  • xenon-alien
  • xenon-alien's Avatar
28 Apr 2026 19:03
Replied by xenon-alien on topic 7i96S card arrived what setup is recomended
Category: Driver Boards
In one picture you have the encoder inputs connected, this may affect test results.
Here is the encoder input circuit, you can check if the 26LS32 is faulty by seeing of the
outputs follow the input state. (the outputs are inverted from the TTL input levels)
Not really understand, but the result is the same, as it was with the TTL encoder.
Thanks for the hint how to check the 26LS32. Tomorrow I will try.
You think, maybe it can be the inputs to the main microchip if the 26LS32 works correctly?
  • Lcvette
  • Lcvette's Avatar
28 Apr 2026 17:33 - 28 Apr 2026 17:35
Probe Basic — 4-axis XYZB wrapped rotary backplot support
Category: QtPyVCP
@ davids
hmm i not even sure where i would start with that, seems pretty unique. I would maybe wait until the latest pyside6 version is released with docs on setting up the machine simulation and try there and report back. I am working on the docs now and then will be uploading the installation requirements for pyside6 for testers, will be a couple days while i try and find time to finish up the doc reconfiguration for bookworm/trixie separation.
  • Lcvette
  • Lcvette's Avatar
28 Apr 2026 17:29 - 28 Apr 2026 17:34
Category: QtPyVCP
@ dredivan
I just pushed an update on the develop branch for bookworm version that specifies the jog buttons to display based on the display>geometry= setting in the ini file, if you update and specify your desired axis buttons there for jogging it will be correct now.
  • davids
  • davids
28 Apr 2026 16:09
Category: QtPyVCP
Hi Lcvette,
Following up on your offer in this thread to test the multi-axis plotting / simulation branch — I'd like to put my machine forward as a test case. It's a different geometry from dredivan's MPCNC, so flagging that up front in case it's useful (or not) for what you're prototyping.
Machine: — 4-axis cylindrical/polar additive system tower-crane style. Not a wrapped-rotary gantry; the entire arm rotates around a stationary work area.
Configuration:
LinuxCNC 2.9.8 on Raspberry Pi 5 (Bookworm + PREEMPT_RT)
Mesa 7i96S
KINEMATICS = trivkins coordinates=XBZA kinstype=1 (joints 0–3 = X, B, Z, A)
Axes:
A — base rotation, 0–360° continuous, carries the entire Z tower + X arm + B head
Z — vertical linear, 0–2470 mm, rides up the rotating tower
X — radial linear, 952–2760 mm (radial distance from tower center to B housing — not Cartesian X)
B — end-of-arm rotation, ±90°, rotates about a vertical axis at the end of the X arm; B=0 means the 652 mm tool arm is aligned with the X arm (radially outward)
G-code is pre-computed in polar/cylindrical space by the CAM post-processor and emitted as dense waypoints in G93 inverse-time.
Sample line:
G93 G1 X2054.287 Z6 A118.183 B11.055 F423.731
→ B housing at radius 2054.287 mm, height 6 mm, base 118.183° CW, tool arm tilted +11.055° from radial; move duration ≈ 1/423.731 min ≈ 0.14 s.
Stock backplots render this as joint space and produce nonsense, which is why a wrapped/transformed preview would be a big deal for us. If the test branch can accept a custom transform (or already exposes a forward-kinematics hook for the canon), I can supply realistic .ngc files and run them on the actual machine.
let me know how I can be useful. Hope we can find a way for me to be a tester for your multi axis plotter!
— David
  • endian
  • endian's Avatar
28 Apr 2026 16:06 - 28 Apr 2026 16:23
Replied by endian on topic LinuxCNC and Beckhoff AX5000 servo drives
Category: EtherCAT
put all AX5xxx first and any other devices behind it ... if translator created the config it is pure master swap to linuxcnc master which is probably OK... but I am just a man and its just a software ...
check sizes of ethercat IDN in the SM and maybe subindexes ...
check if all you have 0x01 ... if they are not change them
share .xml config its tricky to tell you more if there is just small part of the dmesg outcome...
EtherCAT ERROR 0-7: Failed to set SAFEOP state, slave refused state change (PREOP + ERROR).
EtherCAT ERROR 0-7: AL status message 0x0045: "MBX_SOE".
move(means cut off where it is and put it at the bottom of the file) in init commands from anywhere to the bottom like below -
<InitCmd>
<Transition>IP</Transition>
<Comment><![CDATA[Report diagnostics information]]></Comment>
<Timeout>0</Timeout>
<OpCode>3</OpCode>
<DriveNo>0</DriveNo>
<IDN>33072</IDN>
<Elements>64</Elements>
<Attribute>0</Attribute>
<Data>0100</Data>
</InitCmd>
</InitCmds>
</SoE>
</EtherCATMailbox>
EtherCAT ERROR 0-0: Failed to set OP state, slave refused state change (SAFEOP + ERROR).
EtherCAT ERROR 0-0: AL status message 0x001A: "Synchronization error".
which ethercat driver you are using for control the AX ? generic or native
  • spumco
  • spumco
28 Apr 2026 15:55
Replied by spumco on topic (Solved) G43 not being applied in g-code
@Andrax
I'll try it, thanks.
@Maha
like @Aciera, I didn't think that was how M6/G43 worked, but I'll try it (again).  I've tried putting G43 on the next line after the Tn M6 (or M6 Tn) line, but that didn't seem to make a difference.
@Aciera
Thanks for pointing that out.  I think I tried the RETAIN_G43 when I first noticed an issue during the G10 L2 WCS flip testing a couple weeks ago.  I know I haven't turned that on/off during this last round of fiddling.
Among the many things confusing me is the F360 post for LCNC turning.  right at the beginning of the post file is this:
var outputG43OnSeparateLine = false;
But the post outputs no G43 at all - neither on the same line or the next.  Something to sort out once I get G43 working.
I'll try everyone's suggestions this evening and report back.  As usual, I'm grateful for the assistance.
  • cmorley
  • cmorley
28 Apr 2026 15:54
Replied by cmorley on topic Qtvcp GUI and hal pins
Category: Qtvcp
How did you get linuxcnc originally? What version are you using?
What mods would you like to do?
  • T_D
  • T_D
28 Apr 2026 15:39
Ich brauche Hilfe bei meinem Getriebe
Category: HAL
Hey zusammen,ich hänge gerade ein bisschen fest und hoffe, jemand von euch kann mir einen Schubs in die richtige Richtung geben ,Ich habe eine Maho 500 W4 mit einem Servomotor, der analog im Closed Loop läuft. An der Maschine ist ein 3-gängiges Getriebe verbaut:
1:1 (ca. 650–5000 U/min)
Neutral
Untersetzung (ca. 20–649 U/min)
Ist wohl ähnlich wie bei dem User Dowerna hier aus dem Forum.Mein Problem: Ich bekomme den Gangwechsel in LinuxCNC einfach nicht sauber umgesetzt. Ich hab mir das mit der
transm.comp von Dowerna angeschaut, aber ehrlich gesagt verstehe ich nicht so richtig, wie ich das bei mir einbinden bzw. anpassen soll
Alternative Ansätze kenne ich leider auch nicht wirklich.Zum Thema Skalierung bin ich ebenfalls etwas lost… da wäre eine kurze Erklärung echt Gold wert, wie man das korrekt aufzieht bei so einem Setup.Ich habe auch schon versucht, das Ganze über [code]gearchange (HAL Component) zu lösen, aber das hat bei mir leider überhaupt nicht funktioniert.Vielleicht hat ja jemand von euch sowas schon mal umgesetzt oder kann mir zumindest sagen, in welche Richtung ich denken muss. Danke euch schon mal!
[/code]
  • Aciera
  • Aciera's Avatar
28 Apr 2026 15:37
Replied by Aciera on topic (Solved) G43 not being applied in g-code
so G43 in a line with M6, sets G49
Not sure I understand this right but 'M6 Tn G43' certainly works fine for me.
@spumco
Have you tried without 'RETAIN_G43 = 1' in the ini file? (you have one line commenting it out and another later on activating it)
  • opw
  • opw
28 Apr 2026 14:57
Simple G7x Profile editor for Linuxcnc/Axis
Category: AXIS
It should, just try it, it is a small download and easy to try
  • PCW
  • PCW's Avatar
28 Apr 2026 14:24
This browser does not support PDFs. Please download the PDF to view it: Download PDF
  • abs32
  • abs32
28 Apr 2026 14:17
How to fix "Queue is not empty after probing"
Thanks, I downloaded and installed it.
The latest changes to my configuration were as follows: I have a machine with a rack-and-pinion system. It has a good control board and cable. The XXYYZ configuration, Matrixkins—I backported it myself from the source code, adapting it for 5-motor control. The configuration has been tested and works.
To ensure the minimum Z-axis step size was acceptable for scanning, I switched the step divider from 8000 to 25000. For my speeds, I had to reduce the value
[EMCMOT]
#edited 2026-03-21 due to jitter tuning not exceeding 2800 (previously 8000) - base_period reduced from 20000
EMCMOT = motmod
COMM_TIMEOUT = 1.0
BASE_PERIOD = 10000
SERVO_PERIOD = 1000000
What did this lead to? Version 2.8.4 with these same parameters works like a charm. The version you sent displays a message at startup - -
Unexpected realtime delay on task 0 with period 10000
This Message will only display once per session....
then goes through homing
+ and when attempting to move the Y-axis, the Y-motor emergency protection trips (torque overload). Obviously, something is wrong with my Matrixkins. Apparently, my participation in testing is causing more problems than it’s helping.
  • Accipiter
  • Accipiter
28 Apr 2026 13:03
Replied by Accipiter on topic MESA card (LAN) failing to connect.
Just wanted to send a quick thank you to Rodw and Jerry. I have managed to go through the first part of the video and the cyber black hole of networking has been cleared up somewhat. Will advise my success or lack therof when I have a chance to sit down and go over things. Wayne
  • MaHa
  • MaHa
28 Apr 2026 13:02
Replied by MaHa on topic (Solved) G43 not being applied in g-code
You can check for G43 in Linuxcnc status. Eg Axis:
M6 turns off G43,
  • andrax
  • andrax's Avatar
28 Apr 2026 12:08
Replied by andrax on topic (Solved) G43 not being applied in g-code
I'm not entirely sure about this either.
At least G10 only affects the currently selected coordinate system. As soon as you switch, your shift disappears.
It could be the same with G43, since you're applying the length correction to G53.
Just try it out.
Displaying 3091 - 3105 out of 13643 results.
Time to create page: 0.274 seconds
