  • noqui
  • noqui
01 Mar 2025 15:31
Replied by noqui on topic Modify AXIS GUI
Modify AXIS GUI
Hi, If I only want to add the Camera in the AXIS.GUI, I need to set again all the instructions in the Qt Designer? Or there is a simplified way? Thanks a lot.
  • JT
  • JT's Avatar
01 Mar 2025 15:05
Manual homing does not move on any axis
I still use Ubuntu 10.04 and 2.7 on my CHNC and see no point in upgrading if it just works.
JT
  • JT
  • JT's Avatar
01 Mar 2025 15:04
Mesa hm2/hm2_7i96s.0: error finishing read
Category: Driver Boards
After trying pinirq and rebooting the PCI NIC failed to obtain an IP address for three reboots so something random is going on.
My thought now is to copy everything to another drive and reinstall Debian 12.
JT
  • JT
  • JT's Avatar
01 Mar 2025 14:18 - 01 Mar 2025 14:19
After running pinirq
john@cave:~/bin$ sudo ./pinirq enp9s0
[sudo] password for john:
Cores: 12
Old CPU Mask: 00000fff
Set device enp9s0 IRQ 50 CPU mask to 00002048
I get
john@cave:~$ sudo chrt 99 ping -i .001 -c 60000 -q 10.10.10.10
PING 10.10.10.10 (10.10.10.10) 56(84) bytes of data.
--- 10.10.10.10 ping statistics ---
60000 packets transmitted, 60000 received, 0% packet loss, time 60085ms
rtt min/avg/max/mdev = 0.049/0.052/1.112/0.005 ms
JT
  • JT
  • JT's Avatar
01 Mar 2025 13:54
I tried the following grub kernel parameters but the PCI NIC would not work.
quiet isolcpus=11 idle=poll r8125.EEE=0 pcie_aspm=off
quiet isolcpus=11 idle=poll pcie_aspm=off
I changed my grub kernel parameters to
and did a ping test and my PCI NIC started working again as well
60000 packets transmitted, 60000 received, 0% packet loss, time 60092ms
rtt min/avg/max/mdev = 0.049/0.051/0.123/0.001 ms
JT
  • vre
  • vre
01 Mar 2025 13:51
X axis following Y axis was created by vre
If i have a roll of material and unrolling it with encoder installed on roller
how can synchronize this moving of material in one direction (Y axis)
with X axis and Z axis to cut it for example with laser
Rollers have some speed adjustment  and accurate feedback for velocity position from encoder
but it is not like a real Y axis.
  • NT4Boy
  • NT4Boy
01 Mar 2025 13:31 - 01 Mar 2025 13:33
Replied by NT4Boy on topic HURCO KMB-1 Control Update
Category: Milling Machines
I found I had this statement in my hal file...
loadrt hm2_eth board_ip="10.10.10.10" config="num_encoders=6 num_pwmgens=0 num_stepgens=0 sserial_port_0=000xxxxx"
so I have tried
0=010xxxxx"
0=020xxxxx"
But cannot find these
hm2_7i92.0.7i73.0.2.analogin0, 1, 2
I have my pots connected to the IN0 ,1,2 pins and in halshow
on pins
hm2_7i92.0.7i73.0.2.input-00 etc, the lights change from red to yellow as the pot is turned, so electrically looks ok.
still mystified.
  • JT
  • JT's Avatar
01 Mar 2025 13:26
ping test
60000 packets transmitted, 60000 received, 0% packet loss, time 60095ms
rtt min/avg/max/mdev = 0.048/0.051/4.051/0.021 ms
JT
  • JT
  • JT's Avatar
01 Mar 2025 13:24
So I've managed to get the PCI NIC working to access the internet and the onboard NIC to communicate with the 7i96S.
john@cave:~$ sudo lshw -C network
  *-network
       description: Ethernet interface
       product: RTL8111/8168/8411 PCI Express Gigabit Ethernet Controller
       vendor: Realtek Semiconductor Co., Ltd.
       physical id: 0
       bus info: pci@0000:06:00.0
       logical name: enp6s0
       version: 06
       serial: 68:1c:a2:12:f7:e6
       capacity: 1Gbit/s
       width: 64 bits
       clock: 33MHz
       capabilities: pm msi pciexpress msix vpd bus_master cap_list ethernet physical tp mii 10bt 10bt-fd 100bt 100bt-fd 1000bt 1000bt-fd autonegotiation
       configuration: autonegotiation=on broadcast=yes driver=r8169 driverversion=6.1.0-29-rt-amd64 duplex=full firmware=rtl8168e-3_0.0.4 03/27/12 ip=192.168.1.59 latency=0 link=yes multicast=yes port=twisted pair speed=1Gbit/s
       resources: irq:32 ioport:e000(size=256) memory:e0304000-e0304fff memory:e0300000-e0303fff
  *-network
       product: RTL8125 2.5GbE Controller
       physical id: 0
       bus info: pci@0000:09:00.0
       logical name: enp9s0
       version: 04
       serial: f0:2f:74:21:ce:6a
       capacity: 1Gbit/s
       width: 64 bits
       clock: 33MHz
       capabilities: pm msi pciexpress msix vpd bus_master cap_list ethernet physical tp mii 10bt 10bt-fd 100bt 100bt-fd 1000bt-fd autonegotiation
       configuration: autonegotiation=on broadcast=yes driver=r8169 driverversion=6.1.0-29-rt-amd64 duplex=full firmware=rtl8125b-2_0.0.2 07/13/20 ip=10.10.10.12 latency=0 link=yes multicast=yes port=twisted pair speed=100Mbit/s
       resources: irq:35 ioport:d000(size=256) memory:fcd00000-fcd0ffff memory:fcd10000-fcd13fff
The first one is the PCI NIC and the second one the onboard NIC. One thing I noticed is the speed of the onboard NIC is 100Mbit/s even though it's a 2.5 GbE card, is that normal?
JT
  • Hakan
  • Hakan
01 Mar 2025 12:41
Replied by Hakan on topic AX58100
AX58100
Category: EtherCAT
Haven't been working on this particular board a lot since I don't use it myself. Been busy with a voltage reader for plasma and IO, for my plasma cutter and that works great.
If you continue to use the STM32F407 you should check that there are free timers available. Probable there are, but I used a lot of timers I remember.
Earlier in the thread there is an attachment with spindle control schematics, maybe you already had a look on that one.
My spindles are all controlled via Modbus/VFD and the 3V analog output was put there for good measure.
There could have been connectors for I2C and SPI to easily add on functionality controlled by the STM32. Maybe something you can think of.
  • NT4Boy
  • NT4Boy
01 Mar 2025 12:25
7i92 P2 7i77 serial 7i73
I said above that analog was confirmed, not true as I was seeing parameters, not pins.
I've read many posts about enabling the analog mode for inputs 0-7, but cannot get my head around the syntax.
looks like it might be
loadrt hm2_7i92.0.7i73.0.2 config="sserial_port_0=01000000"
But I'm not certain
Would you check for please.
  • HansU
  • HansU's Avatar
01 Mar 2025 11:45
Replied by HansU on topic My CAD / CAM research
Category: CAD CAM
Ah yes I found a similar thread saying the same:
www.cnczone.com/forums/uncategorised-cam...are.html#post2541766
  • ytiuqibu
  • ytiuqibu
01 Mar 2025 11:34
Replied by ytiuqibu on topic Manual homing does not move on any axis
Thanks for the reply JT
I have since reconfigured the axis wiring and discovered that there was a very slight and extremely slow movement which has been overcome by resetting the homing speed . We are still using version 2.7 as we had this working adequately two years ago and I would prefer to ensure we have a working machine before I upgrade the OS and install 2.9.
The homing on our z axis is working extremely well with a pair of relatively new mechanical micro-switches but x and y are proving stubborn with our original switches that are about 20 years old so I will by some new ones and see if their response is better.
We only get to work on this machine a few hours per week so changes are rather slow.
Thanks once again.
  • machinedude
  • machinedude's Avatar
01 Mar 2025 10:30
Replied by machinedude on topic Black Friday Deal got me :)
Category: Plasma & Laser
i was not happy with the force to spin this thing but it seems the bigger you go the greater the torque needed based on some digging with manufacturer specs i found. i found these that i could buy over seas but they require 3.5 Nm of torque. i'm not sure if that is breakaway or running torque? i'm thinking it's breakaway but i am not sure at this point. if i can figure out a way to test this so i can get a feel for it i might be at a fork in the road moment and end up just biting the bullet and buying these is it seems better than what i was seeing with what i was doing. 3,5 Nm seems like a lot of torque needed?
  • royka
  • royka
01 Mar 2025 09:51 - 01 Mar 2025 09:53
Replied by royka on topic Can't eek out that last bit of jitter
Last time I had a bit of a succes on preempt_rt with moving the base thread to another cpu (only with 6.13), but perhaps worth a shot.
Change the CPU numbers and run as sudo. In the script CPU1 is the base thread and CPU2 the servo thread.
forum.linuxcnc.org/18-computer/48079-can...cnc?start=390#321927
Displaying 18256 - 18270 out of 18761 results.
Time to create page: 0.443 seconds
