  • Lcvette
  • Lcvette's Avatar
22 Nov 2025 11:40
problems with Y-Axis, elliptic deviations after several changes -Probe Basic V.5
Category: QtPyVCP
could be lost steps causing some errors. i would set the drive settings to fault for ANY lost steps and tune the system until it is not faulting. this would eliminate that. you don't want to run the system in a state where it is losing steps because of motor sizing and machine mass problems.
also i would make sure that your acceleration calculations for both axes come out to be the same.and ideally give both axis the same reduction. just takes several things out of the equation.
  • Muzzer
  • Muzzer
22 Nov 2025 11:20
Updating from LINUXCNC - 2.8.4-23, Mint 20.3 - gmoccapy lathe structure
Category: Gmoccapy
Progress has been made. I opened up the mini ITX PC and examined the 5i25 assembly. This is a Jetway mobo with a single PCI-E slot. I had fitted an adaptor (PCI-E to full size PCI) and a PCI extension ribbon cable to connect the 5i25 which sits parallel to the mobo. This was the root of the problem, as the adaptor board wasn't seated properly. The mechanical assembly isn't ideal, so I will need to address that to avoid a repetition in the future.
gmoccapy now works as it did previously, so I can now move on to installing a new SSD with the current version of Mint and LCNC. I will then tackle the config files etc. Watch this space.....
  • Sekai
  • Sekai
22 Nov 2025 11:14 - 22 Nov 2025 11:21
Replied by Sekai on topic Chinese Mesa 7I92 from aliexpress NEW
Category: Driver Boards
You are right.
the firmware that the seller gave me was 7i92_G540x2D_custom.bit
I did upload it but it gave an error when i started linuxcnc
I install Mesa Configuration Tools and download a firmware from there the 7i92_G540x2D without the custom part and it works.
For now i just tested the pin output
The next problem is when i start linuxcnc it gave me an error: Watchdog has bit!
from the post "Mesa 7i97 Watchdog has bit!"  i did latency-histogram --nobase --sbinsize 1000 and its like this:
btw the pc is minipc Fujitsu Esprimo Q920
  • juergen-home
  • juergen-home
22 Nov 2025 11:12 - 22 Nov 2025 12:42
probe_basic_postgui.hal conflicts with my gamepad*.hal
Category: QtPyVCP
Thanks for your help.
I forgott that twopass is not working for POSTGUI_HALFILE.
So I moved the declaration of the "not" function to the core.sim3.hal (which I had to change into the "names=" format) and change the function names accordingly.
in probe_basic_postgui.hal:
comment out:
#loadrt not
#addf not.0 servo-thread
and in core.sim3.hal insert:
loadrt not names=not1
addf not1 servo-thread
comment out:
#net prog-running not.0.in <= halui.program.is-idle
#net cycle-timer time.0.start <= not.0.out
change in:
net prog-running not1.in <= halui.program.is-idle
net cycle-timer time.0.start <= not1.out
# changed due to a conflict
# halui.program.is-paused is used is gamepad-encoder-16.hal and in probe_basic_postgui.hal
#net prog-paused halui.program.is-paused => time.0.pause
net net-halui-program-is-paused => time.0.pause
I have another problem with pb, but in a new thread.
  • abs32
  • abs32
22 Nov 2025 10:57
How to fix "Queue is not empty after probing"
I must admit with bitterness that version 2.8.4 with its errors in the g38.3+g38.5 part (Probe tripped during non-probe move) works more stably than version 2.9.7 with all its fixes and error (Queue is not empty after probing). The same object (on the machine desktop), ode and the same g-code program, but in version 2.8.4 there are about 60,000 continuous measurements, and in version 2.9.7 there are no more than 40,000.
  • papagno-source
  • papagno-source
22 Nov 2025 10:53
Replied by papagno-source on topic CNC AXIS IN PARKING MODE
Good morning everyone and thanks for the replies.
It's clearly a machine axis, the Z axis.
The machine is old, and in some operations, it's more convenient to be able to drill manually. We're talking about a machine that works with enormous cast iron bases, 10 meters long, so it must have maximum flexibility.
Rown, basically, using your component, I would have:
net Zenable joint.2.amp-enable-out pid.2.enable isfreewheeling
net Zpos-cmd joint.2.motor-pos-cmd pid.2.command
net Zpos-fb joint.2.motor-pos-fb pid.2.feedback
But I don't understand where to connect: pos_fb_out
  • PCW
  • PCW's Avatar
22 Nov 2025 10:46
Replied by PCW on topic CNC AXIS IN PARKING MODE
You don't need a new component for connecting commanded to feedback position
when the joint is disengaged, and the mux component can already do this function.
That is not the tricky part anyway, the tricky part is returning to LinuxCNC control after
the hand motions  were completed.
Ideally there would be a per joint enable signal (that forced LinuxCNCs internal commanded
position to track the feedback position when disabled) but lacking that, a simple hal profile
generator (using limit3 for example) could be enabled to move to the original position
before control is handed back to LinuxCNC.
  • PCW
  • PCW's Avatar
22 Nov 2025 10:05
Replied by PCW on topic 7i76eu steppers don't move
Are the drives locked?
Note that on many step drives. the "enable" input is actually a disable input
and disables the drive when powered.
For checking outputs without a oscilloscope, you can measure the DIR output and
see if it changes when jogging in different directions
A following error may indicate a setup issue and needs to be resolved.
  • BoMadsen
  • BoMadsen
22 Nov 2025 09:57
7i76eu steppers don't move was created by BoMadsen
I have a DMC2 Mini that I am trying to convert from the Chinese Mach3 board that it came with, to a 7i76eu controlled by linuxcnc.
But I am stuck at getting the stepper motors to move. The DMC2 comes with three Nema23 57-76 motors with built-in controllers, similar to this one:
www.aliexpress.com/item/1005006172891348.html
I have wired the motors like this:
EN-  -> TB2 pin 1 GND
EN+ -> TB2 pin 6 +5VP
DR-  -> TB2 pin 4 DIR1-
DR+ -> TB2 pin 5 DIR1+
PU-  -> TB2 pin 2 STEP0-
PU+ -> TB2 pin 3 STEP0+
But nothing happens when I try to jog the axis. The DRO in the UI change, but the steppers are totally silent. After a while jogging around, I usually get a "Join 0 following error".
I can measure +5v on EN, so I believe that the axis is enabled.
I have just installed LinuxCNC from the livecd, and the configuration is made with pncconf.
Any ideas on what could be wrong, or what I can do to debug it? I don't have an oscilloscope, so I have a hard time actually confirming that the MESA card sends out pulses.
Thank you in advance!
  • PCW
  • PCW's Avatar
22 Nov 2025 09:46
Replied by PCW on topic Chinese Mesa 7I92 from aliexpress NEW
The basic issue is that the current firmware is just GPIO (no Step/Dir hardware etc)
There could be a couple reasons for this:
1. The wrong firmware is installed,
2. The card had corrupted firmware so has loaded the fallback firmware (which is just GPIO)
Did the card vendor supply a firmware file?, it does not look like any standard 7I92 firmware to me
If they did supply firmware, I would try re-writing it with:
mesaflash --device 7i92 --addr 10.10.10.10 --write  vendor_supplied_firmware_file_name.bit --reload
22 Nov 2025 08:21
Replied by tommylight on topic StepperOnline A6 Servo
Category: EtherCAT
Where should we move the above reply to?
  • bszoke
  • bszoke
22 Nov 2025 07:43
Replied by bszoke on topic StepperOnline A6 Servo
Category: EtherCAT
I made some comments on this in another thread about the PDO configuration, you are correct, internally it does configure the PDO's and sets the PDO assignment register ONLY if you set configPdos="true".
forum.linuxcnc.org/ethercat/56205-help-w...ives?start=20#338949
  • aDm1N
  • aDm1N's Avatar
22 Nov 2025 07:38 - 22 Nov 2025 14:55
EtherCAT + CiA402 Servo: OP state reached, but axis won’t move (only Following E
Very short explanation of how PV ↔ CSP switching works:
Only one CiA-402 mode is active at any time.
In spindle mode (PV):
- The drive receives only target-velocity.
- HAL forces: pos-cmd = pos-fb (follow-mode).
- So the axis has no position error while the spindle is turning.
When switching to C-axis mode (CSP):
- HAL switches pos-cmd from “follow-mode” to the motion planner.
- Since pos-cmd == pos-fb at the moment of switching, there is no position jump and no torque spike.
Why this is valid:
- PV mode ignores position commands.
- CSP mode ignores velocity commands.
- Therefore the drive never receives conflicting commands.
- This fully complies with CiA-402 behavior.
Status:
This configuration has been tested electrically only.
The motors run and switch modes as expected, but the mechanical connection to the machine is not installed yet.
  • Aciera
  • Aciera's Avatar
22 Nov 2025 06:50
Replied by Aciera on topic linuxcnc_2.9.4-amd64.hybrid.iso cheksum?
At this juncture you all disgust me.
Like so many times before when you noisily left this forum just to reappear a few days later under a different login.
  • unknown
  • unknown
22 Nov 2025 06:45
Replied by unknown on topic PoKeys57CNC HAL component
Category: HAL
Thank you for giving back to the community, it's refreshing to see rather than those that just take take take.
A Tip O The Hat to you sir
Displaying 11056 - 11070 out of 11230 results.
Time to create page: 1.242 seconds
