run. In this case you will go through and set up each tool, assign a pocket and if needed set manual break points for manual tool changes with our lathe. Tool set up is a fact of life in CNC machining. LinuxCNC can't know which tool holder you are planning to swap in manually.
There are many many more things to work through getting your lathe running under LinuxCNC before you even need to consider this issue.
02 Dec 2025 16:02
Replied by tommylight on topic Test to check if I can submit a post
It should work now.
  • LCR
  • LCR
02 Dec 2025 15:53
Problems with Lichuan Ethercat servo drive
Category: EtherCAT
I don't seem to have that handy. I will be back to the machine in a week or 2. I will make a backup and upload my configuration. What issues are you having?
Displaying 10531 - 10545 out of 11228 results.
Time to create page: 0.248 seconds
