  • besriworld
  • besriworld
08 Sep 2024 15:47
Replied by besriworld on topic Fanuc 2S AC spindle motor on Delta C2000+
Category: Milling Machines
Try a slower acceleration
  • Mtndrew77
  • Mtndrew77
08 Sep 2024 15:40
Replied by Mtndrew77 on topic Threading with A B phase only?
Adam, Still running fine however I really only use it a few times a year. I can't believe its been 8 years. I don't really have any suggestions. Did you get yours converted over?
  • spumco
  • spumco
08 Sep 2024 15:06 - 08 Sep 2024 15:08
Probe Basic - startup error on new installation
Category: QtPyVCP
Just installed a fresh load of Debian 13 and followed the APT-installation instructions for Probe Basic.
One error reported during install (gpg keys, 'server error).
LCNC starts no problem.
On first run of the Probe Basic sim I get the following:
Warning: Spoiler!
Switched from Development to Stable, same error.
Any ideas?
08 Sep 2024 15:05
Replied by tommylight on topic Automatic Gantry Squaring
Category: HAL
No component required, it is a normal feature since 2.8, see ini homing
linuxcnc.org/docs/html/config/ini-homing.html
Basically, set the HOME_SEQUENCE to -1 or -2 for the tandem joints in the ini file and adjust the HOME_OFFSET value as you need it to square properly.
PncConf will do this automatically if you choose a tandem axis/joint, probably StepConf will do the same but i am not sure.
08 Sep 2024 15:01
Replied by tommylight on topic USB ports quit working?
Category: Installing LinuxCNC
Yeah, i keep several PS2 keyboards around, just in case. :)
Although most PC i have do not have PS2... I miss that, no latency, not really noticeable except when gaming on arena shooters.
08 Sep 2024 14:56
Replied by tommylight on topic Mesa 7i96 Output Wiring
Category: Driver Boards
---This has NOTHING to do with the subject, it is a public announcement to be careful on the internet!!!---
Those pictures are proof of how bad the internet has become, notice the L and N marks, that would imply mains voltage (110V or 220V) as L stands for a phase and N for neutral, yet this is for a low voltage DC equipment that clearly has marks + and - on the board.
08 Sep 2024 14:49
What do you really get for a $350 desk top engraver ?
Category: Show Your Stuff
Keep on chugging along, utmost respect for your persistence and effort.
  • spumco
  • spumco
08 Sep 2024 14:49
Replied by spumco on topic USB ports quit working?
Thanks anyway Tommy.  Wouldn't have helped - keyboard & mouse quit working past the GRUB screen.  No way to type in "ls" comands or anythign else.
  • ekbiker
  • ekbiker
08 Sep 2024 14:48
Automatic Gantry Squaring was created by ekbiker
Category: HAL
Does anyone have a .hal snippets for using gantry component in LinuxCNC 2.9.3 for automatic squaring in their homing sequence?
  • swepeter
  • swepeter
08 Sep 2024 14:40
Replied by swepeter on topic Mesa 7i96 Output Wiring
I believe they do. a led there at least
  • PCW
  • PCW's Avatar
08 Sep 2024 14:29
Replied by PCW on topic Mesa 7i96 Output Wiring
That look correct as long as the valves have flyback diodes
(it looks like they do)
  • Aciera
  • Aciera's Avatar
08 Sep 2024 14:28
Replied by Aciera on topic Using a HAL pin in DH parameters
Category: HAL
The pyvcp panel only exists after the gui has loaded, so you will need to put that line in the POSTGUI_HALFILE
  • PCW
  • PCW's Avatar
08 Sep 2024 14:26
Replied by PCW on topic 7i97t with 7i85?
7i97t with 7i85?
Yes, if the cable is HDR26F on one end and DB25M on the other
(the link does not work)
  • Abdulkareem
  • Abdulkareem
08 Sep 2024 14:25
Replied by Abdulkareem on topic Using a HAL pin in DH parameters
Category: HAL
tried it but it gives this error
Displaying 23506 - 23520 out of 23571 results.
Time to create page: 0.471 seconds
