  • PCW
  • PCW's Avatar
02 Jul 2025 03:02
Replied by PCW on topic Servo Driver Plasma Retrofit
Category: Plasmac
It looks like you connect drive-enable-in to drive-enable-out
to enable the drive. This means the 7I97T's enable outputs
may work, but you would need to determine the polarity,
open circuit voltage, and closed circuit current. These can all be
measured with a DVM.
  • kn612
  • kn612
02 Jul 2025 02:28 - 02 Jul 2025 02:53
Replied by kn612 on topic Servo Driver Plasma Retrofit
Category: Plasmac
Here is a more detailed wiring pin out for the hypertherm controller.  However I haven't found anything about if they are activated by a positive voltage or a ground.  This chart says relay contact closure.  With that said, would I be able to just enable the drives with an external switch and relay?
  • MrTejuino
  • MrTejuino
02 Jul 2025 00:29 - 02 Jul 2025 00:31
Replied by MrTejuino on topic Setting a Scara
Setting a Scara
File Name: remora4Scara.rar
File Size:9 KB
these is working right now but it works strange, in joint mode all the joint are great the j0=x(from the board), j1=y(from the board), j2=z(from the board) and j3=A(from the board) but when i home the robot, the motor j1 and the j3 change and i dont know how to change it, i think my hal is wired kind of well, but i dont know how to correct these, i tried to used a personalized kins but i get a lot of errors.
  • cmorley
  • cmorley
01 Jul 2025 21:55
Replied by cmorley on topic Import pin value in handler.py
Category: Qtvcp
if the pin value you wish to read is not created in the qtvcp handler then you must either connect to the pin or read it directly.
to read it directly:
pwmValue = self.h.hal.get_value('pwmgen.0.value')
use the full HAL name.
Otherwise you must make a qtdragon pin and connected it in a HAL file to the pwmgen pin.
Hopefully that helps.
  • PCW
  • PCW's Avatar
01 Jul 2025 20:39
Replied by PCW on topic Configuración thcad2 con mesa 7i96s
If you use pncconf, it should setup the THCAD stuff for you.
This needs the QTPlasmaC GUI:
The encoder option to be "Arc Voltage"
Then you will get the THCAD setup page:
  • TMinj
  • TMinj
01 Jul 2025 20:06 - 01 Jul 2025 20:10
Import pin value in handler.py was created by TMinj
Category: Qtvcp
Hello,
I'm still fairly new to LinuxCNC and QTVCP. I'm trying to modify the QTDragon GUI.
I added a status label and a progress bar using Qt5.
In handler.py, I added the following lines, and I can display the value:
- self.w.OilPumpPositionGage.setValue(int(multiplied_pwm_value))
- self.w.OilPumpPositionValue.setText(f"{multiplied_pwm_value:.2f} %")
My issue is that I would like multiplied_pwm_value = pwmgen.0.value * 100 but I can't figure out how to access the "pmw.0.value" value from handler.py
I tried working with the "newpin" function, but it's not working.
Where can I find information on how to do this, or could someone point me in the right direction?Thanks in advance
  • Johnnysacalu
  • Johnnysacalu
01 Jul 2025 19:51
Configuración thcad2 con mesa 7i96s was created by Johnnysacalu
Hola estoy intentando ya más de una semana configurar el thc y no soy capas “bueno tampoco entiendo de esto” hay algunas configuraciones que se pueden copiar ya lo mejor corregir algunas cosas. Por que configura algo y rompo otra cosa y así.
si hace falta dejo los archivos.hal y .ini o lo que haga falta
01 Jul 2025 19:36
Replied by tommylight on topic Bios error during lcnc start
Try disabling secure boot and TPM in BIOS.
  • PCW
  • PCW's Avatar
01 Jul 2025 19:33
Replied by PCW on topic Bios error during lcnc start
Hard to tell, it might be a connection issue causing a parity error
in that slot or some unknown incompatibility.
Does lspci show the card?
lspci | grep 2718
  • ALS
  • ALS
01 Jul 2025 19:26
Keyboard Functions was created by ALS
Keyboard Functions
Category: AXIS
Hello, how are you?
I would like to know if it is possible to change the functions of the alphanumeric keyboard to functions customized by me.
For example: by default, the F2 key turns on the machine. Can I change it to any other function?
Tanks
  • workshop54
  • workshop54
01 Jul 2025 19:15
Wait for spindle-halt signal before reversing spindle direction
Category: Basic Configuration
In that case it seems like writing a custom component is the best choice.
I'm just getting into writing custom realtime components, so this might be a nice exersize.
I can post the link here when I'm done with it if you guys are interested.
  • GDTH
  • GDTH's Avatar
01 Jul 2025 18:37 - 08 Jul 2025 17:36
Bios error during lcnc start was created by GDTH
He.
I have a 5i25 in a HP workstation.
The computer works fine until I want start lcnc. It reboots and gives this error tlp poisend on pci slot.
Does anyone have any idea what is going on?
I did have some difficulty getting the card in.
photos.app.goo.gl/Vi21HjgVt7QMj1yf9
photos.app.goo.gl/Nu3xv5JSHQanxng99
  • PCW
  • PCW's Avatar
01 Jul 2025 18:24
homing with Phase Z encoder on MESA 7i96s
OK, that's probably to be expected since there does not seem to be any B axis home switch
and you have setup a homing scheme that requires that switch.
If you don't have a home switch on B, and you want to home to index, you need to setup
Index-only homing:
linuxcnc.org/docs/html/config/ini-homing.html#_configuration
  • JackRay
  • JackRay
01 Jul 2025 17:07
Replied by JackRay on topic homing with Phase Z encoder on MESA 7i96s
my configuration works very well on the x,y,z axes with on/off switches. homming is all done at the same time without any problem. the problem is only on this rotary axis where i have an encoder with which i want to use the Z phase to do my homing.
  • PCW
  • PCW's Avatar
01 Jul 2025 16:17
Do you have a spindle encoder?
(it might be a bit easier in hal knowing the velocity)
Also maybe this could be done in the g code with
m5 m66
Displaying 14401 - 14415 out of 15148 results.
Time to create page: 1.034 seconds
