  • Z3n
  • Z3n
26 Nov 2025 13:43
Replied by Z3n on topic Converting a Brother TC215 to LinuxCNC
Category: Milling Machines
Yeah, I was amused to discover the same!
Thanks for the link - I was hoping he'd have some wiring guidance, but he never ended up getting the mill.
What I really need to proceed is to be confident that I'm not going to blow something up by wiring the Mesa board to the servo in the described fashion - it appears from reading the manual that it's fine to wire it as "Analog Circuit D", on Page 18 to the Mesa driver pins, and I'm assuming that I can then also wire up the JP5 Encoder output to the Mesa Encoder pins as a "Line Drive / Reciever" as on page 20. Once that's done, it feels like I could set up a basic LinuxCNC HAL / INI / PnCconf setup to power and move the servos.
Manual link here for ease of reference:
www.dmm-tech.com/_files/ugd/ac1ef8_924ca...fce9d.pdf?index=true
I can also call my friend who has his setup and get him to walk me through his setup and emulate that, but I like to know how the system actually works vs just emulating other people's configurations :)
  • Sandro
  • Sandro
26 Nov 2025 13:08
Replied by Sandro on topic MonoKrom - QtPyVCP GUI for PlasmaC and Mill
Category: QtPyVCP
So the plasma_gcode_preprocessor which comes with Monokrom works for you? I still had no success.
  • jmp97
  • jmp97
26 Nov 2025 12:56 - 26 Nov 2025 12:58
Mesa 7I96s - 5 AXIS was created by jmp97
Mesa 7I96s - 5 AXIS
Category: Installing LinuxCNC
Hi guys!
 I managed to stop my LinuxCNC from giving errors by isolating a core of my CPU. Since then, the milling operations have not stopped and everything is going well.Now I need to add a 2-axis rotary table.
I copied my working configuration from my Mesa 7i96s, and added two A/B axes, both in the INI and in the HAL.I thought it would be as simple as that, but I'm getting an error.I'm not sure if the axes should be called A/B in the configuration.I'm attaching the files to see if you can help me.
Thank you.
  • Masiwood123
  • Masiwood123's Avatar
26 Nov 2025 12:35 - 26 Nov 2025 12:37
Replied by Masiwood123 on topic Physical buttons to 7i96s+7i77
Category: HAL
2.9.0. I didn't have a 7i92 with me, so I used a 7i96s as the main card, which turned out to be better because I'm planning two additional axes later that will use steppers...now about mpg, maybe and I have an example to try...but I didn't have any experience with connecting potentiometers for feed and spindle override, and any Hal example would be valuable to me.
  • Dudelbert
  • Dudelbert
26 Nov 2025 11:20
Considering a Full Rewire on a Working Schaublin 125 CNC
Category: Turning
Thanks for the suggestion. Do you mean sticking with the Mach3 system, or keeping the existing wiring even if I switch to LinuxCNC? One thing I’m worried about is not really understanding what is what unless I take everything out and redo it. “Just” cleaning it up and making it look more organized would definitely be possible, but wouldn’t I just end up with a nicer-looking system that I still don’t understand any better than the current one?
  • Dudelbert
  • Dudelbert
26 Nov 2025 09:32
Category: Turning
Hi,I recently got a Schaublin 125 CNC and I have a dilemma that I wanted to get some opinions on.
The machine was previously retrofitted with Mach3, and it basically works, with a few small caveats. But the wiring is a mess, and I don’t have any schematics or documentation at all.
I previously retrofitted a Hermle 1200UWF to LinuxCNC and really liked the experience. From my first contact with Mach3, I can’t say the same about it.Right now I’m thinking it would be very easy for me to just clean it up a bit, fix a few small issues, and use it as-is. But with wiring like this, it feels like I’m just waiting for the first small problem, and then I’ll be standing there rewiring everything because I can’t find anything in that undocumented mess.
I don’t want to speak badly about the previous owner — if someone other than me had to work on my mill, they wouldn’t fare much better either. But still, this has me thinking about rewiring the whole machine from the start so I don’t run into the same headaches later on.I’m a hobbyist, so it’s not financially important for me to get the machine running as quickly as possible. And if I’m rewiring it anyway, I would probably switch it over to LinuxCNC as well.
So my question to all of you is: am I insane, or is this actually reasonable? I have a working machine, and I’m considering taking it completely apart and turning it into a months-long, or even year-long, project.
Another reason I would prefer LinuxCNC is this forum. I haven’t posted much here in the past, but all of you were essential in getting my mill up and running. The fact that I was able to solve almost all of my problems just by reading here says a lot in my book. Maybe that’s true for Mach3 as well, but I somewhat doubt it.It may be that asking here is like asking a lawyer whether you need a lawyer, but still…
I have a number of pictures of the machine and the wiring, and a video I made, so you can get a better idea of what I’m working with.
Any suggestions on how you would handle this would be very welcome.
  • Neiji_msk
  • Neiji_msk
26 Nov 2025 09:01
Replied by Neiji_msk on topic Servotronix Ethercat problem
Category: EtherCAT
My Linux runs fine. It's just that the driver doesn't switch to enable mode, but the other three axes work. I think the problem might be with vid and pid.
  • Hakan
  • Hakan
26 Nov 2025 07:49
Replied by Hakan on topic Servotronix Ethercat problem
Category: EtherCAT
Can you please show the last say 30 lines from the syslog after you tried to start linuxcnc.
The ethercat master writes errors there
Output of "sudo dmesg | tail -30"
  • Neiji_msk
  • Neiji_msk
26 Nov 2025 07:23
Servotronix Ethercat problem was created by Neiji_msk
Category: EtherCAT
Hello everyone, I have a small problem. I have three VEICHI drives connected via Ethercat in my system. My task was to connect a fourth driver to them, but from a different manufacturer (Servotronix CDHD2S). I purchased this driver, and everything works fine with the PC. Then I connected the driver to the common system with the other drivers via Ethercat, configured it, and added vid and pid. As a result, Linux CNC starts, but the driver hangs in an error and does not switch from PREOP to OP. Please advise what the problem might be. I am attaching my configurations and the xml from the driver manufacturer.
File Name: swm-fm45a.hal
File Size:16 KB
File Name: ethercat-c...1-26.xml
File Size:5 KB
File Name: swm-fm45a.ini
File Size:4 KB
File Name: Servotroni...0605.xml
File Size:460 KB
  • Masiwood123
26 Nov 2025 05:06 - 26 Nov 2025 05:11
Physical buttons to 7i96s+7i77 was created by Masiwood123
Category: HAL
..in connection with the machine retrofit #338210
, I would like to include the hardware buttons in the configuration, also calculating the mpg. I have a lot of free inputs (all on 7i96s) and about twenty on 7i77 where I left the first three free as I understood that they are analog because of the potentiometer) now I need a suggestion, since dont have schematic for the old controller and not for the buttons, I think they are all on 24vdc including mpg. the outputs that I connected to 7i77 lit the bulbs of these buttons at 24v. should I try the configuration in terms of the mpg pendant for selector increments and mpg, and for spindle and feed override how should I connect? Thanks
  • Z3n
  • Z3n
26 Nov 2025 04:45 - 26 Nov 2025 04:49
Hello everyone,
I’ve been lucky enough to be the recipient of a Brother TC215 midway through a LinuxCNC conversion. I’ve always wanted to try my hand at CNC work, as I’ve done a little bit of manual milling and a lot of fabrication work over the years, and I’m always curious to learn and build new things. It’s been a pretty steep learning curve, as I’m new to basically all of this, but I’ve leaned a lot via search and previous forum threads and I think I’m at the point where starting a thread is worthwhile.
On the hardware side:
  • Mill is a Brother TC215
  • Dyn4 AC Servo Drivers/motors
  • Mesa 7i92 / 7i76 / 7i77D control boards
  • HP Elite 8300 USDT running LinuxCNC / ProbeBasic
I'm currently planning on running some of the older Brother boards for things like coolant, safety switches, limit switches, etc, just to keep things simple for now, as I already have breakout boards for all the connectors. I can clean everything up later if it gets that far.  My friend validated that the mill’s mechanical functions are in good shape and made it about halfway through the wiring - but my current priority is to wire everything up such that I can get XYZ servo movement first, and then I will add additional functionality. So I’ll try and keep this thread focused on the help I need to get things moving under their own power.
What I’ve got so far is: The hardware is mounted in the mill, I roughly understand how things are laid out. I feel like i have a broad sense of how this should go together, but the details are oftentimes a little more opaque than I’d like.  What I’ll be doing when I have a minute :
  1. Test all my servo controllers and drives (easy to do, just need to get my windows laptop out to the mill)
  2. Power up the Mesa board (pretty easy, just need to spend some time looking at all the wiring and make sure I don’t fry anything)
The thing that’s blocking me right now is that I don’t really know enough to confirm that I’m wiring the servo drivers in a reasonable way. My understanding is: I should be able to wire my X / Y / Z servos in the following way, to do analog +10v control as a simple starting point. I need to set it up so I’m wiring:
  • 7i77D +24v from field power to Dyn4 JP4-15 (Servo Enable)
  • 7i77D TB5 (Analog Drive Interface) To Dyn4 JP4-13 (Analog +10v) & JP4-25 (Analog GND)
  • 7i77D TB3 (Encoder 0-2) to Dyn4 JP5-2 through 8 (Encoder outputs)
My plan was to disconnect all the motors from the mill and test them on the bench, but running through LinuxCNC, so I can confirm my understanding on how LinuxCNC operates. Once the motors are confirmed to work on the bench, then I would start on wiring up the Estop, limit switches, and other things I would need to get the mill safely moving, and then follow that with wiring in the spindle.
Here's a picture of how things it sits:
Any and all feedback appreciated, as well as suggestions about if I should approach this another way. I've learned a lot here and I hope that documenting this in the long run helps someone else :)
  • WKS-3D
  • WKS-3D's Avatar
26 Nov 2025 02:44
Suche Fusion Postprozessor für Drehmaschine
Category: Deutsch
Vielen Dank das du den PP zur Verfügung stellst, ich werde es die Tage ausprobieren :)
  • Pudding1960
  • Pudding1960
26 Nov 2025 00:30
Probleme beim Bohrfräsen was created by Pudding1960
Category: Fusion 360
Guten Morgen liebe Leute !
Ich möchte euch Heute von einem Seltsamen Phänomen berichten und bin gespannt,ob schon jemand dieses Problem hatte ,oder gar einen Lösungsvorschlag.   Der Sachverhalt ist folgender : Ich habe eine Platte in Fusion 360 Konstruiert, mit unter anderem 6Stk  8er Bohrungen,die zuerst im Bohrzyklus Gebohrt werden und nachher eine 13mm Senkung für den Schraubenkopf durch Bohrfräsen erhalten sollen,alles im selben Setup. Ganz Simpel,schon tausend mal gemacht,aber diesmal will es partout nicht Funktionieren !  Der Fräser will die Senkung 10mm in X Achse versetzt machen ! Wenn ich dann den G Code für den Bohrzyklus Lade,dann fährt der Fräser aber genau an der richtigen Stelle ins Material. Habe schon vieles Probiert,anderes Werkzeug,neues Setup mit genau dem selben Nullpunkt ect alles Erfolglos.  Ich werde als nächste ein neues Setup erstellen,mit dem Nullpunkt in der ersten Bohrung,die ja im Borzyklus Korrekt angefahren wird... Nächste Woche werde ich dann sehen. LG
  • nanowhat
  • nanowhat
25 Nov 2025 18:58
Replied by nanowhat on topic Robotic loader motion planning
I forgot to mention the state machine also has a "manual jog" mode, which I can use to move the machine if, for instance, I manage to crash one pallet into another.
  • nanowhat
  • nanowhat
25 Nov 2025 18:27
Robotic loader motion planning was created by nanowhat
I'm rebuilding a robotic loader. I have a GUI built with GladeVCP hooked to a python state machine. (I am not going to run this robot with Axis or any other machine-tool-oriented user interface).
The state machine already has an interpreter that spits out waypoints, which depend on the state machine's internal variables. What's the best way to connect this to the linuxcnc motion planner?
Displaying 10861 - 10875 out of 11229 results.
Time to create page: 0.881 seconds
