  • ccc774
  • ccc774
21 Oct 2024 21:57 - 27 Oct 2024 11:00
Replied by ccc774 on topic Can the OPI5 be Configured to Run LCNC?
running from sdcard - kernel6.1.75-rt23
  • martin2day
  • martin2day
21 Oct 2024 21:25 - 21 Oct 2024 21:51
Knuth Mark Super CNC Retrofit - need some help with my first LinuxCNC
Category: Milling Machines
Hello,
i have found it very quick... it is as you say... it is controlled by analog signal...
4 Analog Out... 3 for the Axis and 1 for the Spindel.
So what Board did I need to buy? :-)
This one is the "Minimum"?  Link
Thank you very much.
Martin
  • bkt
  • bkt's Avatar
21 Oct 2024 21:24 - 21 Oct 2024 21:46
Replied by bkt on topic c++ compiling error
c++ compiling error
jungle boogie is my preferred ...
21 Oct 2024 21:15
If the manual is right, can I also connect the analog Driver with encoder output to Linux CNC an make a closed Loop?
Both of the drives have encoder outputs so both can be used to close the loop in LinuxCNC.
If you are eager to get the boards and start wiring, i would go for the Mesa 7i96S with a 7i85 and 7i83 for now and add a 7i84 or two later for more inputs and outputs. This makes it possible to control both types of drives, the step/dir ones and analog ones, even a mix of any of those at the same time.
It is a bit more pricey that say 7i97 for analog or 7i95T for step/dir, and maybe a 7i84, but leaves a lot of options open to expand as you see fit in the future.
  • martin2day
  • martin2day
21 Oct 2024 21:09
Oh, i have to check this, tank you.
The Driver is an Maxsine EP100-3A, this I know exactly... but if the Knuth electrical drawing is right, I don't know... I find many errors there.
So I have to check it.
Martin
21 Oct 2024 21:06
Replied by tommylight on topic Machine moves when you stop program in the middle
I had a part that was a little too deep, so I pressed stop and guess what? It plowed through my part before stopping. So that was a $2000 part before we machine it. Turned to trash because something is not right.
To late, but, never ever do production work on a machine that is not tried and tested to function properly.
Can you please attach the hal and ini file you are using here?
In the meantime, check the ini file for "pause_position or tollchange_position" or something similar that would cause such an issue.
Also, does the machine move to the same spot when stopping the execution?
Take some screenshots of the position in DRO before stopping the program and after stopping it and upload those here on the forum.
A video of that happening might also help, use youtube and link here, if you can, or google drive.
21 Oct 2024 21:00
Replied by tommylight on topic Gecko 540 + Mesa 5i25 configuration.
Category: Basic Configuration
On the Mesa configuration page in PncConf, set the encoder number to 0, then it will show input pins so you can select them.
  • Lcvette
  • Lcvette's Avatar
21 Oct 2024 21:00
Add setting to toggle display of one or two file managers in Probe Basic
Category: QtPyVCP
no, it would interfere with the mdi tab widgets which are already compressed for the gcode window there. I have a large machine vmc and have not had any issues with the back plotter size, but i could see a large format router perhaps being a bit of a problem. perhaps you could add a large full screen plotter in the user tab to suit your desired needs!
21 Oct 2024 20:59
Not the same drives, pretty sure, this one is step/dir only, the above is analog only.
  • royka
  • royka
21 Oct 2024 20:56
Replied by royka on topic Can the OPI5 be Configured to Run LCNC?
It's a bit of a mystery for me. A ftdi adapter could help to give some more information. Maybe firmware is missing or a driver is as module but should be built in. When you boot from the sd-card with the rt kernel, the nvme is still recognized? If so, can you show the output of blkid and of dmesg after boot and lsmod?
dmesg > dmesg-output.txt
lsmod > lsmod-output.txt
blkid > blkid-output.txt
  • Lcvette
  • Lcvette's Avatar
21 Oct 2024 20:56
Version aktualisieren + diverse Fehlermeldungen
Category: QtPyVCP
did you completely uninstall the previous versions of qtpyvcp and probe basic? key error sounds like you may not be getting everything installed correctly or like you said may have some odd security conflicts with your network setup. i would completely reslve those and then report back if the problem perists.
21 Oct 2024 20:56
Replied by tommylight on topic Installation Error
Installation Error
Category: Installing LinuxCNC
When it gets to that error:
-remove the USB
-wait 15 seconds
-plug in the USB
-wait 15 seconds
-press or click retry
  • Lcvette
  • Lcvette's Avatar
21 Oct 2024 20:54
Category: QtPyVCP
so what is the error message you get? and does the sim open?
  • martin2day
  • martin2day
21 Oct 2024 20:51
Hello,
thank you... I also have an PDF oft the AC-Driver:
This browser does not support PDFs. Please download the PDF to view it: Download PDF
Martin
21 Oct 2024 20:48
Hard to see on the PDF and my glasses, but those look like analog drives, not step/dir so 7i76E would not be the best option.
Can you take a picture of the drives where the pin naming is?
Displaying 22456 - 22470 out of 22613 results.
Time to create page: 0.877 seconds
