  • dunnitagain
  • dunnitagain
09 Jun 2025 23:57
Linuxcnc 2.4.5 with Ubuntu 10.04 , Terminated with Error!
Hello , Newb here. Just bought 2 , very nice Bridgeport and Jet mill retrofits , with Microkentics Steppers and PICO Universal Stepper cards , from the estate of a friend. Machines are very nicely built.
They sat idle since 2013, the Cmos batteries were dead . Ive been working on the .ini file of the Jet mill , to correct the homing sequence.
Everything was great , fixed the Z Axis homing . Powered down the control to plug the A axis in . Now on power up , it will not load Linuxcnc 2.4.5.
Is there a way to decode the error message , to see what i need to change, to return functionality ?
   The computers are bare bones machines, no network capabilities , just USB.
             Where can I look , or were do I Start ?
  • tar_san
  • tar_san
09 Jun 2025 23:21 - 10 Jun 2025 06:03
Replied by tar_san on topic Problems with Lichuan Ethercat servo drive
Category: EtherCAT
Thank you. I tried both V1.04 and V1.11.
But I couldn't make servo drive move in LinuxCNC main screen.
I didn't see any error on screen,  but servo drivers didn't become "Servo On" state when I pushed "PowerOn"
Where do I need to check ? ( I used to use another tiny LinuxCNC system and machine , but it was stepper.., I used step conf. )
Do I have to set some servo parameter from switches on servo driver ?
( No load is connected to servo motors for now. )
Servo Driver Panel shows "20ry" (2 is blinking.)
I tried both V1.11 and V1.04 and this configuration,
forum.linuxcnc.org/ethercat/52341-proble...rive?start=60#304887
I have 3 sets of Lichuan Servo (Driver+Motor), I want to use them as XYZ CNC.
  • kubes
  • kubes
09 Jun 2025 23:02 - 11 Jun 2025 17:03
Connecting a tool setter and touch probe at the same time
I did not see any other input other than motion.probe-in, is this used for both a tool length setter and a touch probe?  My HW will support several inputs, and I would like to have each hard-wired in, without the need to swap cables, etc.
Is there a dedicated motion input for a tool length setter? If not what is the best means to have to separate HW inputs?
Thanks!!!
09 Jun 2025 22:59
Replied by tommylight on topic Career in LinuxCNC/machine building
Hmmmm ... :
-walk around your area, see what businesses use CNC machines and for what and how = maintenance, service, maybe CAD/CAM and/or machine setup
-see what other businesses have offices there, what they do, drop buy any that do any manufacturing = contracting work, jobs to small for contracts are especially good as no one wants to do them
-drop buy other mom/pop shops, see if there's anything automated that can help them, or streamlining their work
-any foto/video studio, ask if they need sets/props built as needed, cam cranes or robots etc
-any food restaurants that want their logos engraved/cut/3d printed/scratched on glass = see my glass engravers here on forum, add LED's as needed
-leave your phone number to all of them
-and this is very important: do not lie to them, tell them exactly about doing market research trying to find a business that helps them but does not interfere with their existing businesses, as a rule at least 70-80% of them will really appreciate this and will gladly advise you and offer ideas.
--widen the "walk" area
-repeat above
  • russkinch
  • russkinch's Avatar
09 Jun 2025 22:50
Replied by russkinch on topic Encoder for rigid tapping
Category: HAL
Aaah. Awesome. Thank you. I shall try this tomorrow and see how it goes. I will let you know once I have changed the settings.
  • Hakan
  • Hakan
09 Jun 2025 22:38 - 09 Jun 2025 22:52
Replied by Hakan on topic SANGE elec IO
SANGE elec IO
Category: EtherCAT
Run the "lcec_configgen" command and compare.
Also check for relevant error messages from the command "sudo dmesg"
Edit, and according to the xml you attached, output 8 to 15 is in syncmanager 1, but you'll see that.
  • PCW
  • PCW's Avatar
09 Jun 2025 22:32 - 09 Jun 2025 22:34
Replied by PCW on topic Encoder for rigid tapping
Category: HAL
Sounds like you have the encoder component set to counter mode
rather than quadrature mode (counter mode set to 1 rather than 0)
( another hint is your scaling, a 50 PPR encoder is 200 counts/turn
in 4x quadrature )
man encoder
  • russkinch
09 Jun 2025 22:12
Encoder for rigid tapping was created by russkinch
Category: HAL
I have a 50p/r encoder with A, B & Z. It threads perfect and can thread at 1000rpm no hassles. I am trying to do rigid tapping, but when I use G33.1, it taps to the right depth, but when the chuck reverses, the tap goes in more and not out. Its like the stepper is not being told to reverse direction.
In my HAL file I have the three inputs setup (net spindle-phase-a encoder.0-phase-A) etc, I have the scale set to 50 and encoder mode set to 1. When I turn the chuck by hand, the position in HAL view rises by 1 for every 1 revolution of the chuck, but if I turn the chuck in the opposite direction, it carries on increasing and not count down. Is this correct? My encoder is an incremental Omron E6B2-CWZ6C. I am using a prallel port BOB (blue). Nema32 stepper motors and can control my spindle speed via the VFD (Bosch)
Any help is greatly appreciated.
  • jay
  • jay
09 Jun 2025 21:57
Replied by jay on topic Career in LinuxCNC/machine building
I appreciate the recomendation. Is it common that guys in the forums who have been building cnc machines for years (for a living) actually have one of these degrees?
Thank you
  • jay
  • jay
09 Jun 2025 21:50
Yes, in fact I have been considering this exact business. I looked for a local apprenticeship, but couldn't find anyone doing this kind of work locally. A guy on youtube has some great videos. It fits my interests and skills - I wonder how I could find my chances of getting customers. While I do not have a large truck, I can certainly factor that into the costs. If anyone here is involved in this kind of business please let me know the pros and cons.
Thank you langdons
  • jay
  • jay
09 Jun 2025 21:43
Excellent idea, you're getting the wheels turning. This gives me something to research. If anyone else here is doing this, please chime in.
  • jay
  • jay
09 Jun 2025 21:41
Thank you, sir. I should've clarified: while I'm currently in the Eastern US, I didn't mean to ask others to tell me about the market in my area (I feel like that would be asking you to do my homework); I just meant I would like to know how to research the market in my area - what should I be looking for (assets, pitfalls, etc).
Displaying 15271 - 15283 out of 15283 results.
Time to create page: 0.645 seconds
