  • PCW
  • PCW's Avatar
16 May 2026 16:12
7i76D Spindle Analog output changed overnight!
Category: Driver Boards
The original part was a NE5230, which is now obsolete, a suitable replacement is a THS4281D or a OPA197IDR
  • Konstantin
  • Konstantin
16 May 2026 14:58
Replied by Konstantin on topic CiA 402 Folder Missing
Category: EtherCAT
I achieved some kind of success in homing the servo motors using the CiA402 home component. There is still a problem when the homing is executed in a certain situation. Basically, I am using homing method 34. Then using the halshow I set  the 'request-custom-homing' pin, the homing procedure starts but when the servo find its Z pulse it start moving quite fast. Perhaps it tries to reach a certain position but LinuxCNC reports 'joint 0 amplifier fault' and the servo drive error is 'Position deviation is too large'. You can see videos of what is happening - one video in normal velocity and one in slow motion.  Videos
This behavior of the drives can be observed the the actual position is above 35 000 000 pulses. When the homing is started below this pulse number, the motor finds it Z pulse and the move quite fast to the position where the homing was started.
Attached are the configuration files.
16 May 2026 14:58
Replied by tommylight on topic Interface localization into Ukrainian
Category: QtPyVCP
Moved to "QtPyVCP" section.
16 May 2026 14:56
Replied by tommylight on topic Needing help to get started!
Category: Basic Configuration
Did you find anyone to help?
If not, post some pictures here, we are quite good at figuring out things from pictures and videos.
Also some pictures of the insides of control box would help a lot.
  • tbrasselle
  • tbrasselle
16 May 2026 14:29
Replied by tbrasselle on topic Mill Retrofit with Fanuc DC Drives
Category: HAL
Thanks again for help. I swapped both analogoutput0 and analogoutput3 to RG58 cable that I had laying around and had the same results. I also double checked the ground and shielding on the original wiring. i had disconnected one of the grounds but reconnecting it also did not change anything.It looks like the oscillation is at about 33Hz so I don't think it is from the main power. Another note, I change the base period on the servothred from 1000000ns to 800000ns to see if that changed anything. it seems to change the frequency slightly but it no affect on the amplitude.
  • harindugamlath
  • harindugamlath
16 May 2026 14:27
Replied by harindugamlath on topic 7i76D Spindle Analog output changed overnight!
Yes. First thing I checked is the HAL. This has been a machine that runs daily. no changes whatsoever.
That is exactly what I measured. Disconnected the analog out from the spindle drive, then measured. It's wildly non-linear. What Can I do? I live far away from US and don't really have a way to get a new one too. Can you provide the op amp model so that I can try to fix it?
Spindle drive did emit a bad EMI. I had to put filters in the power line of the PC. But didn't expect it to affect the analog out. 10V power is fed through a separate isolated 10V supply. spindle drive is a 11KW SZGH drive. This worked untouched from 2021 and did run daily without a hiccup. This was the only issue that I ever came across.
  • PCW
  • PCW's Avatar
16 May 2026 14:24
Replied by PCW on topic Mill Retrofit with Fanuc DC Drives
Category: HAL
I suspect its something with the tachometer emulation or connections to the Fanuc drive
How did the original drive get velocity feedback?
16 May 2026 14:24
Detailed FreeCAD 1.1 tutorial by DeltaHedra on youtube.
Category: CAD CAM
Bump to remove it from the "no replies" list.
16 May 2026 14:22
Replied by tommylight on topic Spindle configuration
Category: StepConf Wizard
Hello,
few days ago my laptop died
Does the hard drive still work?
If yes, yank it out and put it in the new PC, it should work without installing anything and the machine should work as before.
If the install has failed, you can use a USB stick with any Live Linux to read the existing config and copy it to another USB, then to the new PC.
Or just check what pin setup you had there.
  • PCW
  • PCW's Avatar
16 May 2026 13:37
Did you check the the analog command (xx.n.7i76.0.0.spinout) in hal is as expected?
that is 1000 for a 1000 RPM command with a scale of 10000
(in case you have feedback in the PID setup and there is a encoder issue)
If the analog spindle output (when disconnected from the VFD) is non-linear
relative to xx.n.7i76.0.0.spinout pin, it likely means the the OP-AMP buffer
in the analog output circuit has been damaged, perhaps by EMI from the VFD
  • harindugamlath
  • harindugamlath
16 May 2026 12:19
At lower end it's about twice the voltage, then the error gets lower as we go up. I also noticed spindle rpm glitching once. I have an encoder and had setup spindle at speed with that, That's how I noticed first. Then measured the voltages.
16 May 2026 11:53
Replied by tommylight on topic 7i76D Spindle Analog output changed overnight!
Even in this fuzzy state i do not think it is the board, i have over 70 or 80 (probably more) of them in daily use for over 10 years and none ever failed nor any hiccups nor any issues ever.
I'll shut up now ...
Then again moisture does cause issues ...
16 May 2026 11:49
Replied by tommylight on topic Mill Retrofit with Fanuc DC Drives
Category: HAL
No not twisted for that, shielded, RG58 or RG59 antenna cable if you do not have anything thinner.
Twisted cables are not for analog use.
Displaying 3061 - 3075 out of 13428 results.
Time to create page: 0.650 seconds
