  • endian
  • endian's Avatar
14 Jul 2024 20:17
Ethercat installation from repositories - how to step by step
Category: EtherCAT
hello rod,
can you help me locate ethercat-master folder from where is installed ethercat-master on your hybrid.iso file... I need to change network drivers if it is possible... is it possible to change it please?
  • my1987toyota
  • my1987toyota's Avatar
14 Jul 2024 20:02
Has Anyone used DeskProto was created by my1987toyota
Category: CAD CAM
  So for the most part I use Autodesk fusion 360 and it works fine until you go to use the multi axis option
in the Manufacturing section to find it's kept behind a pay wall. $85 per month or $680 per year and that's
on top of the regular subscription price. It's Just another reason why subscription based CAM is a losing
proposition for anyone not using it on a commercial basses. I would be using it for
generating G code for my CNC foam lathe project and need to be able to sync. the spindle to the "bit"
( actually a soldering iron ). One of the alternative software's I have come across is DeskProto. It looks
like it is a buy a license type of program not a subscription service. see link, and the bottom of it's page
www.deskproto.com/products/comptable.php
The big question is has anyone else used this software and if so how do they like it ? Would they
recommend it? Lets face it FreeCAD doesn't have 4 to 5 axis capability. At least not yet.
  • Aciera
  • Aciera's Avatar
14 Jul 2024 19:52 - 14 Jul 2024 19:54
Brauche bitte Hilfe bei der Steuerung des Werkzeugrevolvers
Category: Deutsch
OK then, that machine can not work, the motion of the X axis must be always in relation to the center of the part, here it is at what looks like 40-45 degrees.
Hm, not sure what I'm missing here but slant bed lathes have been around for a long time. All that is required is:
- Z-axis must be parallel to the spindle axis
- X-axis must be perpendicular to the spindle axis
- cutting edge of the tool must move on a line that passes through the center of the spindle
The first two requirements are clearly fulfilled and I would certainly hope that the builder of the machine has made sure that the tool pointing 45° down will be the correct height to fulfill the third as well.
  • RMJ fabrication
  • RMJ fabrication
14 Jul 2024 19:10
qtplasmac (Operation Error: hm2/hm2_7i76e.0:) in middle of cut
Category: Plasmac
I replaced the thermal paste on the cpu and I am still getting this error at lower temperatures.
here is a ping test
  • my1987toyota
14 Jul 2024 17:47 - 14 Jul 2024 20:06
Replied by my1987toyota on topic CNC Foam Lathe
CNC Foam Lathe
Category: Turning
  So my first obstacle doesn't even have to do with the machine, it has to do with my cad/cam program.
I had never needed to use more then 3 axis of movement before so it wasn't until today that I realized
fusion 360 won't allow synchronized turning without paying extra for the add-on. Keep it up Autodesk
I am really close to fully abandoning Windows and fusion 360 altogether. the Question now though
is do I just treat the models as 3D and add the 4th axis manually or can I repurpose the third axis as
a rotary axis? I guess there's always DevCAD.  More research is needed.
14 Jul 2024 16:28
Category: Deutsch
The carousel component is included with LinuxCNC, see:
linuxcnc.org/docs/stable/html/man/man9/carousel.9.html
  • Project_Hopeless
  • Project_Hopeless's Avatar
14 Jul 2024 15:30
Replied by Project_Hopeless on topic How To Setup for 5 or 6 DOF Robot
Category: PnCConf Wizard
Ok, so I have loaded the firmware (7i96s_5abobrcd) with MesaCT and I think I'm good there.  I created a basic XYZA config.
My plan is for 5 step/gen on the 7i96s and 1 step/gen and PWM servo on the BOB.
Manually editing the *ini file to add the remaining axis seems straight forward.  Any tips??
The sim examples I've followed so far don't have any hardware specific details.  Does anyone have an example config with step/gen across two cards, one being a BOB?  How, or do I edit any of the HAL files to add the BOB.
  • GeckoWorks
  • GeckoWorks
14 Jul 2024 15:28 - 14 Jul 2024 15:32
Sorry, Another 'Which Mesa?' Post. (Yes, I read Spumco's magnificient guide)
Category: Driver Boards
If there is a choice, I  prefer sourcing outputs and sinking inputs
Good point on the need for less IOs than I initially feared. But since I am based on a small island in the Phillippines and the board(s) will take a decent while to get here, I thought the smart move would be to get a daughter card instead of having to order again later, just in case.
I'll go with your preference then as it easily trumps my zero experience. So, 7i96s + 7i84.
Thanks for the help to you and Corn:)
  • Roguish
  • Roguish's Avatar
14 Jul 2024 14:52
Replied by Roguish on topic Spindle Inhibit while Probing.....
Category: Qtvcp
thanks. I'll watch and see when it gets pushed to the master .deb
then give it a try.
it would be best if it could be consistent in all qtdragons.
and of course, included in the documentation.
  • PCW
  • PCW's Avatar
14 Jul 2024 14:43
Also as I mentioned before, you likely need much fewer I/O
points than you think for enable or alarm as they can almost always
be combined.
  • WKS-3D
  • WKS-3D's Avatar
14 Jul 2024 14:22
Category: Deutsch
Sorry aber es geht schneller im English:
Are those two separate machines or is that a single machine in it's final state?
To run the tool changer you can use the included Carousel component, it support plenty of changer types.
It is a single machine.
Where can I find these prefabricated components?
When the whole configuration is completed, I would like to switch to the Probe_Basic_Lathe interface.
I am currently using AXIS for setup.
14 Jul 2024 14:13
Way, wayyyyy to much.
Must be under 50$, otherwise PC and Mesa.
Sorry to repeat this, but humans should really wake up and stop buying 200$ SBC that can do nothing particularly well. Anything over 50$ is to much.
14 Jul 2024 14:07
Category: Deutsch
14 Jul 2024 13:53
Displaying 24931 - 24945 out of 25530 results.
Time to create page: 0.790 seconds
