  • Mecanix
  • Mecanix
06 Aug 2024 17:36
it always depends on the application,
True. Let's hope that badboy will be fit for a 4ax mill, 2ax lathe and ofc a 3ax co2 retrofit (<- my first project). Nice connector link up btw, I use the same although in a 2.54mm pitch.
Too kind, as always. Thanks for sharing your expertise. I've removed the uart interface, will add a ws2812b status led, and added an automotive 2A input supply from MPS (supporting 9~60vdc). That should work with my 24v and 48v PSUs. For the remaining bits you've advised, I'm eager to simply add bidirection translation for the 50 gpios and send that out "as-is" rather. Reason for this is; I want to test ALL gpios on that unknown-to-me fpga before sending out a final board version. Would that be a fair approach?
Tiny motion control board, although likely to pack an incredible power (thanks to the Rio Cult!!). Still plenty real-estate for the translation and other upcoming gizmos.
  • garthnoakes
  • garthnoakes
06 Aug 2024 17:08
LED to indicate M3/M5 status was created by garthnoakes
Category: GladeVCP
Hi
Is there an example on the forum of how to do this? I guess it would just be based on the relevant HAL pin?
If M3 is active, I would like a large red icon, if M5 is active either a grey version of that or nothing
  • AndyDM01
  • AndyDM01
06 Aug 2024 16:45
Ethercat installation from repositories - how to step by step
Category: EtherCAT
Screenshots should do just fine, upload her on the forum under the editor click on "attachments"
how to get screenshots ? push the PrtScr button ? I can also add pictures ?
  • AndyDM01
  • AndyDM01
06 Aug 2024 16:35 - 06 Aug 2024 16:42
Category: EtherCAT
also might be interesting to mention that you need to have a wired internet connection to do the install... probably because i missed some part in the 1330+ pages to read , i tried to get stuff done over wifi... it's not working over wifi
I hope that i will get linuxcnc-ethercat to work and i will for sure make a contribution to the forum with how i got it to work. super detailed ... taking notes about everything ... imagine when everybody was saying ... " when pc's will be completely integrated in modern society , the usage of paper will be decimated!" hahahahahahahahahhahahahahahha
  • PCW
  • PCW's Avatar
06 Aug 2024 15:55 - 06 Aug 2024 15:56
Hardware advise mesa boards for control-loop with motor-encoder and linear scale
Category: Driver Boards
There is really no control mechanism that can compensate for backlash
in a very satisfactory way, especially if the cutting forces can reverse.
Linear scales can compensate for ballscrew thermal growth, and flex
in the drive system in response to acceleration and cutting loads.
With any system you would need a way to read the scales and combine
the scale information with the main position loop.
Typically 2 PID loops would be involved as the tuning of the scale feedback
would have lower bandwidth than the much more tightly coupled rotary
encoder feedback.
  • AndyDM01
  • AndyDM01
06 Aug 2024 15:54 - 06 Aug 2024 16:02
Category: EtherCAT
I am a little bit confused about what to download, the one Rodw put on google drive or the one that was posted on 03/08
because I got the same errors about the opensuse stuff
it was really hard for me to get my boss to agree with changing from his hacked mach3 shit to linuxcnc with ethercat ...
  • Willemsjos
  • Willemsjos
06 Aug 2024 15:32
Thanks.
Do I read between the lines, that you think it hardly makes sense?
If the hardware would be “perfect” with no backlash at all, there would'nt be an necessity for linear scales… And with backlash it is “problematic”.
Originally, the machine had tacho’s on the motors, to detect the motors were spinning and to control theirs rpm... Based on the position measurement of the linear scales (distance to go), the loop was closed until position was reached.
Would that principle be different if I would use step/dir instead of analog +/-10VDC in the old situation? The resolver needs at least 10x higher resolution than the 1um resolution of the linear scales I presume….
And is there then a necessity for a drive with two resolver inputs? Or can a controller-card take over the correction of backlash (which will be in any case)
Do they even exist without paying the highest price?
  • juliankoenig87
  • juliankoenig87
06 Aug 2024 15:31
Replied by juliankoenig87 on topic Probe panel for Axis GUI
Category: AXIS
In the xml you can change mm to inch for the tab. Thats just optical change.
  • juliankoenig87
  • juliankoenig87
06 Aug 2024 15:30
Category: AXIS
In the probe_pocket macro:
#<ff_distance> = 5 (5 mm distance to contact with fast forward speed)
Just change accordingly.
  • PhilipME
  • PhilipME's Avatar
06 Aug 2024 15:29 - 06 Aug 2024 15:36
Replied by PhilipME on topic G53, and G54
G53, and G54
I dont have homing (I bought the limit switches but did not install them yet )
So every start I have to zero x,y,z and that will be my G53 every time.
What I am doing now is G53 G0 x0 y0 then I shut the machine
next start I will set x, y to zero again to set g53 again. For some reason G54 is saved. But it is useless if G53 is lost.
Philip
Edit :
apology
I just realized that my question has no meaning.
I have to install the limit swiches, be able to home, then G54 will work because it is saved.
  • OGMaker
  • OGMaker
06 Aug 2024 15:24
[ Vfdmod ] An easy VFD control over MODBUS RTU
Category: HAL
File Name: vfdmod-0.3...md64.zip
File Size:33 KB
It looks lilke aekhv has pulled the project :-( There are are forks of it, but forking doesn't capture the wiki or the project or the releases. I'll attach the debian 3.2 release in case you still want to use it..
  • TheRoslyak
  • TheRoslyak's Avatar
06 Aug 2024 15:21 - 06 Aug 2024 15:22
Replied by TheRoslyak on topic Monitoring SDO value
Category: EtherCAT
Since no advice was forthcoming, I decided to develop my own component that can monitor and change SDO parameters.
Essentially, this will be a similar component to the one currently working with EtherCAT LinuxCNC but specifically for manipulating SDO data. Unlike the existing driver, it will work with YAML, which is much more convenient than XML.
An approximate example of such a file will be attached. If there are any suggestions, I would be happy to hear them.
I think I will start this week and finish in about a week. Later on, it will be possible to integrate the old functionality for working with PDO.
Although the current one works well, it has its drawbacks.
PS Admins, please add yaml and yml formats to the editor.
  • juliankoenig87
  • juliankoenig87
06 Aug 2024 15:13
Category: AXIS
Yeah inches...
Ok. There are two minor things to change. I am currently not at home but can answer later in more detail.
One is the fast forward in between a pocket. Here I use 5 mm to the estimated contact to use faster speed while probing. 5 inches just leads to the fact that there ist no faster movement.
The second one you find yourself. I have some (yes I know quick n dirty programmed) safety functions. In inches the values are way smaller so that the macro thinks that the probe is not calibrated.
Can you show your tool table please.
Julian
  • OGMaker
  • OGMaker
06 Aug 2024 15:11
Category: HAL
If you having trouble finding it, see github.com/thestealth131205/vfdmod
I'm not sure if the project has been hijacked, or the original owner changed his login without realizing the impact on his links. The good part is that the bits are all still there. I'll be making a fork to have a backup in case it goes away...
  • PCW
  • PCW's Avatar
06 Aug 2024 15:01
Replied by PCW on topic 3 Achs Fräse mit MESA 7C80 und Raspi 4
Category: Deutsch
The spindle output is _not_ a PWM output but rather
an isolated analog output used to replace the potentiometer
of a VFD.
If you need a 5V PWM signal, you would need firmware
that includes a pwmgen with an output on a 5V pin
7c801p_5abobd.bit
Is one, this replaces STEP5 with a PWM output
Displaying 23221 - 23235 out of 25505 results.
Time to create page: 0.786 seconds
