  • PCW
  • PCW's Avatar
14 Feb 2025 22:31 - 14 Feb 2025 23:49
Error: undefined symbol: hm2_pktuart_setup_rx - while lading custom modbus.so
Category: Driver Boards
Here are the pktuart.0 and mb25ioc32.so files that work on my system:
File Name: debug.zip
File Size:51 KB
Replacing your files (one at a time) may help debug this issue.
  • PCW
  • PCW's Avatar
14 Feb 2025 22:21
One laptop + several machines using Mesa cards.
Just needs appropriate configuration (hal and ini) files for each machine
  • CGT80
  • CGT80
14 Feb 2025 22:19
Replied by CGT80 on topic Probe Basic Tool Setter questions
Category: QtPyVCP
That was it! I tried 8" for max travel instead of my 16" and it probed down......I should have done that last night, but it was time to stop for the evening. So, I added 60 thousandths to my previous measurement, as you mentioned, and it measured and inputed the tool length.
Thanks for the link....that is what I was already following, along with the directions on the various PB screens.
I also saw info on the various offsets in your directions, so that should answer one of my previous questions in this thread. I'll make my way through all the directions on your page and I need to check out your videos to see what else I can learn.
  • notJamesLee
  • notJamesLee
14 Feb 2025 21:54
Tangential Cutter C/A - Following Error/Tuning
Hi Friends,
The goal is a tangential knife setup with a pizza type cutter blade. To achieve this i have a servo driving a pulley that drives an output shaft with the  blade on it. my goal right now is to get it to jog without errors.
In Axis, when i jog the A axis its slow and jittery. I increased the speed to about 500 deg/min and it moves faster but just as jittery. Anything over 600 i get a following error, I also get random following errors throughout normal jogging. I checked all the connections and they seem fine. Which leaves makes me think it might be the servo tuning.
I tried to follow this guide to tune it (gnipsel.com/linuxcnc-old/tuning/servo.html) however, i cannot find the signal in hal scope. The tutorial calls out 'axis.x.f-error' i can only find 'joint.x.f-error' and get no change when i trigger it with a movement. what is the difference between these two and am I on the right track?
Any advice is greatly appreciated.
  • scotta
  • scotta's Avatar
14 Feb 2025 21:22
LinuxCNC will only come out of eStop when the SPI comms works, ie the remora-spi component receives a valid response from the board.
This is where using the serial output from the board is handy to ensure the board boots all the way to idle state where it will wait for SPI commands.
  • PCW
  • PCW's Avatar
14 Feb 2025 21:17 - 14 Feb 2025 21:22
OK  thinking about this, it's probably just a difference between a RIP installation and
a binary installation, where the normal user does not have write access to LinuxCNC's
system files.
Still does not explain the issue, and why it works as expected using  2.9.4 built from source.
Maybe a problem with the binary image.
  • Corne
  • Corne's Avatar
14 Feb 2025 21:16
I changed the permissions of the modules directory. Now only a 'touch' error. Doesn't say me something...
corne@linuxcnc:~/CNC/Mesa/mod$ modcompile mb25ioc32.mod
/tmp/tmp40_g_2ol/mesa_modbus.c
touch: cannot touch 'mesa_modbus.c': Permission denied
Compiling realtime mesa_modbus.c
Linking mb25ioc32.so
cp mb25ioc32.so /usr/lib/linuxcnc/modules/
  • jairobbo
  • jairobbo
14 Feb 2025 21:05 - 14 Feb 2025 21:06
yeah so before I tried also to get CubeProgrammer to reinstall the bootloader but it failed, and now wonderfully it succeeded.
also:
firmware.bin => firmware.cur
my further drilling the setup led to understanding that the estop is tied to:
net user-enable-out <= iocontrol.0.user-enable-out => remora.SPI-enable
net user-request-enable <= iocontrol.0.user-request-enable => remora.SPI-reset
net remora-status <= remora.SPI-status => iocontrol.0.emc-enable-in
I do not fully understand, but remora.spi-enable is TRUE, status is FALSE and reset = FALSE, they are connected to a signal which is probably a physical signal on the octopus, but I dont know where. I accidentally made a short by connecting 3.3v to GND on DIAG0.... :(
Anyway getting closer :)
p.s. I believe nothing was damaged!
  • Corne
  • Corne's Avatar
14 Feb 2025 21:03
With a fress install (from image) - without sudo i get this;
/tmp/tmpqf_2s56r/mesa_modbus.c
cp: cannot create regular file '/usr/lib/linuxcnc/modules/mb25ioc32.so': Permission denied
make: *** [/usr/share/linuxcnc/Makefile.modinc:107: install] Error 1
  • noqui
  • noqui
14 Feb 2025 21:01
Replied by noqui on topic ssh connection instead of telnet
I will try to do this: "Unless you have setup sshd to listen on port 5007 that is the the expected behavior."
  • PCW
  • PCW's Avatar
14 Feb 2025 20:58 - 14 Feb 2025 21:00
it should be:
modcompile xxxx.mod
not
sudo modcompile xxxx.mod
at least that's what I have always done
  • Corne
  • Corne's Avatar
  • noqui
  • noqui
14 Feb 2025 20:52
Thanks you both. Yes I know that the security of the WAN is the most important security thing I must take care, but SSH, will at least secure part of the system. But anyway it is a very good advise. Thanks a lot.
Displaying 18871 - 18885 out of 19423 results.
Time to create page: 3.873 seconds
