  • clayton2ndtry
  • clayton2ndtry
06 Nov 2025 03:53
"file ./live/filesystem.squashfs failed the MDS checksum"
Category: Installing LinuxCNC
Okay. I am using Rufus but it does not like the ISO. The complaint is "the ISO you have selected contains a UEFI bootloader that has bween revoked. and that will produce a "Security Violation" screen. Rufus suggests a more up to date ISO. linuxCNC 2.9.4 is not current enough?
  • cmorley
  • cmorley
06 Nov 2025 03:42
Replied by cmorley on topic Rotary axis in Qtdragon_hd
Category: Qtvcp
Can you post your config files?
06 Nov 2025 03:06
Replied by tommylight on topic High frequency ohmic struggles
Category: Plasmac
You should have mentioned that, could save me several minutes of typing ! :)
You are welcomed, always.
  • bentiggin
  • bentiggin
06 Nov 2025 02:44
Replied by bentiggin on topic High frequency ohmic struggles
Category: Plasmac
Long story short, a lot of things were changed before I replaced the the 7i97t. Since then, I have have been cutting with zero issues. The thcad for arc volts is reading accurately while cutting. The thcad for ohmic is not hooked up. I can't get it to work, but maybe that's a good thing because it sounds like it's a bad idea with hf start.
The longer story is that this machine didn't have a home. So while its new home was being built, I set it up temporarily in my shop, so I could attempt to retrofit it with linuxcnc. When I fired up the torch for the first time, it damaged the 7i97t. This was with both ohmic and arc volts hooked up, so its anybodys guess what caused it. I added some grounds and an emi filter and few other things then replaced the 7i97t. Then I got it working great with a non hf plasma(except I didn't hook up ohmic).
Then after it was moved into its new home, we added several ground rods and hooked it up to the hf start plasma the way you had just advised. It's been cutting great.
I know I ask a lot stupid questions but I do appreciate the help.
  • Jamanji
  • Jamanji
06 Nov 2025 01:46
Replied by Jamanji on topic issues with MESA to SCARA kins
Category: Basic Configuration
Its an Ethernet card, i got the motors to spin as though it were a milling machine, but SCARA isn't an option. The default it has is XYZ, XYZA and XZ lathe, none of those options are what i need. I followed a few guides that said how to change the kinematics but so far, following those guides, I've had no luck. I was hoping that might be able to helps me out with either more direct communication or by providing a working example.
  • unknown
  • unknown
06 Nov 2025 01:40
If there was a "known problem" it would have been fixed pretty quick.
The guys that build the ISO test them, they aren't just built and thrown out into the wild, things just don't work that way.
Usually in these kind of issues the first port of call should be to check the download as tommy suggests, rather than just assume it's a problem with the way the ISO has been built.
Is there any reason you cant boot from a USB drive ?
06 Nov 2025 01:10
It helps to burn the DVD at 1X speed, if at all possible, as it lowers the write errors.
I would also check the manufacturing date on the DVD box, fully enclosed they can be OK for 5 to 20 years depending on moisture in environment, hermetically sealed even more.
Did you check the MD5SUM or SHA256 for the download? It can also be a bad download due to interruptions or drops in connection.
  • PCW
  • PCW's Avatar
06 Nov 2025 01:08
Replied by PCW on topic Bricked Mesa 7i92T
Bricked Mesa 7i92T
Category: Driver Boards
It comes down to what pinout you need.
What is the 7I92T connected to?
That is, what breakout board are you using?
  • clayton2ndtry
  • clayton2ndtry
06 Nov 2025 00:56
I burned the 2.9.4 ISO to a DVD.  Because my DVDROM drive went bad recently, I bought a replacement.  Amazingly, I found an exact match for my Dell Optiplex 960.  It plugged right in, passed diagnostics and successfully booted from DVD.  I went a burned it again.  Same problem.  Is there a known problem with the release ISO, or does Windows 11 ISO burn just not work?
  • FPVUALAB
  • FPVUALAB
06 Nov 2025 00:44
Replied by FPVUALAB on topic Bricked Mesa 7i92T
Bricked Mesa 7i92T
I downloaded the archive for mesa 7i92t cards from the official website, but there are so many different firmware versions that I don't understand which folder I need to copy.
  • FPVUALAB
  • FPVUALAB
06 Nov 2025 00:41
Bricked Mesa 7i92T
The thing is, I don't know how to do it))
This is my first time doing this, and I'm already panicking because I've been trying to figure it out for over a month))) Now I've decided to ask people for help!))
My LinuxCNC doesn't have any firmware for Mesa 7i92TH at all.
  • PCW
  • PCW's Avatar
06 Nov 2025 00:08
Bricked Mesa 7i92T
mesaflash 3.5.16 is the latest
If you want 4 stepgens and 4 encoders, what pinout do you want?
(If for a 7I85S you would use 7i92t_7i85sx2d.bin = config fir 7I85S with 4 stepgens, 4 encoders, 1 sserial port per connector)
05 Nov 2025 23:59
05 Nov 2025 23:57
Help with Wireless Handwheel XHC-WHB04B-6 (wrong Product ID)
@Rod,
We can not edit your youtube videos on your youtube studio! :)
how is the html code for grin?
05 Nov 2025 23:55
Category: Plasmac
I think there are much bigger issues than ohmic sensing from what you describe, namely bad wiring/shielding/grounding in general, so my strong advice is:
-do not fire the torch before grounding things properly
-make sure the power socket and the machine are grounded and the shop has proper ground rods
-make sure the PC is grounded
-make sure the plasma source is grounded
-disconnect anything ohmic related from Mesa
-disconnect the THCAD from Mesa
-connect THCAD only to plasma source
-wire and test the new Mesa, make sure everything works properly, wire the Torch ON to plasma source
-power on the plasma source and cnc machine and start QtPlasmaC or PlasmaC or whatever you are using
--enable LinuxCNC, jog around a bit, then use the Torch PULSE on screen set to 1 sec (default) ONLY ONCE !!!!!
-did anything move/burn/make strange noise/screen blank/PC turn off or lock/Mesa reset or lost connection/THCAD smoking ?
If any of those is yes, turn OFF everything and go back to wiring/shielding/grounding (goggle Hypetherm grounding they have a nice general guide)
If all above are no, try the pulse again and again, waiting 5 seconds between, make the pulse time 3 seconds and test several times again
If all that goes OK, try to do some manual cutting (use F9 to probe and fire the torch then jog manually), do several short cuts
If all good, power down and wire the THCAD to Mesa, do the same procedure from the line with two - signs above
ONLY if all tests go without issues proceed to wiring and testing Ohmic sensing. Again test from line with two -
Displaying 11431 - 11445 out of 12816 results.
Time to create page: 2.068 seconds
