  • jschulze
  • jschulze
30 Sep 2025 16:51
Replied by jschulze on topic Wrapped Rotary on Non Rotary Axis Letter.
Category: Basic Configuration
I am impoving a Java macro program called Repeat that uses matrices to identify mouse gestures; it works, but I have absolutely no idea how or why it works.
Yeah, I'm really glad Aciera put in all of the hard work to get it all working, otherwise I'd never be able to get TCP or TWP working myself.
  • MacKaye
  • MacKaye
30 Sep 2025 16:35
sticky estop, help needed was created by MacKaye
Hi everyone, i have tried entering some older threads but to no avail. I have currently a very strange behaviour to deal with. I´ve tried each and every logic to get my system to reset halui.estop.is-activated and have resorted to a very basic.hal that does nothing but try to reset emc-state 3 (estop reset). I even built a python logger skript that can log emc-state and all hal pins, but no matter what i try, i can´t reset estop.
Are there any hidden inputs into system estop? I´ve been looking into github to track all connections to emc-state, but i found nothing revealing but this is way above my paygrade anyhow.
All help is very much appreciated, i am close to being crazy, doing the same thing over and over again
  • Ahmed.emara
  • Ahmed.emara
30 Sep 2025 15:41 - 02 Oct 2025 13:09
Reading data from var file using Python was created by Ahmed.emara
Category: O Codes (subroutines) and NGCGUI
SOLVED!
Hello everyone, In my machine setup I probe some points and store them in the var file. The probing is done through a custom M-code, and the probed coordinates are saved into parameters (variables). After that, I want to read these parameters from a Python script. I managed to do it, but I found that the Python script only sees the updated values if I restart LinuxCNC.
 After digging I found out that parameters are saved in internal memory and, while shutting down, they get copied into the var file.That's why when I restart, my Python script works fine.My question is:Is there a way to access the internal memory directly and read the arameters with a Python script so that I don't need to restart the machine? Or if not, is there another way to access the probed points live without restarting?Thanks in advance!
  • kb58
  • kb58
30 Sep 2025 14:59 - 30 Sep 2025 18:04
(Solved) Initialization code for a rintelligent ECT60 fails when run on an ECR60
Category: Driver Boards
I don't know the syntax for writing a line of code that causes a factory reset.
I'll try downloading the XAE code and print out the config file to see if there's anything different.
I'll also try "ethercat rescan", thanks.
Just to prolong the drama a bit, the Amazon seller of the ECT60 drive reported that a week-long national holiday is coming up, so they won't be able to ship the drivers until they return - and cancelled my order. Perhaps this is the universe telling me to keep working on the ECR drivers...
  • peterpan
  • peterpan
30 Sep 2025 14:57
Replied by peterpan on topic Trouble with Cia402 drive configuration
Category: EtherCAT
LINUXCNC - 2.9.4
Machine configuration directory is '/home/cnc/linuxcnc/configs/sim.axis'
Machine configuration file is 'axis.ini'
Starting LinuxCNC...
Note: Using POSIX realtime
Found file(REL): ./ethercat.hal
LCEC: slave 0.D4: FAILURE: FAILURE: more input PDO entries configured than your hardware supports.
Axis 1 has 13 PDO entries, vs a configured limit of 8.  You will need to edit your XML
configuration and either remove some <modParam name="enable*"> entries or increase
<modParam name="ciaTxPDOEntryLimit">. Check your CiA 402 slave's hardware manual to determine the
correct limit.
Enabled features that impact this limit are:
  -  <modParam name="enableActualFollowingError" value="true">
  -  <modParam name="enableActualTorque" value="true">
  -  <modParam name="enableActualVoltage" value="true">
  -  <modParam name="enableErrorCode" value="true">
  -  <modParam name="enablePositionDemand" value="true">
  -  <modParam name="enableProbeStatus" value="true">
  -  <modParam name="enableTorqueDemand" value="true">
  -  <modParam name="enableVelocityDemand" value="true">
In addition, disabling unneeded CiA 402 modes may help, as some implicitly add additional PDO entries:
  -  <modParam name="enablePP" value="true">
  -  <modParam name="enablePV" value="true">
  -  <modParam name="enableCSP" value="true">
  -  <modParam name="enableCSV" value="true">
  -  <modParam name="enableCST" value="true">
  -  <modParam name="enableHM" value="true">
  -  <modParam name="enableTQ" value="true">
LCEC: Invalid appTimePeriod of 0 for master 0 (should be 1000000).
correct limit.
note: MAXV     max: 5.000 units/sec 300.000 units/min
note: LJOG     max: 5.000 units/sec 300.000 units/min
note: LJOG default: 0.250 units/sec 15.000 units/min
note: jog_order='X'
note: jog_invert=set()
When you say to try TwinCAT, do you mean hook it up on a windows system?
If I were to just get a different drive to make this easier for me, which lineup of drives would you recommend, so that I run into as few problems like this with lcec?
  • jschulze
  • jschulze
30 Sep 2025 14:56
Hmm...
There must be a solution so your setup can be XYZABC.
How does the PC communicate with the machine?
I use a Mesa 7i76eu with ethernet.  I'm guessing with a little trial and error I could modify the kinematics file to just set the B axis value to a constant 0 to avoid it being in the calculations for TCP and then passthrough the actual value to my joint.  The actual matrix math stuff is well beyond my level, so I'd rather leave that alone.  Not totally sure I'd want to label it B axis instead of W anyway, since B wraps around Y in my head.
I'm going to work a bit on trying to get the axis to retain position values when it's in spindle mode, I'm using a step/dir servo, so I need to figure out a way to keep track of position somehow.
  • heaven
  • heaven
30 Sep 2025 14:38
Replied by heaven on topic Robot / coBot functions
Posible but not simple,
1. Linuxcnc control robot arm - Yes
2. Hand teach - No, you have to build it by force/torque sensor or dynamic model
2. Linuxcnc logging it's trajectory - Yes but linuxcnc trajectory planner only support 3 axis-XYZ readahead. This mean if you record 6 axis and playback it will be very slow
  • Hakan
  • Hakan
30 Sep 2025 13:49 - 30 Sep 2025 14:24
Replied by Hakan on topic Sync Problem LinuxCNC + EL8EC400F
Category: EtherCAT
Good to hear. Especially the -10 thing.
The "-" actually synchronizes linuxCNC's servo-thread to the DC reference clock.
Wasn't documented, I ran across it in the source code. Seems to work though, and I am happy to get
that feedback from you.
But I don't want to spread this. I have submitted a Pull Request to the linuxcnc-ethercat that will introduce
an option
syncToRefClock="true|false"
that will both document this and
make it clear that this can be used. Until then, keep using the "-".
  • Ahmed.emara
  • Ahmed.emara
30 Sep 2025 13:30
Replied by Ahmed.emara on topic Sync Problem LinuxCNC + EL8EC400F
Category: EtherCAT
hey hakan
i discovered that i had huge latency problem i solved it with disable some features in BIOS and made core isolation, and then i changed the refclock to -10 and it worked! but i want to understand why it worked with -10
thank you guys for your help!
  • Hakan
  • Hakan
30 Sep 2025 13:28
Leadshine 2CS3E-D507 / Cia402 almost working - help please!
Category: EtherCAT
Comment out this line in the ini file.
#HALFILE = LIB:basic_sim.tcl
Hope it doesn't mean a lot of extra errors but I think it might work.
Then give cia402.0.pos-cmd a value in halshow.
  • dextaca
  • dextaca
30 Sep 2025 13:04
Robot / coBot functions was created by dextaca
Good day Forum
Wondering on possibility of implementing linuxcnc on a Older Motoman robot.
Wondering if the necessary is in place to be able to to hand teach of the robot arm ( cobot style ) logging its trajectory etc.
I think that would catapult Linuxcnc in the cobot world.
ideas?
Thank  you
  • 2tinker
  • 2tinker
30 Sep 2025 11:01
hm2/hm2_7i76e.0: error finishing read! iter=1342204
Category: Deutsch
Hallo zusammen.Nachdem ich ein paar Erfahrungen mit einem ArduinoUno und ESTLCAM gesammelt habe, versuche ich mich jetzt an LinuxCNC und einer MESA 7i76eu. Mit Windows kenne ich mich recht gut aus. Mit Linux leider noch gar nicht, darum bitte ich um Nachsicht!Mein System besteht zur Zeit aus einem i3 mit 4GB RAM und zwei Realtek LAN-Adapter (einer OnBoard, einer als PCIe-Karte); Debian 12 und LinuxCNC 2.9.4.=11.0ptWie bereits an anderer Stelle hier im Forum beschrieben erhalte ich nach einiger Zeit folgende Fehlermeldung: „hm2/hm2_7i76e.0: error finishing read! iter=1342204„
Wie in diesem Thread ( Mesa i76e error finishing read. Another Time with LinuxCNC 2.9.1 ) beschrieben, habe ich ethtool installiert.Das Auslesen der Werte mit „sudo ethtool –c enp1s0“ zeigt, das „rx-usecs“ bereits auf 0 gesetzt ist.
Soweit ich den Thread richtig gelesen habe, sollte diese Einstellung (bis zu eine reboot) die Fehlermeldung unterdrücken/beseitigen.
Auch habe ich in der Maschinen-INI den Parameter „SERVO-PERIOD“ auf 2000000 gesetzt.Vielleicht hat ja jemand eine Idee, woran es liegt, dass dieser Fehler geschmissen wird. =11.0ptDanke im Voraus und Grüße vom tinker.
  • jrc
  • jrc
30 Sep 2025 09:54
Category: EtherCAT
I added them back in and got the same error : HAL: ERROR: function 'motion-command-handler' may only be added to one thread
I think the simple minimal sim config I use as a starting point probably has those somewhere so it's complaining about duplicates
  • ShemJ
  • ShemJ's Avatar
Displaying 13051 - 13065 out of 13392 results.
Time to create page: 0.914 seconds
