  • tuxcnc
  • tuxcnc
14 Jun 2026 15:39
Replied by tuxcnc on topic Chinese Mesa 7I92 from aliexpress NEW
Category: Driver Boards
The "error finishing read" has nothing to do with jitter or ping time.
In short, this means network conntroller works well, but breaks connection after some time.
Cause may be the corrupt hardware, bad network driver (try DKMS), or bad kernel version (try other and beware upgrades).
  • jarcysgru
  • jarcysgru
14 Jun 2026 15:21
Replied by jarcysgru on topic Ucięty widok AXIS
Ucięty widok AXIS
Co mam podać ?
  • karlhe
  • karlhe
14 Jun 2026 14:43
Replied by karlhe on topic linuxcnc ohne endschlter
Hallo,
ich habe über die stepconfig eine neue Maschine angelegt,
die Endschalter entfernt. Alles gespeichert. Referenzpunkte manuell
angefahren. Dann in die Mitte der Aufspannplatte gefahren und jede
Achse genullt. Programm eingelesen und gestartet. Die Maschine und Steuerung haben alles prima ausgeführt
Meine Maschinenkonfiguration probetap kann ich in stepconfig nicht
einlesen, da alle Enstellungen dann gelöscht werden.
Viele Grüße karlhe
  • Aciera
  • Aciera's Avatar
14 Jun 2026 13:16
please help five Axis with Vismach simulation and Mesa 7i96S
I'm sorry but you do not provide ANYWHERE near enough information to give further assistance.
14 Jun 2026 11:21
Replied by tommylight on topic Ucięty widok AXIS
Ucięty widok AXIS
More info?
  • PedPEx
  • PedPEx
14 Jun 2026 11:14
Beckhoff EL5021 Modification: 1 V_pp and 11 µA_pp multi signal input
Category: EtherCAT
Hello all :)
I recently briefly mentioned my EL5021 modifications in my Maho MH400E retrofit discussion. Due to three additional terminals requiring the same modification, I decided to write a guide on how to modify the Beckhoff EL5021 encoder input terminal for both 1 V_pp as well as 11 µA_pp signals (and in theory TTL signals too - untested).
For anybody who's interested, the detailed guide can be found over on GitHub:
github.com/PedPEx/EL5021_multi-signal-mod
A video of a modified EL5021 reading 11 µA_pp signals from a Heidenhain LS403 linear glass scale is also available on YouTube:
If you have any further questions or suggestions, feel free to open an issue, reply here, or write me an email. :)
  • jarcysgru
  • jarcysgru
14 Jun 2026 10:41
Ucięty widok AXIS was created by jarcysgru
Ucięty widok AXIS
Tak jak w temacie mam uciety widok AXIS , brak napisu narzędzia jak to naprawić w linuxcnc 2.9..8.
  • Alex
  • Alex
14 Jun 2026 10:25 - 14 Jun 2026 10:26
Now it is running, i made ini and hal with Ki.
When running a toolpath in Vismach simulation it shows perfect but the machine makes strange things.
In fact I have not reaaly a plan what setting i need in Linux for 5 Axis...
Scale is correct
  • bedouno
  • bedouno
14 Jun 2026 02:30
Replied by bedouno on topic HAL component for tangential knife
Category: HAL
you did it master rod , it was hard , congratulations and thank you
  • jayem1427
  • jayem1427
14 Jun 2026 01:13
Replied by jayem1427 on topic My Ethercat Journey
My Ethercat Journey
Category: EtherCAT
I heavily leaned on Cursor (an IDE with integrated LLM) to setup my recent ethercat build. For best results, feed your LLMs documentation and examples. And keep requests to small, easily testable bites. And for sure learn version control through Git. My repo can be found here for reference: github.com/jayem1427/lemontart_lcnc_config
  • Masiwood123
  • Masiwood123's Avatar
13 Jun 2026 23:51
Replied by Masiwood123 on topic Axis 2 - touchscreen version of old friend
Category: AXIS
zack sorry for the delay, I just tried it, but it's definitely not for small screens, not just axix2 but any, only for repetitive operations on machines where it's not that important....the letters in the preview are unreadable, the rest are large. thanks
13 Jun 2026 22:40
  • hermano
  • hermano
13 Jun 2026 18:37
neuer linux cnc nutzer hat probleme mit steuerkarte
Category: Deutsch
Hi
danke erstmal fürs melden
mein problem ist hab alles durch was geht, von der hal datei bis zum messen vom Lpt kabel, die motoren funktionier einwandfrei und laut karte ist relais auf pin 17 , wenn ich pin 17 inventiere schaltet das relais beim starten von programm ein das heist irgent was passiert ja , aber mit M3 (plasma On) passiert nix mehr , egal ob invertiert oder nicht oder auch andere pins 16,15
  • jeffmaxwell
  • jeffmaxwell
13 Jun 2026 18:22
Replied by jeffmaxwell on topic Steps to make a bootable USB to install LinuxCNC.
Thanks. Looks like it's working now.
  • Aciera
  • Aciera's Avatar
13 Jun 2026 18:09
Replied by Aciera on topic linuxcnc ohne endschlter
Ja, das geht grundsätzlich schon aber da du (vermutlich) die Endschalter auch zum Referenzfahren verwendest musst Du dann den Maschinennullpunkt auch manuell bestimmen.
Um ohne Referenzfahrt MDI Befehle und Programme ausführen zu können musst Du in deiner INI Datei in der [TRAJ] section diesen Eintrag einfügen:
NO_FORCE_HOMING = 1
Nachdem Starten musst du die Maschine per Jog an den Nullpunkt verfahren und den Koordinatennullpunkt (zg G54) setzen.
Zusätzlich kann es sein, dass durch den Ausfall der Endschalter nun ein oder mehrere Signale in der hal Datei gelöscht werden müssen falls es dadurch nun zu Fehlermeldungen wegen aktiven Endschaltern kommen sollte.
Displaying 2491 - 2505 out of 13411 results.
Time to create page: 2.148 seconds
