  • juergen-home
  • juergen-home
14 Aug 2025 12:42 - 14 Aug 2025 12:54
Replied by juergen-home on topic "pwm/dir" (Out1) switches for spindle CCW
Category: Basic Configuration
Question about  Connect Mesa 6i25 HDR26 with 7I52S HDR50 moved to
forum.linuxcnc.org/49-basic-configuratio...h-7i52s-hdr50#333411
  • rodw
  • rodw's Avatar
14 Aug 2025 12:39
Replied by rodw on topic multiple estops on separate pins
Drive alarms should be wired to joint.n.amp-fault in hal, not to e-stop,
Yes as I said. Much cleaner to maintain
  • rodw
  • rodw's Avatar
14 Aug 2025 12:37
Replied by rodw on topic Search for Google document from rodw
What was the doc pertaining to? Maybe the information can be found elsewhere?
Its really the only complete guide to installing and optimising Debian Trixie to get a reliable machine with Mesa cards and ethercat.
Because we never had an ISO for Bullseye, nobody had any idea of the kernel changes that impacted on reliable machine operation from about kernel 5.10 and on until Bookworm came along. I did get this into the getting linuxcnc docs but it was discarded with the release of 2.9 by people who had no idea. I'm not redoing it. When I looked at how I could host the info today, making it a downloadable ptoduct on my home network seemed to be the best option. But there is a cost. Feel free to gather the info and make your own version and or add it to linuxcnc docs (which don't cover Trixie). Somebody offered to donate USD $300 for this info so it has value to some people. Surely $1.30 USD is not to much to ask me and almost half will go in fees.
14 Aug 2025 12:27
Replied by tommylight on topic multiple estops on separate pins
  • Todd Zuercher
  • Todd Zuercher's Avatar
14 Aug 2025 12:22
Replied by Todd Zuercher on topic multiple estops on separate pins
You can use logic components such as and2 to connect multiple signals to one. But I'm not sure I see the advantage of doing so with an e-stop. Generally an e-stop loop is all in hardware, and the e-stop input to Linuxcnc is merely to inform it of the loop's state.
  • buyroomty
  • buyroomty's Avatar
14 Aug 2025 12:17
Replied by buyroomty on topic Opencamlib manual
Opencamlib manual
Category: CAD CAM
I could use this PDF manual too - if it even exists, of course.
  • Todd Zuercher
14 Aug 2025 12:13
Replied by Todd Zuercher on topic Search for Google document from rodw
  • rodw
  • rodw's Avatar
14 Aug 2025 12:04
Storing the most extreme dimensions found on preview
Category: AXIS
Linuxcnc allows you to create a Python filter that processes the Gcode when the file is opened, Not sure how qtplasmac does it.
  • rodw
  • rodw's Avatar
14 Aug 2025 11:59
Yes, sorry its gone. I'm working on a similar document for Trixie. Its still a draft but its here
erpx.au/shop/trixie-linuxcnc-debian-trix...tion-pdf-download-48
There is a small charge for it AUD $2 to cover costs. That really only covers the payment processing costs. I will send final versions once its complete to anybody that buys it while its in draft.
Its hot off the presses as I just wrote it today. Any feedback will be appreciated.
  • browsem
  • browsem
14 Aug 2025 11:50
Replied by browsem on topic New update on STMBL
New update on STMBL
Category: Driver Boards
i have an Old Abb irb2000 thats just sitting there, that i want to revieve.
it seems that this could be a way forward.
What kind of setup are you using for the rest of the control chain ?
  • rodw
  • rodw's Avatar
14 Aug 2025 11:50
estop-latch is the right way to go  with these but a better way is to use joint.N.amp-fault-in IN BIT   Should be driven TRUE if an external fault is detected with the amplifier for this joint.
ref: linuxcnc.org/docs/stable/html/man/man9/motion.9.html
This will halt motion.
Your drives may also have a estop input which disables the drive on an estop.
  • Todd Zuercher
14 Aug 2025 11:48
  • JT
  • JT's Avatar
14 Aug 2025 11:40
Replied by JT on topic multiple estops on separate pins
There's a couple of ways, you could use the Mesa Configuration Tool or you can add the estop_latch component yourself.
JT
  • Jonathan_H
  • Jonathan_H
14 Aug 2025 10:32
System hangs repeatedly with certain combinations of operations
I'm not with the machine right now, so cannot run any tests (perhaps later today) but looking at the various hal state dumps I posted previously, spindle-at-speed seems to be showing false all the time, whether the next move works or not.
It does look like I need to check spindle-at-speed, but it doesn't seem like it is the deciding variable (at least not on its own)
  • LeonDolnicar
  • LeonDolnicar
14 Aug 2025 09:59
multiple estops on separate pins was created by LeonDolnicar
Hello,
I am running a thre axis CNC mill with stepper motors with mesa 7i76eu. I wanted to connect stepper driver alarm outputs to mesa and have them triger emergency stop. I am also planning on adding two additional Estop buttons. I wired them up but then noticed that linuxCNC setup wizard only lets me select one output as emergency stop. Is there a way I can select multiple inputs as emergency stop, or do I have to wire the buttons in parallel and connect them to one input.
Displaying 13741 - 13755 out of 14149 results.
Time to create page: 0.378 seconds
