  • JPeters
  • JPeters
18 May 2025 22:06
Hello scotta,
thank you for your quick reply. Yes, that is exactly what I thought myself.
The EC500 is powered by an external power supply. From the 6 pin header, GND, SCK and SDO have been connected to one of the probes.
I don´t have any kind of schematic on hands for the EC500. So I am not shure, why the header pin is labeled SDO. I would expect SDIO for a sufficient SWD connector. Is your header labeled with a SDO too?
My EC500 is labeled with IMXR_EC500 2023-05-18
Up to now, there has not been a single successful flash. From within MCUExpresso, I am at least able to build your application.
If this is not going to be successful: do you think, your actual project with W5500 and raspberry pi pico is as powerful as the 1052 solution and could be a viable alternative?
Thank you very much. I will try to give more details tomorrow.
Cheers Julius
  • Thayloreing
  • Thayloreing
18 May 2025 21:11
Replied by Thayloreing on topic Remora - ethernet NVEM / EC300 / EC500 cnc board
Hi Scotta, do you happen to know what the error I'm having means? It seems like it's not communicating with the cloud in any way.
  • scotta
  • scotta's Avatar
18 May 2025 20:45
Hi Julius,
Very strange that one of those combinations don't work, especially MCUExpressoIDE.
For flashing
1. board is externally powered from 24v, so no VCC connection
2. GND, SCK and SWDIO is all the connections needed to the CMSIS-DAP probe
When I've experienced connection issues, powering on the board as the probe is trying to connect to the MCU has helped.
  • zz912
  • zz912's Avatar
18 May 2025 20:30
Replied by zz912 on topic Gmoccapy 3.5.0 - opinions needed
Category: Gmoccapy
Your answer is a technical explanation of why this is the case. However, I look at it from a user perspective. I take it that there is unnecessary information in manual and MDI mode. I understand that removing this is extra work, but it is not unsolvable.
  • HansU
  • HansU's Avatar
18 May 2025 20:19
Replied by HansU on topic Gmoccapy 3.5.0 - opinions needed
Category: Gmoccapy
Is there any reason why "G-code properties" is also displayed in manual and mdi mode?
It is there in manual mode as well, because it is part of a box that is displayed in all modes, so this is also displayed in all modes.
  • alangibson
  • alangibson
18 May 2025 20:08
Replied by alangibson on topic Ohmic probe aborts immediately
Category: Plasmac
At long last, here it is:
  • JPeters
  • JPeters
18 May 2025 19:29
Hello dear EC500 users,
same as Thayloreing , I had a quite frustrating time trying to flash my EC500 over the last months. And there still is no success. So I am considering quitting the whole thing but I want to give it a last try by registering to this forum.
The problem is to get the firmware into the flash... and I did not find any solution that is working for me. I even can not reproduce the video from scotta with the reprogrammed STLink/V2 stick.
I tried:
  • Modified STLink/V2
  • DAP Link probe from Aliexpress
  • JLink Edu mini
on
  • pyOCD
  • MCUExpressoIDE
  • On Windows and Linux
I was not able to use the modified ST-link/V2 stick (as in the video from scotta) as a mass storage device under Windows for drag and drop usage. It simply does not show up in Explorer. I checked this with 3 different computers.
The DAP Link Probe is being detected under Linux and is attached to /dev/ttyACMx, but flashing with pyOCD leads only to the prompt: no ACK.
Using both probes under MCUExpressoIDE under Linux is useless, because they are not detected at all. JLink shows up, can be selected but stops programming by stating: can't stop CPU.
The EC500 seems to be a quite nice piece of hardware and I would like to use it in my projects.
Is there a working solution to flash this board available anywhere? I was not able to find any reliable solution what so ever.
Further on: Is the programming interface on the EC500 even usable? And what pins has to be used? There are:
  • VCC
  • GND
  • SCK
  • SWO
  • Boot_MO
  • Pro_B
Is this a sufficient pinout for a  working interface for SWD? SWO is for CPU output, not for data input. And what are Boot_MO and Pro_B good for?
I hope for any help on that topic. Programming a MCU should not be that complicated...
Cheers Julius
  • PabloSancez
  • PabloSancez
18 May 2025 19:02 - 18 May 2025 19:05
Replied by PabloSancez on topic Problems with Lichuan Ethercat servo drive
Category: EtherCAT
Hi, I have finished the lathe with ethercat drivers. I'm posting my configuration. I am using a revolver head with asynchronous motor with carousel control. mesa reads the encoder and buttons. the machine is cast in steel.
youtube.com/shorts/veTGtAU7UrY
youtube.com/shorts/fbEU6qiVqMk
disk.yandex.ru/d/rNy3ErpcVfzkxw
  • aluplastvz
  • aluplastvz
18 May 2025 18:35
Replied by aluplastvz on topic absolute encoders with dual axis
Category: Basic Configuration
I am currently working on a machine with two X axes 1500x3000mm, what should I do so that with the incremental encoder it can align the bridge if it moves a little in reset mode.
mesa 7i95t
Greetings
  • Thayloreing
  • Thayloreing
18 May 2025 18:14 - 18 May 2025 19:11
  Good afternoon, I think I managed to do what you asked me, but without results, still with the same error. Could it be my pyocd installation? I've tried with other versions of Debian, but always the same problem.
  • unknown
  • unknown
18 May 2025 17:33
Linuxcnc 2.9.4 .iso on Rpi5: apt update does not build /boot/initrd.gz
Category: Installing LinuxCNC
Best thing to do is think of an RPi running Linuxcnc as the ECU in an early 2000's car or bike, as long as it works there's no real need to upgrade.
I'd like to be able to count the amount of times I upgraded the ECU on my 1999 Toyota Echo on one hand, but I have all the fingers on each hand
  • unknown
  • unknown
18 May 2025 17:27
Replied by unknown on topic Important Info Regarding Rpi4/5 Images.
On a normal daily driver or even server kernel upgrades are fine.
The issue in this instance is that the kernel used in the image is particular to the RPi and is custom built.
From playing around with various Arm devices the boards aren't as "generic" as the PC platform. Each Arm processor or SOC has it's own quirks as such. The device tree is a way to let the Linux kernel know which devices are available, device tree overlays are used to further customise the setup.
Then there are custom patches that are used to further "tune" a particular board.
I have 3 main machines at home running Linux, one desktop and laptop running Mint and a server running Ubuntu, kernel upgrades are not an issue on any of these 3.
Obviously I have an RPi5 & 4 for testing Linuxcnc images, so these don't see kernel upgrades unless testing new images.
The Orangepi PC that running my hacked together reflow oven doesn't get upgrades, it works and is left alone, but it does have a custom device tree has I needed some status LEDs and an off button on the front panel from the GPIO header. Now if I was to upgrade this kernel I would also have to rebuild the device tree file to suit.
Whilst the Arm platform is good, it's come along way in 20 years, it's not as generic as the PC platform, it's kinda like pre PC days.......but without the OS software issues.
  • Murphy
  • Murphy
18 May 2025 17:10
Try been in the directory where the file is located. Before you run pyocd. Are you able to ping the board. 10.10.10.10 ??
  • rdtsc
  • rdtsc's Avatar
18 May 2025 16:37
Aaah I see; thoughtless mistake then. Kernel 6.1.0-35-arm64 was the linuxcnc one, which apt erroneously removed in favor of 6.12.11-1 and 6.12.12+bpo-rt-arm64, since those (recently) emerged as the logical successor. Note to future self: do NOT accidentally do dist-upgrade on LinuxCNC!
I was hopeful though, that the original version could be reinstalled without having to redo the whole install. This is because when removed, apt did note that it could not remove the 6.1.0 folders as they had custom files in them. But alas, I accidentally removed linux-image-bcm2712-rpi since that was now linked to the 6.12.12 kernel. That package has no installation candidate, so I'm borked. Reinstalling...
  • pgf
  • pgf
18 May 2025 16:35
Effect of lengthening the servo thread period?
Thanks! That first paragraph was gold. My understanding of how the whole thing works just went *way* up!
Displaying 15916 - 15930 out of 16113 results.
Time to create page: 0.463 seconds
