19 Aug 2025 18:19
  • AndyUAZ
  • AndyUAZ
19 Aug 2025 18:11
Replied by AndyUAZ on topic Linuxcnc auf 32bit
Linuxcnc auf 32bit
gibt es noch andere alternativen z.b. Raspberry pi4 ?
19 Aug 2025 17:39
Replied by tommylight on topic Linuxcnc auf 32bit
Linuxcnc auf 32bit
Nur die alte versione, das soll tun:
www.linuxcnc.org/iso/ubuntu-10.04-linuxcnc3-i386.iso
Bin ich nicht sicher, aber auch diese soll 32bit sein
www.linuxcnc.org/iso/linuxcnc-2.7.14-wheezy.iso
  • AndyUAZ
  • AndyUAZ
19 Aug 2025 17:30
Linuxcnc auf 32bit was created by AndyUAZ
Linuxcnc auf 32bit
Hallo gibt es eine Möglichkeit das ich linuxcnc auf einen 32bit PC zum laufen bekomme.  Ich bin absolut neu mit Linux und der cnc Bearbeitung. Ich entschuldige mich jetzt schon für meine dummen Fragen
Mfg Andy
  • Lcvette
  • Lcvette's Avatar
19 Aug 2025 15:56
Replied by Lcvette on topic Carousel ATC setup on Probe Basic
Category: QtPyVCP
Sorry, joco mentioned you had a deb file he had built that was on your google drive you hosted
  • ihavenofish
  • ihavenofish
19 Aug 2025 15:34
Replied by ihavenofish on topic Mini wannabe datron build
Category: CNC Machines
Blue part was I think $86cdn. The grippers were $25cdn each. Now that I have it in hand and see what they did, I can see some things I can change that should make it a little cheaper.
For example If you model impossible chamfers someone will hand file them right to the edge. We don't need none of that silliness. So I guess I need to either model accurately, or make a note "only cnc the chamfers as close as is reasonable"
Ove time I will bring all the small parts in house, but its pretty cool that i can affordably do one offs to start.
  • Rookie0
  • Rookie0
19 Aug 2025 15:29
Replied by Rookie0 on topic SOLVED - LS L7N Servo drives
Category: EtherCAT
1. make sure all ecat servos are OP+ status before you run any move action in lcnc.
by run "ethercat sl" cmd in terminal.
2. a working ecat servo which is in CSP mode, it's cia-controlword should be 15 (4>6>7>15).
if yours is not, check statusword,  there must be someone bit in wrong.
you can use halshow panel, get value of statusword pin, and convert to binary, check every status bit with servo instruction manual.
  • Murphy
  • Murphy
19 Aug 2025 15:24 - 19 Aug 2025 15:26
I have my Denford Triac PC running on remora and an EC500 , DM556t drivers, Probe Basic UI.Amazon cheap 23" touch screen.
I'll post my ini and hal later in the week if anyone is looking to do the same.
19 Aug 2025 15:04
Replied by tommylight on topic Stepper motors running rough after re install
Category: Basic Configuration
Z420 ? i still have one in use daily, had over 20 and they are very good for small NAS or local server, or crypto mining as they come with a 700W power supply... I know, i used them for mining for several years.
Back on topic:
1. does your Z420 have the water cooler or the normal offset mounted air cooler?
2. does it still have the original NVIDIA QUADRO graphic card?
For 1 they tend to fail, but very, very rarely, so far only 1 failed.
For 2 see if you can find an AMD graphic card, might work perfectly well with 2.9 as the PC has good latency overall.
  • emresensoy
  • emresensoy
19 Aug 2025 15:01
SOLVED - LS L7N Servo drives was created by emresensoy
Category: EtherCAT
Hi there,I need help with something.
The L7N series servo motors work fine with the settings in the l7npos.xml and l7npos.hal files.
But I want to use them with cia402.comp. I've configured the settings in the attached "l7npos_cia402.xml" and "l7npos_cia402.hal" files, but the motors aren't working. They're stay in the "Enabled" state.
What do you think I did wrong?
19 Aug 2025 14:55
Replied by tommylight on topic Compleatly off line Voron image possible ?
Category: Additive Manufacturing
I have no bad info on CloadFlare so far, hope they continue.
Just keep in mind that all your traffic goes through them, so they know what your watching... :)
  • Hartwig
  • Hartwig
19 Aug 2025 14:50
New member from Germany - CNC retrofit of a Leinen FM1
Hi Andy,
yes, he has.
Thanks a lot and best regards
Hartwig
19 Aug 2025 14:45
Replied by tommylight on topic ARE YOU KIDDING ME YOUTUBE !!!
8.7 TB free here.
You should be able to install a gitlab at home too. docs.gitlab.com/install/docker/ then you could clone what you want into your trpo
I am just now building a 56TB NAS, but not for me.
Also, i never use Docker nor any other ProxMox, Jellyfin, VM, etc.
I use bare metal for everything, and even that as simple as possible.
The security concerns win always with me.
  • Hakan
  • Hakan
19 Aug 2025 14:28
Replied by Hakan on topic ARE YOU KIDDING ME YOUTUBE !!!
I wonder if ads are connected to monetisation. I think youtube puts in ads "always".
It's just you get a share of the income. When I was active I got around 100 bucks every three months.
In the end I ran out of subjects and appreciated being without the constant chase for content.
Nice experience, nice to be without.
  • andypugh
  • andypugh's Avatar
19 Aug 2025 13:56
Replied by andypugh on topic ARE YOU KIDDING ME YOUTUBE !!!
I have looked into monetisation, but it looks like my lifetime earnings would have been about $25 over the last 15 years, and I prefer not to annoy my subscribers with adverts.
Displaying 13486 - 13500 out of 14150 results.
Time to create page: 0.353 seconds
