  • rubes
  • rubes
12 Aug 2026 17:21
Gui message while homing with shared home/limit swiches
Category: Qtvcp
thanx, but I already had a working solution to my "problem" so didnt actually need your help by that time. I guess i am obviously an idiot because i didn't fall all over myself thanking you, and using your solution rather than the one i worked hard at figuring out while not knowing anything about HAL or Linuxcnc.
  • Holzwurm56
  • Holzwurm56
12 Aug 2026 14:39
Replied by Holzwurm56 on topic Frage zu 7I96?
Frage zu 7I96?
Category: Deutsch
Hallo,
wenn man LCNC startet kommt eine Auswahl von Maschinenkonfigurationen? Da ist nur die 7I96s, aber ich habe die 7I96 in
pncconf gefunden.
  • meister
  • meister
12 Aug 2026 14:38
Sometimes it can be an advantage to be a bit lazy :)
Otherwise, I wouldn’t have been able to reproduce it.
At first, I had the driver connected directly to the TangNano9k (3.3V),
then I had a quick Google to see if anyone else was having problems with the DM542. Yes, they were, because of the 3.3V. Now I’ve connected it to the Tangoboard with 5V signals and everything’s working perfectly, with the default settings
www.youtube.com/shorts/3IeqAu58WdI
  • meister
  • meister
12 Aug 2026 14:10
@viewsat
Wow, OK, I can picture it – that’s intense
Even at low speed – wtf
  • saxa
  • saxa
12 Aug 2026 11:53
Gantry oxyfuel / plasma type machine from scratch
I was wondering if I should buy direclty the 7i95T as it has all needed i/o and encoder feedbacks for up to 6 axis.
What you suggest ?
Yes, that would be better, but finding it sometimes not easy,
With Mesa, you can add inputs and outputs and PWM and encoder feedback as you see fit:
-more IO = 7i84 or 7i70 or 7i71 or 7i72
-more encoders = 7i85 or 7i85S (not the same, only half the same)
-more PWm for +-10V servos = 7i83
Many thanks, will take a closer look to those.
  • saxa
  • saxa
12 Aug 2026 11:50 - 12 Aug 2026 11:52
For such a large machine upgrading from the 7i96s would be a smart move as io is limited (but you can add extra boards). eg. Depending on your needs 7i76eu, 7i95t, 7i97t.
Ok, I was just thinking that buying it once for the complete machine would be easier and more clean instead of adding the various boards per needs. Also because time sometimes makes obsolete something and its difficult to
find later.
Note that if you do fall back to ethercat, with beckhoff, you just need to add an extra input or output module at any time as required at a cost of about $50 for another 8 ports.
In fact the initial idea of going with EtherCAT was exactly to prevent not having the possibility to add later
some functionalities. To me seems that more and more industrial stuff is going EtherCAT direction.
Don't forget LinuxCNC can handle about 8 spindles so the drill could get a free ride on another Z axis stage if you are creative.
ok thanks for that info. I will have to struggle a lot with it, I know :)
Does your table have downdraft zones?
What you exactly mean by "downdraft zones" ? I have not yet build the table where the workpiece will sit on.
But the gantry is already existing and here are some pictures of when I received it. brastrak.com.br/files/cnc/
  • dredivan
  • dredivan
12 Aug 2026 08:56
Replied by dredivan on topic Simple G7x Profile editor for Linuxcnc/Axis
Category: AXIS
  Hi everyone! Follow-up to my earlier post — kept working on the profiler with Claude (AI) and testing on my real lathe (LinuxCNC 2.9.8, Mesa 7I96S). Found more real issues since last time, including a couple more crash risks, plus added several new features.What was fixed:
  • G72's D/I/R were also wrongly scaled for G7 — same class of bug as the D/I swap from before, but G72 works along Z, where no diameter/radius conversion should apply at all
  • Retract (R) in G71 was missing the same G7 scaling fix that D/I already got
  • diagonal rapid moves could happen between multiple finishing/spring passes — now explicit, safe L-shaped repositioning between every G70 call
  • a profile point sitting exactly on the centerline (X=0) could hang LinuxCNC before any motion even starts — now caught with a clear error instead
New features:
  • tool nose radius compensation (G41/G42) support, including multiple finishing passes under compensation
  • separate "spring passes" (repeat the final cut N times with no material removal) as its own stage
  • finish allowance entered per pass (e.g. 0.25mm × 2 passes), with the total shown live
  • ΔZ (enter coordinates relative to the previous point) and ⌀X (enter the desired diameter at an arc's peak instead of the radius)
  • Half/Mirror preview mode
  • full project import/export (.txt with all machine parameters, not just coordinates), with auto-detection on import
  • Coolant/Tool comp/Cycle as dropdowns instead of text/checkboxes
  • generate-then-save workflow (Save/Send stay disabled until you click Generate)
  • better fill rendering in preview (incl. ID bores, and stock length the profile doesn't reach)
File and detailed changelog (CHANGES.txt) attached. As always — I'm not a programmer, so please double-check everything on your own machine before trusting it blindly.
  • tuxcnc
  • tuxcnc
12 Aug 2026 03:27
Category: Qtvcp
I can't help you.
I gave you working example.
You only have to remove from your config unnecessary stuff and replace parport pin by mesa pin.
But you see only that is one line not many...
11 Aug 2026 22:08
Replied by tommylight on topic Gantry oxyfuel / plasma type machine from scratch
What you suggest ?
  • rodw
  • rodw's Avatar
11 Aug 2026 20:32
  • rodw
  • rodw's Avatar
11 Aug 2026 20:01
Chinise mesa clone vs Original vs Ethercat
Category: Driver Boards
Yes, there will be synchronized movement as its all controlled by Linuxcnc on the single servo thread
  • rodw
  • rodw's Avatar
11 Aug 2026 19:51
Replied by rodw on topic Unable to Jog When HAL_ToggleBtn Active
halui.mode.teleop bit inpin for requesting coordinated jog mode
  • saxa
  • saxa
11 Aug 2026 18:25
That would be redundant as LinuxCNC is the motion controller.
In short:
-buy a Mesa 7i96S and a THCAD
What you suggest ?
I plan to set up a separate head in the future for plasma and who knows maybe even a spindle for drilling.
  • automata
  • automata
11 Aug 2026 14:55
Replied by automata on topic LinuxCNC S-Curve Accelerations
looking forward to your TP2. I would consider a few jerks in feed override an acceptable loss for using override as long as the max degredation of velocity is trapezoidal. Even a slight violation of max acceleration of an axis during the feed override is an acceptable degradation in my opinion.
If you are looking for a discussion on switchkins, I can help. When I first wrote switchkins, I could not think of an easy method to force a interpreter sync and yield type of queue buster which stops readahead. So looking at Fanuc and Hass, I added G12.1 and carried it through the complete chain of interpreter and motion. However dgarret came up with a much easier way to affect the queuebuster using M66 and remap which avoided touching so many files in the source tree for the switchkins feature.
For using axis limits during planning, the tool length which will become a parameter for the kinematics (including kinematics on the user side), could be carried through HAL or as a status variable from the #variables (#5401 to #5409).
I am looking forward to your release.
-automata
  • besriworld
  • besriworld
11 Aug 2026 14:53
Replied by besriworld on topic Chinise mesa clone vs Original vs Ethercat
I wonder if there are two interfaces. For example, the X and Y axes are controlled by the Ethercat and the Z axis is controlled by a Mesa card, will there be synchronized movements?
Displaying 1531 - 1545 out of 12724 results.
Time to create page: 0.298 seconds
