  • Lcvette
  • Lcvette's Avatar
15 May 2024 05:18
Replied by Lcvette on topic Preview doesn't match actual program path
Category: QtPyVCP
Awesome! Thanks TurBoss!
  • Lcvette
  • Lcvette's Avatar
15 May 2024 05:17
Replied by Lcvette on topic Can't jog the machine
Category: QtPyVCP
You need to turn off all screen saver and power saving modes.
  • rodw
  • rodw's Avatar
15 May 2024 05:11
Replied by rodw on topic Is QtVCP better than QtPyVCP ?
Category: QtPyVCP
Qtvcp is much better documented on the Linuxcnc web site. The qtdragon GUI is very good.
The GUI's typpically don't use C++ but the real time side of linuxcnc (Components and core code) is based on C. Some parts are in C++ but the core code predates C++
  • rodw
  • rodw's Avatar
15 May 2024 05:07
Announcing Deckard: StreamDeck support for LinuxCNC
Category: Show Your Stuff
I would rather buy an industrial wireless pendant/MPG for similar money.
This is another topic, but those wireless MPG's have never seemed like a great idea to me.  They look convenient, especially for large routers or plasma tables, but potentially fraught with peril.  How robust is the wireless protocol, and how exactly does it behave with potential interruptions/interference?  I definitely sleep better using hard-wired controls for potentially dangerous and expensive CNC machines.
I saw one with an mushroom E-Stop on it, which seemed optimistic at best.  I don't think that would pass any sort of safety system design review.  It could be designed to fail safe if the wireless link drops out, but then if you had a brief interruption of the wireless link, your whole system would go into E-Stop and potentially ruin work or tools.  If it's more tolerant of wireless dropouts, then it no longer is truly safe as an E-Stop.
I would much rather have a dumptruck hardwired operating in real time than a Ferrari dependent on a USB connection!
I belive the 433 MhZ pendants I use are compliant and include a dual circuit estop. Here is the receiver. I have used one for 7-8 years and it never let me down.
  • Utilitas
  • Utilitas
15 May 2024 05:06
Replied by Utilitas on topic 7i96S PSU
7i96S PSU
Category: Driver Boards
Just thought I would upvote the din rail MDR-10-5 and also mention the NDR-120-24v as a possible option for
the drivers depending on the max current requirements for your motors.
Using din rail power supplies can help to keep things more compact and tidy.
(I bought a MDR and a couple of the SDR (an upgraded NDR) series for the mill I am currently building and
really liked how much more convenient they were compared to the computer PSU I was working with initially.)
If you can get by on just 12v/5v, the computer PSU could be an option on a budget, I had one laying around so
my build started out using one, but it mostly got replaced by the mean well supplies I upgraded to. Keep in mind
that some hardware does not like to have input power supplied through a switch, it may not be the most practical
to have all of your power supplied from one source...
  • hachi
  • hachi
15 May 2024 04:53
I want to use QTAxis, is it meant to be used?
Category: Qtvcp
@cmorley I've created github.com/LinuxCNC/linuxcnc/pull/2977 because I think this change could be good for people in general (not just my customized machine)
I tested edit mode and get what I think is the right behavior from it (maximizes to window and shrink back down again)
Resizing the window seems to have reasonable behavior, the size of the splitters are implicitly saved by the preferences it seems.
There is an open question of whether things should be collapsible or not, right now the gcode_editor splitter is collapsible, but the other is not. Let me know if you want me to change this, or if you want me to just ditch the PR because you don't want it.
Thank you for all your help on this.
  • rodw
  • rodw's Avatar
15 May 2024 04:47
Replied by rodw on topic Run linuxcnc as root user
I might be wrong but from my memory linuxcnc does not like being run by the root user. Certainly compiling hte source as root creats all sorts of issues. I found that out the hard way.
What you could do is build linuxcnc from source via RIP as a specific user and that will place all of the executables in that users home folder. The linuxcnc folder will also be there too. Its pretty easy to do. I did a tutorial of it.
So other users can be set up as another user and they will never see any access to linuxcnc and root is not used at all.
15 May 2024 04:13
Replied by Cant do this anymore bye all on topic LinuxCNC on Raspberry Pi 5
Category: Installing LinuxCNC
Hello all,
first thanks so much for building this image - it really works nicely (although I still need to get my touchscreen working but assuming this is just a driver issue).
The main question I have before connecintg and configuring a MESA card is that my latency looks decidedly wrong - I am wondering if I have the RT kernel enabled at all? When I make uname -r, I get this, which doesn't mention RT:
6.6.28+rpt-rpi-2712
All I did was load the GDrive image a few posts ago, and run a update && upgrade.
Is there any way to check and correct?
Blindly running an update is not a good idea.
The easiest way is to reflash the image. The kernel really should have been "pinned" to prevent updates. The RT kernel is a "custom" one.
So you really shouldn't be updating, it's fine as is.
If you are the type that "must update" read this
www.snel.com/support/how-to-block-packag...l-updates-in-debian/
  • phillc54
  • phillc54's Avatar
15 May 2024 02:46
Replied by phillc54 on topic New set of problems
New set of problems
Category: Plasmac
Can you post the g-code file for the above cut and also the BACKUP from the SETTINGS tab.
  • rdtsc
  • rdtsc's Avatar
15 May 2024 01:58
Replied by rdtsc on topic LinuxCNC on Raspberry Pi 5
The <SHIFT> key may drop the Pi into diagnostic boot mode.  <ESC> likewise does not work on the Rpi.  From what I'm reading at places like raspberrypi.stackexchange.com/questions/...which-kernel-to-load changing the kernel is more than tricky on the Pi and involves moving/building kernel images manually and editing config.txt.  It would certainly be easiest to just use the ready-made Debian Rpi 4/5 LinuxCNC build found here: linuxcnc.org/downloads/  Just burn it using your favorite flashing software (Rpi Imager, Balena Etcher, etc.)
Do note that the Rpi 5 uses a new and incompatible SPI chip, so vendor boards which use SPI are currently a no-go.  Rpi said they may release the details of their new chip sometime in the future, but not anytime soon.
15 May 2024 00:29
Replied by tommylight on topic Foundational questions about my setup
That is quite an improvement ! :)
  • PCW
  • PCW's Avatar
15 May 2024 00:22
Replied by PCW on topic 2.9 vs 2.7 tb6560
2.9 vs 2.7 tb6560
I would think they would be nearly identical
though the configuration utilities may have improved
a bit (plus 2.7 is pretty old)
15 May 2024 00:20
Replied by Cant do this anymore bye all on topic Run linuxcnc as root user
With regards to “security” with Linuxcnc.
It really comes down to who has access to the machine. I feel once the “bad guy” has physical access it’s the damage that can be done to the cnc machine whilst running linuxcnc. It’s not like you’re running a server with sensitive info, you’re running a piece of equipment that can either harm personnel or damage itself.
First rule of security is physical security of the machine. Once an unauthorised person get physical access to your cnc machine I can guarantee it’s not the file system on the computer you’ll be “shitting bricks” about.
  • hachi
  • hachi
15 May 2024 00:08
Category: Qtvcp
Just a quick note on my supposition above, I'm not sure of this... and I'm not trying to lob it out and say it's a bug report, but the whole problem of editor/preview/interpreter loading of the file seems to be disconnected to me and I want to learn why.
  • stupiddon
  • stupiddon
14 May 2024 23:42
2.9 vs 2.7 tb6560 was created by stupiddon
2.9 vs 2.7 tb6560
Is 2.9 easier to setup the configure for tb6560 than 2.7
Displaying 26491 - 26505 out of 26555 results.
Time to create page: 0.522 seconds
