  • PCW
  • PCW's Avatar
24 May 2025 00:51 - 24 May 2025 00:51
Developments on my Home built 5C CNC Lathe - Polar interp. and Live tooling
Yes, this definitely seems like a bug.
I can see the cut starting at a different place at different spindle
speeds due to the time needed to get synched to the spindle
varying at different spindle speeds, _but_ once synced and cutting,
the threads should be identical regardless of spindle speed...
(as they are in a normal manual lathe than maintains strict gearing
between the spindle angular position and Z offset)
  • spincycle
  • spincycle
23 May 2025 22:45
Replied by spincycle on topic Bridgeport VMC760 retrofit
Category: Milling Machines
Its steel actually.
Made it. Not hard!
Have a few of them in the shop. Made out of solid 2" (50mm) plate offcuts from the scrap dealer. I had them blanchard ground. Just mag drilled and tapped the M16 holes. Cheap and flat fixture tables. I've built some very straight motorbike and push bike frames on them over the years.
Thanks for the heads up on the switches. I'll keep this in mind.
  • atrex77
  • atrex77's Avatar
23 May 2025 22:15
W5100S-EVB-PICO stepgenerator and encoder driver
Category: Driver Boards
you need a network switch to connect
  • ihavenofish
  • ihavenofish
23 May 2025 22:12
Omron/Generic Ethercat Driver - Communications Synch Error
Category: EtherCAT
Poke poke
I'm trying to get my omron servos working here and it doesn't give the 90 error now, however it is giving me an 83 error which is also communication related.
I am starting with a very basil xml and using halrun to test things.
Any thoughts?
  • atrex77
  • atrex77's Avatar
23 May 2025 22:07 - 23 May 2025 22:10
if you use normal pico and a w5500 board, you need to wire like the dark blue pins in the w5100s-evb-pico, pinout here w5100s-evb-pico pinout new video here Embeddedtronics testing stepper ninja
  • DavidR8
  • DavidR8
23 May 2025 21:44
7i96S for Pathpilot? was created by DavidR8
Category: PathPilot
I'm planning to switch my 3-axis mill conversion from Masso to LinuxCNC using Pathpilot.
I ordered a Mesa 7i96s board. I ordered that board because a friend is also running Pathpilot on his router but he's using a 7i96T board.
Hoping to confirm that the 7i96s board will work for me.
Thanks in advance.
  • COFHAL
  • COFHAL
23 May 2025 21:15 - 23 May 2025 21:18
You say the PI pico connection (connections like in the w5100s-evb-pico), but the Pico pins are different for the SPI0, or am I wrong?
I have another question: if I'm going to use your io-samurai, would I need another network card?
  • andypugh
  • andypugh's Avatar
23 May 2025 20:56
Replied by andypugh on topic Need Help Setting Up a 2nd Spindle
Use " Halshow " to check that the spindle.1.xxxxx pins are doing the right things, and trace the signals from there.
  • Ismacr63
  • Ismacr63
23 May 2025 20:47
Replied by Ismacr63 on topic config tool setter
config tool setter
Category: QtPyVCP
yes that's how it is.
  • PCW
  • PCW's Avatar
23 May 2025 20:29 - 23 May 2025 20:30
Protecting My Mesa 7i76EU: Wiring Questions for Home Sensors and Touch Probe
Category: Basic Configuration
Yes, if the touch probe uses a contact to ground you can use a pull-up
resistor as Andy suggested.
For 7I76XX inputs this needs to be fairly stiff, say 2.2K 1/2W
This is because the 7I76XX input resistance is 11K and needs an input > 14.4V
for a high level at 24V Vfield, and a 10K resistor will not do this.
  • andypugh
  • andypugh's Avatar
23 May 2025 20:25
Replied by andypugh on topic Retrofit SODICK A320D
Do you want to replace like-for-like or swap out for a LinuxCNC conversion?
  • Lcvette
  • Lcvette's Avatar
23 May 2025 20:25
Replied by Lcvette on topic Probe Basic: Hide Tabs & Default Tab
Category: QtPyVCP
not currently, but its on the list
  • Lcvette
  • Lcvette's Avatar
23 May 2025 20:24
Replied by Lcvette on topic Setting started modification Probe Basic
Category: QtPyVCP
yup, from memory the probe led is a good example, forgot about that one
  • andypugh
  • andypugh's Avatar
23 May 2025 20:23
Replied by andypugh on topic M62-M68 codes not working
Category: Plasmac
M62 and friends need connections in HAL to have any effect. Do these connections exist? (motion.digital-out-NN etc)
  • andypugh
  • andypugh's Avatar
23 May 2025 20:13
Replied by andypugh on topic Index homing Heidenhain ls 403/exe602
As far as I know nobody has done this yet, but the change that allowed one to use a custom homing component was put in to support this type of scale.
How's your C coding?
www.linuxcnc.org/docs/devel/html/man/man9/homecomp.9.html
github.com/LinuxCNC/linuxcnc/blob/07cee8...nts/homecomp.comp#L4
However, I don't know if that is strictly necessary. I think that it _might_ be possible to craft a custom HAL component that outputs an encoder position and handles index_enable. This would take the encoder counts as input, and also manipulate the index_enable pin of the encoder counter. (I think it would be necessary to use the position-latching facility of the software or Mesa encoder. I _think_ you can set index-enable, which will zero the counts when the first index is seen, then re-enable index-enable and look at the counts-latched pin when index-enable resets on the second index. But I have not tried this.)
The component would then reset the index-enable that the homing system sees, and pass the correct position into the system. (Note that the "correct" position might be the inverse of the actual position, in some way. The position-after-index-enable is used by the system to calculate how far the current position is from the home position.
component inputs:
index-enable - to / from motion system
encoder position - from encoder counter
position-latched - from encoder counter
outputs:
index-enable - to manipulate the encoder counter
encoder-position - an offset version of the encoder position input
I do have a Heidenhain scale, but i have never done anything with it, and don't know if its a type with encoded index marks.
Displaying 15646 - 15660 out of 16112 results.
Time to create page: 0.558 seconds
