  • zarfld
  • zarfld
08 Apr 2025 08:23 - 08 Apr 2025 08:24
Pokeys_homecomp EncoderSearch / Encoder Arm Topic: Pos_Fb Following errors
Category: HAL
thanks for the answer!
the "errors" seem to be the limitswitches. (i need to check the simulation).i disconnected the HAL signals from joints and now that works.
an minor issue which i can workaraound by just providing pos_fb=0.0 during homing procedure on pokeys is that i don't know how to "Pause" Linuxcnc from checkeing pos_fb versus pos_cmd for following errors during homing procedure.
(in homing.c i have seen some "free_tp.enable=0" and applying ofstes to pos_fb and pos_cmd - i think i have to check that more in detail)
BR
Dominik
  • hermann1976
  • hermann1976's Avatar
08 Apr 2025 08:10
Replied by hermann1976 on topic NativeCam on LinuxCNC 2.9.3
Category: NativeCAM
Hi Giovanni,
Thank you very much for your efforts in integrating the NativeCAM plugin into the current version of LinuxCNC 2.9.4. Thanks to everyone else as well.
I've been looking for a way to generate simple programs within the LinuxCNC control system for a while. I only came across the NativeCAM plugin late. I installed NativeCAM according to the instructions and have now got it running as a plugin in the axis environment.
However, I have the problem that I can access the NativeCAM preferences, but the settings aren't saved. Can anyone else confirm this?
I also can't run NativeCAM as a standalone program with the command: "ncam -i (path to ini file) -c mill." This results in error messages. I'll add them later.
I would like to run NativeCAM alongside the QTDragon screen (as a standalone program) if possible. Would that be possible?
Thank you very much, and I ask for your help.
(translated from German to English via Google translate)
  • Domi
  • Domi
08 Apr 2025 07:34
just run the override flag : I just don't understand how to use it. Thank you
  • skydyver
  • skydyver
08 Apr 2025 07:34 - 08 Apr 2025 07:36
Replied by skydyver on topic Rotating the g54 coordinate system.
I've just implemented this for myself.
I already have autoprobe routines that set g54 parameters for X, Y, and Z. I augmented my autoprobe functions to log the x and y values of every completed probe, along with the g54 offsets in effect at the time.
When I have a rotated part, I touch it twice, along a surface that's parallel to its twisted X axis. That gives me two new log entries. I have a script that level devil  reads those entries, and calculates d = atan ( (y2 - y1) / (x2 - x1) ), after correcting the x and y values with the offset information.
The script prints the result in degrees. In fact, the script simply prints the necessary g-code: "G10 L2 P0 R $angle", which I then pasted into the MDI window.
Once you generate the G-code command with the calculated angle, do you have any specific procedures for verifying the machine’s response after you paste it into the MDI window?
  • jenkinson8
  • jenkinson8
08 Apr 2025 06:58
Replied by jenkinson8 on topic Remora - ethernet NVEM / EC300 / EC500 cnc board
Fortunately this one is a reasonably easy fix:
pip3 install tftpy
it will spit out an error advising that you need to work inside a virtual environment, since you probably aren’t using your LinuxCNC machine for Python development, just run the override flag. Apologies I am typing on the go otherwise I’d look up the exact flag you need to add.
08 Apr 2025 06:09
4-Gang 1-Way Switch To Control 3 Power Supplies and a Router Independently
Where are you getting the info?
No DC side relays nor switches!!!
Never switch the DC side, unless you're in the solar panel business.
  • behai
  • behai
08 Apr 2025 04:52
Seems a bit excessive and not very useful.
It is much better to use a single small industrial switch and 4 of automatic fuses inside the control box, you can switch on/off automatic fuses as they can handle a bit of torture although they are not made for it, but since they will be used during testing only, they will be fine.
Regarding the automatic fuses, I understand that we can also use DC circuit breakers.
I am studying to understand how to select appropriate DC circuit breakers for different PSUs and loads.
I understand that: Fuse Rating in Amp = Load Current x 1.25
I am using the Mean-Well MDR-100-24 PSU whose output is 24VDC 4A to power the 8 proximity switches exclusively.
The current rating for each of the switch is 300mA. In theory, 4 of the switches could activated at the same time, the maximum Load Current is 4 x 300mA = 1.2A.
But because the switches are just inputs to the Mesa 7I96S, I understand that, in this case, they draw very little current, maximum about 20mA each.
The maximum Load Current is then: 4 x 20mA = 80mA.
An DC-rated miniature circuit breaker is:
- Current: 1A - 2A
- Voltage: greater than or equal to 24VDC; up to 60VDC or 125VDC
- Curve Type: Type B
Is this correct, please?
Thank you and best regards,
...behai.
  • Kieran
  • Kieran
08 Apr 2025 03:56
Replied by Kieran on topic Rf45 clone glow up.
Rf45 clone glow up.
Category: Milling Machines
Got some goodies too.
  • Kieran
  • Kieran
08 Apr 2025 03:52 - 08 Apr 2025 03:54
Rf45 clone glow up.
Got the table modified last week.
  • PCW
  • PCW's Avatar
08 Apr 2025 02:30 - 08 Apr 2025 02:37
Replied by PCW on topic Joint Error After large rotary move
Pushed a change to Master to use 64 bit integers for hm2 quadrature
encoder count values rather than 32 bit, Seems to work as expected.
(32 bit ints cause a wrap at  a count of 2147483648)
(looped back a stepgen at 30 M counts/sec to the encoder
input to test, still took a while...)
  • cakeslob
  • cakeslob
08 Apr 2025 01:32
Hmm ok that confirms it. I did most of my octopus functionality testing on the octopus v1.1, I didnt like the buzzer on the pro. The octopus PRO has level shifters on the UART lines. When I jumper the TMC UART line to another pin, it configures fine. That is the only thing I can think of. But this overlaps with another issue Im having with another board, that also has a level shifting circuit on the UART line.
Scott, if you can provide input/assistance on this issue, it would be appreciated.
Im trying to support this mellow flyCDY3 board, but the uart isnt working. I tried changing the baudrate, but no luck. Thankfully my buddy mdroberts is much smarter than me, so he collected some data for me on the issue.
It looks like i cant upload the excel file he made, but here is what he said
Further to the TMC2209 read-back. I used the scope UART decode feature to confirm that the programmed values sent to the TMC2209 seem reasonable and consistent with the registers, but the TMC2209 doesn't put any data out after a register read is requested. The sequence after resetting the board is provided in the attached.
I just don't see any output from the 2209 when a register read is done.
07 Apr 2025 23:57
Replied by tommylight on topic Free Mesa 5I25 Superport board
Category: User Exchange
You should remove the e-mail, spam incoming :)
  • robforbes
  • robforbes
07 Apr 2025 23:42
Replied by robforbes on topic Free Mesa 5I25 Superport board
Looks like Francisco got it.
Rob
07 Apr 2025 23:13
Who's the lucky winner?
  • pgf
  • pgf
07 Apr 2025 22:32
Replied by pgf on topic Rotating the g54 coordinate system.
When I have a rotated part, I touch it twice, along a surface that's parallel to its twisted X axis. That gives me two new log entries. I have a script that reads those entries, and calculates d = atan ( (y2 - y1) / (x2 - x1) ), after correcting the x and y values with the offset information.
Displaying 17026 - 17040 out of 17636 results.
Time to create page: 0.418 seconds
