  • meister
  • meister
21 May 2026 08:52
very strange :(
i can only test in simulation at the moment, can you try it also in simulation mode please !?!
bin/rio-generator -S carrot.json
  • Tim Bee
  • Tim Bee
21 May 2026 08:37
meister:
I redownload rio in a new folder, and used new gui rio-flow to config again
PCB is build by myself, it used a 12Mhz oscillator
Tim
  • ziggi
  • ziggi's Avatar
21 May 2026 06:07
Stmbl V5 Drive for Sale was created by ziggi
Category: User Exchange
Some time ago I purchased a Stmbl V5  drive, but never used it. Means it is new, unused.
I would ask 120€ including shipping to Germany or Austria- current price for a ready Stmbl V5 is ~220+ shipping from what I remember
So if one would need this to play around with contact me via email please  This email address is being protected from spambots. You need JavaScript enabled to view it.
  • meister
  • meister
21 May 2026 05:04
hmm, i see the 1.0 velocity
Which version are you using?
# git status
  • andrax
  • andrax's Avatar
  • Tim Bee
  • Tim Bee
21 May 2026 01:39 - 21 May 2026 01:45
meister:
my json file
and sorry about the frequecy I write wrong: when command is :G53 G01 F60 X100output pules frequency is about 1.28khz
because my scale is 1280, when F60 (1mm/s), output frequency is 1280 * 1 = 1.28Khz
the stepdir.velocity is show about 0.5mm/s
Tim
  • rodw
  • rodw's Avatar
20 May 2026 21:42 - 20 May 2026 21:50
Replied by rodw on topic Lichuan CL57E Very Basic Setup
Category: EtherCAT
Great work! When I first tried lcec_configgen, the output was useless, common on multiaxis drives. But recently I tested it after some changes made by Grandixximo and he now has an inbuilt driver for the OL drive so its even easier than this xml you used. And yes, it think it will work for the open loop version too. He should see this and might be able to extend the OL driver to support this too
  • PCW
  • PCW's Avatar
20 May 2026 21:31
Replied by PCW on topic Mill Retrofit with Fanuc DC Drives
Category: HAL
Looks OK
Might be worth disconnecting the analog hal pins in hal and just setting them
manually (connected and unconnected to the drive) to see whats going on.
  • tbrasselle
  • tbrasselle
20 May 2026 20:19 - 25 May 2026 18:49
Replied by tbrasselle on topic Mill Retrofit with Fanuc DC Drives
Category: HAL
Yes. I am connecting to the two honda connectors labeled J10 and J5 on this diagram.
Please let me know if you see any mistakes in this.
Machine side       ->      Mesa 7i83
Pin 1, PRDY1X    ->      TB2, Pin 1, ENA0-
Pin 2, ENBL1X     ->      TB2, Pin 1, ENA0-
Pin 3, OVL1X       ->      No Connection Currently
Pin 4, VRDY1X    ->      No Connection Currently
Pin 6, TSAX         ->      TB2, Pin 16, AOUT3
Pin 7, VCMDX     ->      TB2, Pin 4, AOUT0
Pin 13, 0G           ->      No Connection Currently
Pin 14, PRDY2X  ->      TB2, Pin 2, ENA0+
Pin 15, ENBL2X  ->      TB2, Pin 2, ENA0+
Pin 16, OVL2X    ->      No Connection Currently
Pin 17, VRDY2X ->      No Connection Currently
Pin 19, TSBX      ->      TB2, Pin 15, AGND
Pin 20, ECX        ->      TB2, Pin 3, AGND
Machine side       ->      Mesa 7i85
Pin 1, 0V         ->      TB3, Pin 3, GND
Pin 2, 0V         ->      TB3, Pin 3, GND
Pin 3, 0V         ->      TB3, Pin 3, GND
Pin 4, +5V       ->      TB3, Pin 6, +5V
Pin 5, +5V       ->      TB3, Pin 6, +5V
Pin 6, +5V       ->      TB3, Pin 6, +5V
Pin 8, OH1X    ->      No Connection Currently
Pin 9, OH2X    ->      No Connection Currently
Pin 14, PCZX   ->      TB3, Pin 7, IDX0
Pin 15, *PCZX  ->      TB3, Pin 8, /IDX0
Pin 16, PCAX   ->      TB3, Pin 1, QA0
Pin 17, *PCAX  ->      TB3, Pin 2, /QA0
Pin 18, PCBX   ->      TB3, Pin 4, QB0
Pin 19, *PCBX  ->      TB3, Pin 5, /QB0
  • meister
  • meister
20 May 2026 18:07
The only parameters that affect the frequency are
* stepdir0.velocity
* stepdir0.velocity-scale
* stepdir0.velocity-offset
and the FPGA clock frequency
Could you please attach your .json file?
  • NTULINUX
  • NTULINUX's Avatar
20 May 2026 15:42 - 20 May 2026 16:02
Gentoo Image, Which Applications are in and Which are Out
Huge update everyone! My Gentoo image now ships with LinuxCNC preinstalled, many bugs were fixed, and a lot of packages were added. The image size grew by quite a bit but this functions more as a complete Linux system with some extra applications such as GIMP and Krita. Browser has been switched to Konqueror and 4K videos on YouTube play excellent on my old GPU.
github.com/NTULINUX/gentoo_backup/releases/tag/v0.4-alpha
Same instructions as before, still no RTAI support but I'll get there eventually. The issue before was that I was trying to stay under the 2GB file limit on Github, but now since I split the tar into 2 files, this gives me more range. It is now ~3.3GB in total for the download, and the minimum space requirement has been bumped as well (16GB minimum for the root filesystem)
This ships with the following packages, list not complete:
FileZilla
GIMP
Krita
Inkscape
FlexGUI
mesaflash
halviewer
LinuxCNC
Hexchat
Konqueror
NetworkManager (with applet)
XFCE
LXQt
guvcview (camera)
Kate
Geany
btop
htop
For qtpyvcp/probe basic:
git clone https://github.com/NTULINUX/qt_pb
cd qt_pb
./qt_pb.sh
  • Tim Bee
  • Tim Bee
20 May 2026 14:34
Dear meister:
I used MDI command to move x axis for a example. The velocity is 60mm/min, and used halshow to watch pin:rio.stepdir0.velocity
the value is about 0.5mm/s, but the motor run in right speed,and I probe the x axis's pules signal used a oscilloscope
and it show the freqency is about 12.78khz, my scale is 1280 in .ini file
if I use stepdir to drive a servo motor to run a spindle, I net the spindle rps to some one stepdir.velocity then spindle run in a wrong speed
whitch parameter I set wrong?
Tim
  • PCW
  • PCW's Avatar
20 May 2026 13:17
Category: HAL
Do you have a document for the actual driver pinout?
20 May 2026 11:56
Replied by tommylight on topic Trying to get analog joystick to control jogging
Category: Basic Configuration
It's a joystick, and those have been analog for the last 20 years or so, last digital joystick i had was 30 years ago.
In short, you are looking at the wrong thing, search for joystick, not for analog joystick, or xbox controller or PS2/3/4/5 controller, there are some here on the forum.
html.duckduckgo.com/html?q=linuxcnc%20joystick
Displaying 2986 - 3000 out of 13407 results.
Time to create page: 0.883 seconds
