  • Hakan
  • Hakan
13 Nov 2026 09:10
Replied by Hakan on topic New experimental ethercat layer
Category: EtherCAT
So EL6021 is a ... how does that work? serial over EtherCAT or what?
No that's not supported now. It can be, biggest hinder is I don't have one to test with.
This one is so different that tests are needed. There must be direct support in ecat.so for terminal access.
A bit the same as with EoE devices, there is a clear way how to support that. But need a device to test with.
Actually ESI files are supported.
Get all ESI files downloaded from Beckhoff foor example, point to the directory (see at bottom of this figure) and rescan the bus.
not.N is there, to the right.The Invert
Maybe not general enough. Maybe one should add a type not-bool as an invers to boolean. Ideas?
13 Nov 2026 06:55
Ich möchte für das Forum-Upgrade spenden – aber wie?
Category: Deutsch
Danke Muecke,
There might be opportunities to help later on, thank you very much for your continued support.
  • Kittifix
  • Kittifix
13 Nov 2026 06:49
Replied by Kittifix on topic New experimental ethercat layer
Category: EtherCAT
Thank you for your work, it's fun to experiment with it! I'm playing around with a mini milling machine. All I need now is a VFD for EtherCAT, as the EL6021 doesn't seem to be supported yet. I'll try that out when the function with the ESI files is implemented. But I have one more question: is there a way to output it inverted, except via " not.N "?
  • Dudelbert
  • Dudelbert
13 Nov 2026 06:35
Replied by Dudelbert on topic I Made a CAM Program for My Lathe (AI Made It)*
Category: CAD CAM
I just hope it will be useful. Let me know what you think after you've tried it.
  • Hakan
  • Hakan
13 Nov 2026 05:41
Category: EtherCAT
I've made a new release after working through all steps to bring a
config from linuxcnc simulator into operation with EtherCAT drives,
IO and encoder. I run it myself on a plasma cutter and a lathe.
I could try to write how great is is, but just try for yourself.
github.com/MetalMusings/ecat for releases, now only 2.10.
Unfortunately you may to build it yourself since there is no released 2.10 to rely on.
I can back-port it to 2.9 and make a deb package if more than one person wants it
Development has been at the speed of light,but it's slowing down now.
The tools feel somewhat useful so development will be more on my own usage, try use cases.
  • grandixximo
  • grandixximo's Avatar
13 Nov 2026 05:25
Replied by grandixximo on topic task: main loop took
I also have almost just as many on my machine, but everything works fine, but mine are just about 0.01xxx I do not have 0.02xx or 0.03xx
  • Muecke
  • Muecke's Avatar
13 Nov 2026 05:17 - 13 Nov 2026 05:19
Category: Deutsch
Hallo zusammen,
ich habe den Beitrag Forum upgrade Fund Rave gelesen und würde mich gerne mit einer Spende beteiligen.
Leider ist die Spendenannahme bei GoFundMe inzwischen ausgesetzt.
Ich gehöre zu den Nutzern, die viel Hilfe benötigen, häufig im Forum nachlesen und immer wieder auf die Unterstützung der Community angewiesen sind.
Gleichzeitig gehöre ich aber auch zu denen, die sich in der Vergangenheit über Probleme mit dem Forum beschwert und immer wieder darauf gedrängt haben, dass endlich etwas verbessert wird. ;-)
Deshalb fände ich es nur fair, wenn ich mich jetzt auch finanziell an der Verbesserung beteilige!
Mir ist bewusst, dass das ursprüngliche Spendenziel bereits erreicht wurde. Wenn meine Spende aber dem Forum oder dem LinuxCNC-Projekt insgesamt zugutekommt, möchte ich trotzdem gerne etwas beitragen.
Gibt es noch eine Möglichkeit zu spenden?
Im ursprünglichen Spendenaufruf kann ich leider nicht antworten, da dieser Bereich offenbar den Administratoren vorbehalten ist.
Vielen Dank und viele Grüße
Mücke
  • dberegovoy
  • dberegovoy
13 Nov 2026 04:25
Lathe Spindle Encoder: What are the options for EtherCAT?
Category: EtherCAT
I was curious to see if I could switch operation modes on the fly (between Position and Velocity) with my Omron EtherCAT servo drive.
Initially, I started out using the standard cia402 HAL component written by Dominik (dbraun1981). It is a great and very convenient component to get up and running quickly. However, the operation mode (csp or csv) is configured as a parameter when the component is loaded and cannot be dynamically changed during runtime.
So, as an experiment, I decided to bypass the cia402 component and test direct, low-level control using only the lcec driver. I wrote a custom XML configuration mapping the required raw PDOs (0x6040 Controlword, 0x6060 Modes of Operation, 0x607A Target Position, 0x60FF Target Velocity, and feedback objects) directly to HAL pins.
I loaded the setup using halrun -I -f and manually controlled the state machine and switched modes via halcmd—and it worked!
In short, the test sequence was:
1. Enable the drive manually via Controlword (6 -> 7 -> 15) and test movement in CSP mode (8).
2. Zero out the velocity setpoint and switch 0x6060 (opmode) on the fly to CSV mode (9), spin the motor, and bring it back to a stop.
3. Read the current actual-pos (0x6064), write that exact value into target-pos (0x607A) for a bumpless transition without any sudden jumps, and switch opmode back to CSP (8).
I have attached a text file containing the full terminal log (halcmd session), along with the omron_direct.xml and direct_test.hal configurations, in case anyone wants to test or reference this setup.
Hope this helps anyone exploring dynamic mode switching or learning how CiA 402 works under the hood!
File Name: lcec_direc...hing.txt
File Size:4 KB
  • anfänger
  • anfänger's Avatar
13 Nov 2026 04:09
Replied by anfänger on topic I Made a CAM Program for My Lathe (AI Made It)*
Category: CAD CAM
Nice, thanks for sharing. I am definitevly going to check it out.
12 Nov 2026 19:27
PancakeSlicer, a Self-hostable and Non-planar 3D Printer Slicer on OrcaSlicer en
Category: Additive Manufacturing
NOT my stuff!!!
Bumped into this, a Self-hostable and Non-planar 3D Printer Slicer built on the Orca Slicer engine, see the video and github for more info.
github.com/zimengxiong/pancakeslicer
  • PCW
  • PCW's Avatar
12 Nov 2026 17:40
  • Dudelbert
  • Dudelbert
12 Nov 2026 15:35
Category: CAD CAM
I'm not, as Tommy said, we can talk here. What is it about?
  • HolmHansen
  • HolmHansen
12 Nov 2026 13:38 - 12 Nov 2026 14:17
CNC Fräse: Umstieg von Windows/Arduino/Estlcam zu LinuxCNC/Mesa 7196S
Category: Deutsch
Hallo tinker,
ja ich werde versuchen meine Forschritte zu dokumentieren.
Ich hatte mir damals das Endchen angesehen, aber mich dann doch für die andere Maschine entschieden.
Welche GUI es wird steht nun fest -> qtdragon_hd.
Hab mich da mal in der Sim etwas reingefuchst und auch schon mein erstes python Script gebastelt, das mir die bisher gewohnte Funktionalität des Jog-Kreuzes aus Estlcam gibt. Ich weis nicht ob du das kennst, da werden 8 Pfeile für X und Y angezeigt, die aus 5 Segmenten bestehen und tippt oder klickt man rein kann man ohne loszulassen schneller oder langsamer jog ausführen. Vor allem geht so X und Y gleichzeitig.
Gleiches Verhalten mit Z wie in Estlcam - ich finde das super intuitiv.
Im dritten Bild sieht man das der Pfeil nach unten rechts gedrückt ist und wir uns bei 60% befinden für X und Y.
Ein Button (ganz oben) regelt, ob man das 5 Segment Jog nutzen will (100%, 80%, 60%, 40% und 20%) oder ob man die Einstellungen aus dem Standard Jog nehmen will, dann wird die Oberfläche auch umgeschaltet. Klappt wie gesagt 1a, ich muss das noch umsetzen und verdrahten.
In ein paar Tagen gehts weiter, die Bilder zeigen was ich meine ...
  • HolmHansen
  • HolmHansen
12 Nov 2026 13:26
Category: Deutsch
Yeah, that's exactly what my electrician told me, too! We did everything we could, and it got better, but it just never went away completely.
That's why we did the upgrade and switched to the Mesa 7i96S and LinuxCNC.
  • tuxcnc
  • tuxcnc
12 Nov 2026 13:05
Category: Deutsch
Erdung wo es nur geht
According to Murphy’s Law, a safety measure can itself be the cause of a failure.
I struggled for a long time with interference from a VFD; I tested several models, rerouted cables in various ways, connected shields at different points—but nothing helped. Bizarre things were happening: the monitor would shut off, and the machine became completely unusable.
Then, quite by accident, I left the VFD’s ground connection disconnected—and ever since, everything has been working perfectly...
Of course, it never hurts to use noise filters or opto-isolated USB-to-RS485 converters.
As for LinuxCNC configuration, I always recommend finding a setup for a similar machine and making the necessary adjustments using a text editor. It really isn’t difficult.
Displaying 136 - 150 out of 11274 results.
Time to create page: 0.616 seconds
