11 Nov 2025 21:29
Replied by tommylight on topic beta bulleri for retrofit?
Category: CNC Machines
Try jogging with on screen buttons, does it still jerk?
The wire you connected 24V is the machine enable, so it goes to Mesa 7i77 output, while the other wire should go to input as machine is ready. Does the other pin come from the ON/START/GREEN button?
Tuning does not seem OK, but it is very nice that you can jog at low speed, try increasing the speed gradually and see this for further instructions:
  • dgdodo
  • dgdodo
11 Nov 2025 21:18
Replied by dgdodo on topic [SOLVED] Backlash issues on Y-AXIS
I Tried with 'hal_pi_gpio.write base-thread' at the end of the base-thread, but it does not make any difference.
Thanks for the info anyways.
11 Nov 2025 21:09
Beckhoff Problem with Communication (TwinCAT, LinuxCNC)
Category: EtherCAT
No double posting.
And fix the tittle to explain what it is about.
Thank you.
  • peterpan
  • peterpan
11 Nov 2025 20:42
Replied by peterpan on topic Trouble with Cia402 drive configuration
Category: EtherCAT
I can't find much on Ethercat homing. Maybe I'll be able to figure it out down the road. How would I set it up with Inputs on the EL1008 instead, in the meantime?
  • peterpan
  • peterpan
11 Nov 2025 20:29
Replied by peterpan on topic EtherCAT servo homing
Category: EtherCAT
My drive have several homing method built in, and I recently solved to change the drive state druring the LCNC start, so I can initialize the drive to HM mode first, than CNP mode.
How?
  • Masiwood123
  • Masiwood123's Avatar
11 Nov 2025 20:25 - 11 Nov 2025 20:26
  • endian
  • endian's Avatar
11 Nov 2025 20:18
Replied by endian on topic Ethercat HAL driver
Ethercat HAL driver
Category: EtherCAT
Translate it as complex . Import it as s32 or u32.. Then create simple component to cut it a pieces... Simple and effective
  • Masiwood123
11 Nov 2025 20:14 - 11 Nov 2025 20:24
  • Masiwood123
11 Nov 2025 20:12
Replied by Masiwood123 on topic beta bulleri for retrofit?
watch both videos, I think the following is motor tuning, connecting the home switch, and again I have a problem with the keyboard, the velocity changes when jogging, I need to find Tommylight's post on how to solve it. thanks:)
  • DemonClaW
  • DemonClaW
11 Nov 2025 19:16 - 15 Nov 2025 07:50
Category: EtherCAT
Hey Guys,some of you know so much about this Topic so I hope I can find someone in the mood to help me.Im trying to make a CNC 3-Axis on Raspberry PI5 and Beckhoff, the problem is that im completly new in this topic and try to learn as much as possible but i got already stuck in the beginning. EtherCAT works fine and i got the "Koppler" and Cards but if im trying to get them into LinuxCNC like some videos teach the Programm wont start anymore
If i start i get the message: Failed to register PDO entry: No such file or directory
LCEC: master 0 PDO enty registration failed
A friend and myself checked the code 10x, and it seems that the problem starts before. I cant get the EK1100 connected to TwinCat or CodeSYS, too. Whats kind of weird to me because as i said if I try it with the "ethercat slaves" command, it knows The Ek1100 and all Cards
Thanks for everybody who can help me with this and invests some of his time for me
  • zz912
  • zz912's Avatar
11 Nov 2025 18:58
Replied by zz912 on topic Compile files in /linuxcnc/lib/
You probably don't need to compile the gtk_little_probe.py file.
Python is an interpreted language, so often you just need to make the edits and run the code.
It is true, but not in LCNC.
If I modify this file:
/home/zdenek/linuxcnc/linuxcnc-zz912/src/emc/usr_intf/gmoccapy/gmoccapy.py
It returns:
zdenek@cnc:~/linuxcnc/linuxcnc-zz912/src$ make
Reading 203/203 dependency files
Done reading dependencies
Reading 274/274 realtime dependency files
Done reading realtime dependencies
make: Vstupuje se do adresáře „/home/zdenek/linuxcnc/linuxcnc-zz912/src“
Syntax checking python script gmoccapy
Copying python script gmoccapy
You now need to run 'sudo make setuid' in order to run in place with access to hardware.
make: Opouští se adresář „/home/zdenek/linuxcnc/linuxcnc-zz912/src“
The most important sentence is:
Id dont know why and where, but it works.
gmoccapy.py is in /src/ folder and it works.
I placed the wrong file here, I meant:
/linuxcnc/lib/python/gladevcp/builtin-panels/gtk_verser_probe/gtk_verser_probe.py
You can try modify it, but noting happens.
MAKE doesnt see it.
  • Hakan
  • Hakan
11 Nov 2025 18:30
Replied by Hakan on topic Ethercat HAL driver
Ethercat HAL driver
Category: EtherCAT
The array data types are not implemented in linuxcnc-ethercat.
Not 100% sure about IgH Ethercat master.
  • Masiwood123
11 Nov 2025 18:15
i will make short video what is all about that problem later.
  • Hakan
  • Hakan
11 Nov 2025 18:14 - 11 Nov 2025 18:16
Replied by Hakan on topic Trouble with Cia402 drive configuration
Category: EtherCAT
The following error can be large due to physical reasons, such as the axle sticking, tool breakage, etc.
With a good FERROR setting, the machine stops with a warning instead of destroying all sorts of things.
That's what you want. When the servos are working well, you should tighten the FERROR values ​​to get that protection.
Normally, values ​​are specified in the INI file.
With Ethercat it isn't so stream-lined yet, some values are set directly in the hal file like the pos-scale.
You can do it yourself, but it often introduces one more level of complexity when one just wants the machine to work.
In the ini file create a [ETHERCAT] section like below
[ETHERCAT]
CIA402_POS_SCALE_X = 200.0
and more
and use it in the hal file
setp cia402.0.pos-scale [ETHERCAT]CIA402_POS_SCALE_X
Optional.
I am not the right person to elaborate on ethercat homing.
I use linuxcnc's homing variant with switches in the traditional way.
Many people have used ethercat homing, search the forum, or maybe someone chimes in.
There are 3-4 lines mentioning homing in the cia402 documentation github.com/dbraun1981/hal-cia402
  • Masiwood123
11 Nov 2025 18:08
 thank you very much for the answer, it will certainly help me later, now i have come to the conclusion that I could destroy the drivers by bringing 24v for enabling, it did not occur to me that the old controller gives 10v on that output, otherwise they are all 24vdc. and now here in the picture you can see these white wires, they are connected to enable on pin 7, however, the pin 6 from the driver just gives 10v and then I managed to short-circuit to pin 7 and the drivers are enabled, however, I still need to understand the estop chain so that the switch that supplies power to the drivers would stick, when I turn it on manually, the axes slide slightly to one side, maybe mm/min, I assume that the offset on the trimmer is not well adjusted, But, when all that I did it via the Mesa 7i77 card, i installed enable and brought the wires for the analog signal of the axis, when i start linuxcnc machine F2  axis move a little and stop(joint following error) (I will have to try to tune the motors first or maybe I should try to turn the analog wires ref and ref-?
Displaying 11206 - 11220 out of 12799 results.
Time to create page: 0.976 seconds
