  • boksi
  • boksi
25 Oct 2025 11:07 - 25 Oct 2025 11:25
Mesa smart serial or PktUART or serial over RS232 or udp for robot joints
It's good thing to know.
Do you know are there some configs with stmbl driving robots available around?
I saw some integrations with robots but encoders are read by mesa cards directly.
I would be more interested in this part which you mentioned if stmbls are set up in this way that they send position over smart serial.
Do you happen to know on higher level how this position report over smart serial works if we want to read 6 robot joints positions?
Correct me if I am wrong, but possibly in HAL we would have 6 sequential position requests, one request per each joint. We would wait for each one stmbl to report its position. So request + stmbl processing time + reply over smart serial and this happens 6 times. From fast look earlier not 100% sure but I think that there are 2 mcu in stmbl, so possibly one of them fast handles communication.
  • andypugh
  • andypugh's Avatar
25 Oct 2025 09:59
Interesting that you mentioned stmbl, I remember they were integrated with some robot (video of manutec carrying a coin).
Do they send its position over smart serial ?
They do report position by smart-serial if configured to do so. And can also accept position commands the same way (but it is all configurable)
STMBL firmware has its own HAL so you can configure the command module and the feedback module (and quite a lot more)
  • andypugh
  • andypugh's Avatar
25 Oct 2025 09:56
Replied by andypugh on topic Maho MH800e Retrofit Project
Category: Milling Machines
watching the "DRO" the z axis zeros then moves, hits the index, zeros, and then hits the estop. I have the offset set to 0 so it should just stop correct?
There is a final move to the HOME position once the switches (and index, where specified) have been found.
linuxcnc.org/docs/stable/html/config/ini-homing.html
It is possible that your HOME_OFFSET has the wrong sign.
  • Hakan
  • Hakan
25 Oct 2025 08:20 - 25 Oct 2025 08:26
Help with Delta E3 Ethercat drives - hal and ethercat-conf.xml
Category: EtherCAT
That's what makes it so challenging with ethercat. Settings in several places and cross-dependencies.
Anyways, the second line in ethercat-conf.xml has the appTimePeriod setting.
There also :)
There are two more settings you can do now when things start to work.
Add this line right under the "<slave" line
<dcConf assignActivate="300" sync0Cycle="*1" sync0Shift="0"/>
and go back up to the second line in the file and add a minus-sign to the refClockSyncCycles value
<master idx="0" appTimePeriod="1000000" refClockSyncCycles="-1000"
  • ddVll
  • ddVll
25 Oct 2025 07:54
RS-422 Linear Magnetic Encoder shows ERROR LED after power-on (Mesa 7i76 + 7i85)
Category: Driver Boards
You are right.
Switched the 7I85 channel to TTL mode, disconnected A−/B−/Z−, and kept +5, A+, B+, Z+, GND only.
The encoders now start in IDLE every time and looks work.
These Chinese “RS-422” linear scales most likely don’t have a true RS-422 line driver and cannot drive the 120 Ω termination on the Mesa inputs.
As a side note — it seems these low-cost Chinese sensors are often mislabeled:
one of my units was even shipped with 1 µm resolution instead of 5 µm as specified.
So if anyone else is buying similar “RS-422” magnetic scales, be cautious — the specs are not always accurate.
  • Aciera
  • Aciera's Avatar
25 Oct 2025 07:27 - 27 Oct 2025 13:44
VTK based version of Vismach was created by Aciera
Category: Show Your Stuff
This is a new version of the 'vismach' simulation tool based on VTK instead of OpenGL:
github.com/Sigma1912/vtk-vismach
Still work in progress.
For more information see the README and the comments in the files.
  • Clements
  • Clements
25 Oct 2025 06:13
Replied by Clements on topic gmoccapy probe
gmoccapy probe
Category: Basic Configuration
I had a pretty hard time finding a pc with a parallel port. I don’t use a mesa card
The new pc is a dell optiplex 980 That is a very compact unit. The old HDD doesn’t seem to fit in the housing.
I use pcloud for gcode synchronization and I just couldn’t open the site on 2.8. So I decided to install te latest version of LinuxCNC
  • boksi
  • boksi
25 Oct 2025 05:30
Yes that is right.
I suppose when position is requested drives can’t replay all at same time because of other priorities, but stll they have to provide position.
I have custom drives build and they are reading encoders and do control but I am looking next part integrating with kinematics module.
  • thefabricator03
  • thefabricator03's Avatar
25 Oct 2025 04:48 - 25 Oct 2025 04:49
PlasmaC Fatal Error Message was created by thefabricator03
Category: Plasmac
Hi Guys,
A plasma machine I built that runs the original PlasmaC is having a fatal error message that is stopping the machine from operating.
The guys who run the machine tell me the machine ran fine last Friday and when they came to use it on Monday morning they got this error message not matter what gcode program they tried to run.
This same issue happened back in March, and the only way I could fix the issue was to reformat the machine to a default state. Since it is re-occuring, there must be something going on to cause the issue.
Ive attached the gcode file to this post.
  • bentiggin
  • bentiggin
25 Oct 2025 02:29
Replied by bentiggin on topic Hypertherm hsd130 interface
Category: Plasma & Laser
I finally got around to getting everything wired up enough to test.
At first, I couldn't get it to start using a relay and a power supply on a switch. I realized the manual says "or dry contact closer", so I wired the relay directly to start- pin 15 and start+ pin 34, which worked.
Now I can't get my arc ok signal. I followed the example wiring in the manual. I connected ark ok+ pin 23 to the relay. Then 24vdc+ pin 37 to the relay. Then ark ok- pin 4 to power ground pin 36.
Wired up like this, the arc will not start and the plasma cutter gives an error. If I disconnect the ground to ark ok- pin 4, the plasma will start without errors. I am getting 24 volts between power and ground, and the 2 ark ok pins will close the circuit when the arc starts.
I am attaching the examples from the manual plus diagram of how I wired the arc ok relay.
I may have wired it up like example 4(which it says don't use) a long time ago before I decided to remove the old interface connection on it, so maybe that messed it up.
Does my ark ok wiring seem right? Should I try wiring it differently or should I consider using a reed relay instead?
  • ihavenofish
  • ihavenofish
25 Oct 2025 02:16
Replied by ihavenofish on topic New ethercat / probe basic control for minimonster
Category: CNC Machines
Poke. Figured I should stick this here.
Machine is back together with some new upgraded, ethercat is working for the xyz.
Now I'm on to making the spindle work with modbus.
Is there a simple step by step instruction to set this up? I got a usb adapter, and I'm running qtdragon. In addition to just tuning on and off, id like it to display the true spindle speed and the load.
  • Cooped-Up
  • Cooped-Up
25 Oct 2025 00:54
Replied by Cooped-Up on topic Maho MH800e Retrofit Project
I thought so but obviously something is wrong. I did post my ini file a post or so ago. I was trying to change the direction the axis moves after the index is seen. Nothing I change seems to do anything
  • PCW
  • PCW's Avatar
25 Oct 2025 00:30
Replied by PCW on topic Maho MH800e Retrofit Project
Do you ini file settings match the requirements for index only homing?
linuxcnc.org/docs/html/config/ini-homing.html#_configuration
  • andypugh
  • andypugh's Avatar
24 Oct 2025 22:49
The STMBL drives can work with Yaskawa encoders.
(But supply is an issue)
forum.linuxcnc.org/27-driver-boards/5375...tmbl?start=30#311767
I see that you already know about their existence, but it might be worth considering using them.
  • boksi
  • boksi
24 Oct 2025 22:32
as I see from list there is no support for this type of encoder.
It's yaskawa absolute 12bit encoders. After power up some mS and it sends its absolute position over UART, after that if it moves it starts to send only quadrature pulses A/B like normal incremental encoder.
Displaying 12121 - 12135 out of 12865 results.
Time to create page: 1.946 seconds
