  • MueTho
  • MueTho's Avatar
16 Oct 2026 10:16 - 16 Oct 2026 17:43
7i96S custom bitfile: 4x PktUART V3 on P1 (3x Modbus + 1 full-duplex link) + St
Category: Driver Boards
Hi Peter,
I am building a small 3.5-axis mill/drill with a 7i96S and five STEPPERONLINE A6-RS servo drives (step/dir + Modbus RTU). Current setup: LinuxCNC 2.9.10 uspace on Debian 13 (PREEMPT_RT), 7i96s_pktv3.bin flashed. hm2_modbus to one A6 on TB2 works without errors (115200 8N1, rxdelay 40 / txdelay 45 / icdelay 20, about 7 ms per single-register read at 1 ms servo period).
I would like to ask for a custom bitfile with the following configuration.
TB2 and all on-board I/O: identical to 7i96s_pktv3
- StepGen 0-4 (X, Y, Z, W, spindle), QCount 0 with index (spindle), PktUART V3 on TB2 with internal TXEn, SSR, OutM, InM, PWM unchanged.
P1 (W6 set to GND, a small interface board sits directly at the header):
P1 pin | IO   | Function                         | Instance
1      | IO34 | StepGen Step                     | StepGen 5
2      | IO35 | StepGen Dir                      | StepGen 5
3      | IO36 | GPIO                             | -
4      | IO37 | QCount A                         | QCount 1
5      | IO38 | QCount B                         | QCount 1
6      | IO39 | QCount Index                     | QCount 1
7      | IO40 | GPIO                             | -
8      | IO41 | GPIO                             | -
9      | IO42 | GPIO                             | -
11     | IO43 | PktUART TX (Modbus, Z drive)     | PktUART 1
13     | IO44 | PktUART RX (Modbus, Z drive)     | PktUART 1
15     | IO45 | PktUART TX (Modbus, spindle)     | PktUART 2
17     | IO46 | PktUART RX (Modbus, spindle)     | PktUART 2
19     | IO47 | PktUART TX (lever link)          | PktUART 3
21     | IO48 | PktUART RX (lever link)          | PktUART 3
23     | IO49 | PktUART TX (Modbus, spare)       | PktUART 4
25     | IO50 | PktUART RX (Modbus, spare)       | PktUART 4
Notes:
- All PktUARTs V3. No TX enable pins on P1: the three Modbus ports use RS-485 transceivers with automatic direction control (e.g. MAX13487E); the lever link (PktUART 3) is full-duplex RS-422 with the driver permanently enabled, 2-5 Mbit, one packet per servo period in each direction.
- Instance numbering as in the table, please: PktUART 0 stays on TB2 (so existing configs keep working), StepGen 5 and QCount 1 are the highest instances, so I can turn them into GPIO with num_stepgens=5 / num_encoders=1 when they are not needed.
- If it does not all fit into the T20, please drop in this order: QCount 1 first, then PktUART 4, then StepGen 5. PktUARTs 1-3 are the ones I really need.
Questions:
1. Does this fit (5 PktUART V3 in total, 6 StepGens, 2 QCounts)?
2. hm2_modbus without a TX enable pin: is the receiver masked while we transmit (RXMASK driven by the internal drive enable), or should the transceiver's receiver be disabled during TX to avoid the echo?
3. Lever link: for full-duplex use I plan to set the drive enable bit statically and the auto bit off in my own HAL component. Is that the right way with PktUART V3, or would you configure it differently?
4. Is the 7I87 expected to be available again?
If it is easier for you, I can also build it myself with Efinity from the 7i96s sources - in that case a hint which PIN file to start from (PIN_7I96SD_PKTV3?) would be much appreciated.
Thank you very much for your support,
Thorsten
  • NWE
  • NWE's Avatar
16 Oct 2026 03:42
Usefull Open Source software, vibe coded in Rust
Same here. When I was new on Github I thought I could fork a project to my account to archive it. Nope one day I came back and discovered my unchanged fork had vanished along with the original author's interesting project.
Now it is:
cd into my NAS
git clone
  • paulmag
  • paulmag's Avatar
15 Oct 2026 20:47
Axis interface and "useful" conversational scripts in python
Category: AXIS
I got interested in them as they are an easier option for straight forward machining rather than having to go onto my other pc in my office as i dont connect machines to my network and having to create toolpaths then load them in and if i want a change to go through a mess of work scripts i discovered are great within minutes toolpath made and loaded .
  • concorde
  • concorde
15 Oct 2026 17:17
Replied by concorde on topic JMC Servo Drive Bricked!
I managed to fix the issue. The diagnostics software kept reporting the AF_610 and also AF_620 faults (encoder related faults), but the reason was it could not communicate with the encoder due to a bunch of random parameters set during the failed write/download from the diagnostics software.
However these parameters are locked out to users. However you can activate a "super user" level with code "jmc2018". This will allow you to alter the necessary P00 parameters.
  • yaska
  • yaska
15 Oct 2026 13:58
Replied by yaska on topic Z-axis doesn’t move
Z-axis doesn’t move
Category: Flex GUI
Here are the files you asked for
On a lathe, the Z-axis is No. 2, and on a mill, it’s No. 3. I think that’s where the problem comes from—previously, I had to have two Z- and two Z+ buttons; on one pair, I used jog_1_pb,
and on the other, I used jog_2_pb, which I used when the axes were homed, and it worked. When the axes weren’t homed, I had to use jog_pb_1 to move the axis.
So why does it work normally in Probe Basic but not in Flex GUI?
  • Hermle_Gerald
  • Hermle_Gerald
15 Oct 2026 13:02
Replied by Hermle_Gerald on topic Hermle auswahl Mesa Karten
Category: Deutsch
Ich denke die Kiste wird nie Geld verdienen. Beruflich arbeite ich auf einer CNC Fräsmaschine. Warum man dann zuhause noch so ein Teil braucht. Keinen Ahnung was ich mir damals gedacht habe. Ich besitzt eine würde sagen gut ausgestattete Werkstatt. Und da fehlt einfach noch eine cnc Fräse.
Die 7i96s hat nicht gerade sehr viele ein/ausgänge.
Währe daher nicht eine 7i76eu besser. Diese besetzt 48 Ein bzw Ausgänge. Hat 5 Anschlüsse für die Servomotoren. 1 Stück TTL oder Encoder Eingang.
Dazu noch eine 7i85s um die Encoder um 4 Stück zu erweitern. So könnte ich die Encoder von den Servos an die Mesa anschließen. Oder eben alternativ die Glasmaßstäbe mit einem TTL Signal.
In der Anleitung habe ich die Encoder Anschlüsse gefunden.
Anschluss CN1:
21 OA+ Encoder A-phase positive output
22 OA- Encoder A-phase negative output
23 OB- Encoder B phase negative output
24 OZ- Encoder Z-phase negative output
25 OB+ Encoder B-phase positive output
Die Step + Step - / Dir + Dir - Anschüsse suche ich noch immer?
Was haltet Ihr davon?
  • bassti
  • bassti
15 Oct 2026 10:46
Replied by bassti on topic Hermle auswahl Mesa Karten
Category: Deutsch
Also dann wäre das ziel erstmal da die kiste etwas geld verdient?
bis auf die Mesakarte hast du ja alles liegen - nimm eine 7i96S und steuer die Endstufen mit step dir an .. wenn du dann später feststellst das das nicht genau genug ist (was ich nicht glaube) würde ich nicht die glaßmasstäbe auslesen sondern eine andere mechanik in betracht ziehen ...
Das wäre dann ein relativ einfach aufzusetzendes setup und du musst nicht so viel zeit in verkabelung investieren. kannst du dann später noch machen wenn du lieber retrofits machst als zu fräsen ;)
gruß bassti
  • Hermle_Gerald
  • Hermle_Gerald
15 Oct 2026 08:42
Category: Deutsch
Vielen Danke für die Unterstützung!
Die Heidenhain Glasmaßstäbe sind noch original. So richtig konnte ich mich damit bis jetzt nicht anfreunden. Keine Led sondern noch Glühbirne zum Abtasten. Schlechte Lagerung. Laut der Firma Singer ist die Qualität dennoch sehr gut. Deshalb habe ich beschlossen sie Instand zu setzten. Kabel getauscht, Dichtlippen erneuert und komplett gereinigt. Getestet Funktion ist einwandfrei.
Ich dachte man kann die Problemlos an die Mesa anschließen. Ein Konverter ist mir zu teuer.
Deshalb würde ich vorerst die Glasmaßstäbe weglassen und nicht anschließen. Eventuell später die Heidenhain durch China Model mit TTL Ausgang tauschen.
Mein ursprünglicher Plan vor ca 3 Jahre als ich die Antriebe gekauft habe. Diese wie im dem Video vom Taller83 an eine 7i76 anzuschließen.
Das ist ebenfalls ein ein JMC Servo allerdings mit 24v. Dieser wird mit 4 Leitungen an die Step/Dir Ausgänge der Mesa angeschlossen.
Handelt es sich dabei um eine Closed loop Verbindung?
So ganz habe ich das noch nicht verstanden. Der Servomotor hat einen Encoder. Dieser wird vom Servoregler ausgewertet. Sollten die Encoderdaten an die Mesa weiter gegeben werden?
Das würde bedeuten ich bräuchte eine Karte mit 6x Encoder Eingang. Drei Stück für die Servo Encoder.  Drei Stück später für die Glasmaßstäbe TTL Eingang.
Das ist die Anleitung von den Servos:
www.jmc-motor.com/uploads/20240730/163ce...315f4288926ae918.pdf
Die Maschine hatte original nur einen Servomotor. Die Achsen wurde mit Magnetkupplung angesteuert. Das habe ich alles rausgeworfen. Umbau auf Kugelumlaufspindel inkl. drei Servomotoren.
Bezüglich der Mesa Karten spielt das Geld schon eine Rolle. Die Maschine sollte sauber und störungsfrei laufen. Bis jetzt hat sie schon genug Geld vernichtet.
  • anfänger
  • anfänger's Avatar
15 Oct 2026 08:19
Replied by anfänger on topic Barnworks shop update
Category: Show Your Stuff
No fire (and much heavier water) damages we found at the beams in the main house.
15 Oct 2026 07:22
Replied by tommylight on topic Barnworks shop update
That was very low on my list of possible explanations, first was fire, then diesel heater, then open firepit...
  • anfänger
  • anfänger's Avatar
15 Oct 2026 06:53
Replied by anfänger on topic Lathe Chuck Table
Lathe Chuck Table
Category: QtPyVCP
I hope this way it might help someone if he wants the same feature. Or improve it.
I think it might be interesting to see what other have as cutom features, so one knows whats possible and might be handy.
  • anfänger
  • anfänger's Avatar
15 Oct 2026 06:42
This was an old cow stable, the ceiling is blackened by the diesel exhaust from the Traktor
15 Oct 2026 05:37
Replied by tommylight on topic Usefull Open Source software, vibe coded in Rust
Archived, thank you.
Several years back i built a NAS, so now i just dump stuff into it, hence the "archived".
15 Oct 2026 05:33
Replied by tommylight on topic can we use servo motors in linux cnc
Nothing ?!?!
Well, just ion case, you can even control servos through parallel port, with a simple H-bridge drive and encoders directly wired to parallel port, as can be seen here:
and with Mesa.
15 Oct 2026 05:19
Mesa Ethernet / QtPlasmaC retrofit experience — lessons from a marginal mini PC
I've always had good luck with used PC's for LinuxCNC, mainly because i always use the "Enterprise" versions from Dell, HP, Lenovo, and Fujitsu.
Same with Mesa, i am sure i have Intel and RealTek network cards in use, none had any issues, ever.
Then again, i have several USB to LAN adapters that work fine with Mesa, Laptops and tablets that work fine with Mesa, etc, etc.
I would roughly say i had about 0.5% rate of not working/not usable PC's, and 30% rate of not usable laptops.
Displaying 151 - 165 out of 12320 results.
Time to create page: 0.282 seconds
