  • andypugh
  • andypugh's Avatar
11 Nov 2025 17:06
Replied by andypugh on topic Compile files in /linuxcnc/lib/
You probably don't need to compile the gtk_little_probe.py file.
Python is an interpreted language, so often you just need to make the edits and run the code.
So, the reason that "make" is not doing anything is that the file in question is not mentioned in the makefile, as it is simply interpreted as and when needed.
(There is a complication that Python code is compiled to bytecode (.pyc) and sometimes that might be run instead.)
To be sure that your edited file is running, maybe put a "print("this is version 2.2.2") near the top of the file?
  • Lcvette
  • Lcvette's Avatar
11 Nov 2025 16:45
Replied by Lcvette on topic Probebasic tool length calculation
Category: QtPyVCP
G49, did you modify your tool setter macro? If not I would check that your var file and pb version are all correctly aligned and the parameters are storing in the var file.
11 Nov 2025 16:38
Replied by tommylight on topic beta bulleri for retrofit?
Category: CNC Machines
Pots do not work with digital inputs, but encoders do, so given enough space the pots can be switched for encoders.
For rough analog, Mesa 7i77 has 4 analog inputs (in0-in3) when set in mode 2, you can try that and see if it is usable for you.
For outputs, 2.10 (or Master) has a nice feature where you can toggle inputs and outputs from the "show hal configuration" menu, so add the Mesa outputs by assigning some random names to pins, then use the above to toggle on and off outputs by clicking on SET or clear, as shown bellow:
  • peterpan
  • peterpan
11 Nov 2025 16:03
Replied by peterpan on topic Trouble with Cia402 drive configuration
Category: EtherCAT
I figured out how to setup homing mode in the ClearView software, and setup a home sensor, but I have no clue how to make it start homing when home is pressed in linuxcnc. I assume I need to do something with the joint.0.index-enable pin?
  • PCW
  • PCW's Avatar
11 Nov 2025 15:14
Replied by PCW on topic Determining Rate Of Accelleration
You can get acceleration by taking  the derivative of the encoder velocity pin with the HAL ddt component.
  • peterpan
  • peterpan
11 Nov 2025 15:05
Category: EtherCAT
Sweet, so setting the following error higher allows it to run at higher speeds. What is the trade-off? Is it less accurate with a higher following error?
How do I know when to edit something in the .ini file vs the .hal file? it sounds like ferror is linked to a hal pin, but is configured in the .ini file..?
Then, regarding a completely different topic, I was wondering about the pros and cons of using the servo's built-in Homing mode. And if it makes sense to, how would I use HM to home, then switch to CSP for operation?
On the same topic of homing, how would I set that up? Is there a hal pin for homing that I would need to link to a homing sensor?
  • TurboStreetCar
  • TurboStreetCar
11 Nov 2025 14:48
Determining Rate Of Accelleration was created by TurboStreetCar
Hello, i have a project im working on (Not a CNC machine, but i believe a Mesa card is good capable hardware for this application) where im trying to determine the rate of acceleration of an externally driven spindle using an encoder.
There doesn't seem to be any built in components for this that i can find.
The use case, is to feed the rate of acceleration into a PID loop to control the output of a stepper/servo that regulates the spindles speed.
Is there a relatively easy way to measure/determine rate of acceleration accurately?
  • Beovoxo
  • Beovoxo
11 Nov 2025 14:27
ASDA-A2-1521-E parameter list for ethercat com
Category: EtherCAT
thx :) i thought the light would be on, and flashing while communicate. i just connected them to the ek1100 and no faults :):)
  • seuchato
  • seuchato
11 Nov 2025 14:17
Replied by seuchato on topic Toolchanger HAL Component project
Category: HAL Examples
smc.collins
Interesting work you present here! I might get a chance to start implementing a tool changer over christmas/new year.
Greez
chris
  • Plasmanfm
  • Plasmanfm
11 Nov 2025 13:45 - 11 Nov 2025 13:46
Replied by Plasmanfm on topic THC Plasma
THC Plasma
Category: Deutsch
Hallo rodw
I hadn't installed THC until now . And have found that it is better if you use metallsheet with about 2 mm
With a cutting height 1.8 mm 22 amp nozzle 0.9 I measured 103 volts
And nice cutting results .
Now that the intermediate sizes of the resistors are very bad to get, I go to 200 V
King regarde
Juergen
  • unknown
  • unknown
11 Nov 2025 11:03
Replied by unknown on topic [SOLVED] Backlash issues on Y-AXIS
addf hal_pi_gpio.read base-thread
addf hal_pi_gpio.write base-thread
addf pwmgen.make-pulses base-thread
Has this always been the case, usually the write function is the last one in the list.
  • dgdodo
  • dgdodo
11 Nov 2025 10:01 - 11 Nov 2025 10:04
Replied by dgdodo on topic [SOLVED] Backlash issues on Y-AXIS
Unknown:
I am very sure the .ini file was added in the first post, but I don't see it anymore?
Here again.
And yes I mentioned BACKLASH in the JOINT_1 section of the Y-AXIS, otherwise there wouldn't be any difference between 1, 2 and 3 in the picture?
File Name: dgplotter_...1-11.ini
File Size:6 KB
There the backlash was set to 1, 2 and 3.
Why does the picture get bigger (higher) instead of doing the backlash?
langdons:
After some years I thought it would be good idea to be 'up to date'.
What I always do with all my other Linux machines here, regularly
  • rodw
  • rodw's Avatar
11 Nov 2025 09:31
Replied by rodw on topic THC Plasma
THC Plasma
Category: Deutsch
There is not much point upgrading from THCAD5 or THCAD10 to THCAD to THCAD2 as it is functionally identical except you can select 0-5v or 0-10 volt scales.
I personally think 150v is a bit low given cutting volts can be up around 130-140 volts. I would set to 180 to 200 volts.
  • unknown
  • unknown
11 Nov 2025 09:06 - 09 Dec 2025 04:31
Experimental raspios Linuxcnc Trixie images.
Category: Installing LinuxCNC
I've been working on using a new build system for Raspberry images based on the utilities that are used on the official images. No custom kernel as RPi does provide pre-built RT kernels, but the 6.12.47 version has had reports of crashing. And yes raspi-config is included.
Benefits include being able to use Raspberry Pi Imager to preconfigure user name & password, local, all other things Raspberry Imager enable you to configure. There is now a single image for the 4 & 5 models. These are the only models supported. No there is no wayland, so don't try to changes this via raspi-config. The desktop environment is xfce.
I haven't included vnc as that brings in all the CUPS (printing) software and the associated services.
Only one browser is included, Firefox-esr.
Some simple screensver & power management items have been configured.
There is a network applet near the clock to simplify configuring a wired network. Please take note that the Raspberry's network address should not be that same as your mesa card, ie the last number in the address should differ. (sorry for those that are aware, but it pops up from time to time)
I have also included a fix for the CNC items appearing under multiple categories. This will survive upgrades. Due to the way Debian runs these "hooks" it will run after every time apt, apt-get or dpkg is run. Changes will only be made when it is required. No isolcpus has been added to the commandline, but this can be added by the usual methods.
Downloads are here - currently waiting to be updated 09 Dec 2025;
Please note the image on the Linuxcnc downloads page is missing a browser and a pdf reader, but will still run Linuxcnc itself fine. I apologise but so far I've been "on my own" building and testing.
If anyone is willing to test and point out any glaring errors it would be most welcome.
Rob
Any issues please raise here
github.com/ozzyrob/linuxcnc-rpi-2.9.7-image-issues/tree/main
Displaying 11221 - 11235 out of 12798 results.
Time to create page: 0.828 seconds
