  • Surmetall
  • Surmetall's Avatar
21 Apr 2026 06:48
Replied by Surmetall on topic LinuxCNC and Beckhoff AX5000 servo drives
Category: EtherCAT
Thanks for your quick reply. It is very possible that I made a mistake somewhere.For some reason, I am unable to create and download the ZIP file using the button in the top right. Is this the correct link? I get an error message whenever I try to generate and download the ZIP. Is this the correct link: codeberg.org/endian/twincat3_to_lcec_eth...ator/src/branch/main Because of that, I used AI assistance to download the data via the terminal instead. There is a high chance that something went wrong during that process.I will redo everything from scratch this evening: download, export, and convert it again, just to make sure nothing is going wrong on my end.I do feel a bit bad about it. There is now such a great configurator that makes the whole process manageable even for beginners, and I still somehow managed to get it wrong. Apparently there is always a dumbest possible user, and in this case, that would be me. :'(
  • grandixximo
  • grandixximo's Avatar
21 Apr 2026 02:42 - 21 Apr 2026 02:54
Replied by grandixximo on topic Ethercat random jitter fix
Category: EtherCAT
I tried, no much difference, and there should be almost none, the "bug" was more cosmetic, not really hindering OP time, if anything we are talking in the milliseconds range, no human perceivable difference.
OP time is not immediate with DC, can you time how long it takes? If the wait is excessive, there may still be something I have not found.
Would love to get remote access on the debian 10 and debian 13 setups, to compare, get that USB to ethernet adapter please, you are the only one that has both quick and slow OP, and I could compare what the drives and lcec are doing.
21 Apr 2026 02:13
Replied by tommylight on topic (Solved) FlexGUI - Multiple spindles?
Category: Flex GUI
Mods - please mark as 'solved'
Done, thank you.
  • spumco
  • spumco
21 Apr 2026 01:47
Replied by spumco on topic (Solved) FlexGUI - Multiple spindles?
Category: Flex GUI
Looks like JT updated FlexGUI for multiple spindles on GH a few hours ago.
Can't wait to update and have a go at it!
  • ihavenofish
  • ihavenofish
21 Apr 2026 00:37
Replied by ihavenofish on topic Leadshine L7 / L6 servos
Category: EtherCAT
thanks, the EC is a much older version of the drive. these are L7N
So i'm not sure if the settings translate, but its a start. :)
  • Rookie0
  • Rookie0
21 Apr 2026 00:29
Replied by Rookie0 on topic Leadshine L7 / L6 servos
Category: EtherCAT
  • Marko 87
  • Marko 87
20 Apr 2026 23:38
5-Axis BC Head Router – LinuxCNC Kinematics, TCP and Hardware
Hello everyone,
I’m working on an unfinished DIY 5-axis CNC router project with a BC head. The machine was originally built by a company but never fully completed, and it has been sitting unused for about 2 years. It never achieved proper simultaneous 5-axis operation.
The current setup is based on Mach3, without TCP/RTCP, so true 5-axis machining is not possible.
Machine configuration:
X, Y, Z + B, C axes
Stepper motors with encoders on all axes
Dual motors on the Y axis (gantry configuration)
BC head driven by stepper motors with gear reduction
Total: 6 motors
I’ve decided to rebuild the control system properly from the ground up using LinuxCNC.
At this stage, I’m trying to define the correct approach:
What is the recommended kinematics setup for a BC head machine?
How is TCP typically implemented in LinuxCNC for this configuration?
Are there example configurations I should study?
Hardware side:
What Mesa configuration would be appropriate for this setup (6 motors, dual Y, encoders)?
Is something like 7i95T sufficient, or would another combination be more suitable?
My goal is to build a stable and correct 5-axis system, based on a proven approach.
Any advice or pointers would be greatly appreciated.
Thanks!
  • ihavenofish
  • ihavenofish
20 Apr 2026 23:33
Replied by ihavenofish on topic Tuning Steperonline A6 Servos
Category: EtherCAT
If all you did was autotune, you aren't done.
You need to set the feed forward. Also set the in position error allowance.
What could be happening is that 2 or 3 microns is still within the drives set error, so it just doesn't move.
  • ihavenofish
  • ihavenofish
20 Apr 2026 23:25
Leadshine L7 / L6 servos was created by ihavenofish
Category: EtherCAT
So I have some L6 and L7 servos coming to evaluate for including with my machines. My understanding these are *mostly* the same as the EL6/EL7 models on their website, just OEM and 1/3 the price.
One notable difference is the 24 bit encoder on the L7.
Anyone set these up in linuxcnc? Issues? Success?
  • dm17ry
  • dm17ry's Avatar
20 Apr 2026 21:31
Replied by dm17ry on topic Yaskawa Mechatrolink 3 connect
Category: Driver Boards
got myself an sgd7s mechatrolink-iii drive... tried to talk to it. although it's basically a 100base-tx ethernet, they are not using ethernet 802.3 headers. and worst at all - they violate the 60 byte minimum frame length. by 4 bytes :) i was able to convince Zynq MAC to transmit short frames by turning off FCS offload. i can see the drive answers, but they get dropped and there's no way to receive them.
NICs on linux PC are no better.
so the only way to do it with Zynq is to implement a custom ethernet MAC in PL.. unfortunately my board has PHYs connected to PS pins, so i can't do it. will try again with another board...
  • endian
  • endian's Avatar
20 Apr 2026 20:07
Replied by endian on topic LinuxCNC and Beckhoff AX5000 servo drives
Category: EtherCAT
Are u using current version of translator?
Because I can clearly see subindexes of pdos are 0x00 instead of 0x01 which is clear issue to me l...
Download latest translator version and try export again.. versions before were buggy
Check it or edit it manually(fastest) and let me know
  • axemas
  • axemas's Avatar
20 Apr 2026 19:46
NativeCAM 2.0b — Python 3 & GTK3 port for LinuxCNC 2.9 / Debian 13 Trixie
Category: NativeCAM
"Hi everyone,
Thank you all for testing the port and providing feedback! I've just pushed a few fixes to the repository (including the INI parsing errors and GTK deprecation warnings). github.com/cnc-proton/nativecam-py3-gtk3...vecam_2.0b-4_all.deb
Regarding Bug Reports:
As more people start using this port, it becomes harder to track individual errors and logs across forum pages. If you encounter a bug, a crash, or a specific error message, please report it via GitHub Issues here: github.com/cnc-proton/nativecam-py3-gtk3/issues
The forum is still the perfect place for general discussions, sharing ideas (like the Lathe Polyline!), and showing off your work. But keeping the technical bug reports on GitHub allows me to solve them much faster and keep the project organized.
Thanks for understanding and for your continued support!"
  • jetbadger
  • jetbadger
20 Apr 2026 19:25
Replied by jetbadger on topic Lathe C axis homing
Lathe C axis homing
I've tried that too. Now I've noticed that I have pid.c.feedback-deriv connected. Maybe getting rid of it will help, Guess I'll try that next.
  • Konstantin
  • Konstantin
20 Apr 2026 19:06 - 20 Apr 2026 19:06
Replied by Konstantin on topic CiA 402 Folder Missing
Category: EtherCAT
Hello andrax,
I tried to follow your guide but still getting .hal file error for missing pins.
I ran LinuxCNC from terminal and it outputs that the HomeComp started.
Then the terminal reports that pins "joint.0.request-cia-homing" and "start-cia-homing" are not found.
  • Surmetall
20 Apr 2026 18:36
Category: EtherCAT
HEllo Endian,
thank you for the link i tried my best to fix it myself (and later with help of AI...) i hope i understood most of the problems.
I am trying to get a Beckhoff AX5125-0000-0216 running.
Current situation:
- LinuxCNC 2.9.8
- IgH EtherCAT master 1.6.8
- all other slaves on the real machine bus go OP
- only the AX5125 stays in PREOP / PREOP+ERROR
I also tested AX-only (only the AX connected to the LinuxCNC EtherCAT port, no other slaves) and it still does not go beyond PREOP. So it does not look like bus order / other slaves are the root cause.
It runs perfekt in TC3 also after  change from 2ms to 1ms i could jog it by hand.
What I already verified:
- TwinCAT project was switched to 1 ms
- exported again from TwinCAT
- converter run with c -i
- appTimePeriod = 1000000
- IDN 1 = e803
- IDN 2 = e803
- generated assignActivate 740 was changed to 730
Observed errors during the different attempts:
- AL status 0x0045: MBX_SOE
- AL status 0x001D: Invalid output configuration
- Writing IDN 0x80CC failed
- SoE configuration failed
- sometimes PDO entry 0x0024:00 is not mapped
- in AX-only test it still remains PREOP
Current result with LinuxCNC running:
- all non-AX slaves = OP
- AX5125 = PREOP E
I am attaching:
1. current ethercat-conf.xml
2. current initCmds/Antrieb-1-AX5-0-initCmds.xml
3. TwinCAT 1 ms export XML
4. ethercat slaves output
5. ethercat pdos -p 7 output
6. relevant dmesg output
Question:
Do you see an obvious issue in the AX SoE startup / telegram / DC setup, and what would be the correct minimal working config for AX5125-0000-0216 with lcec?
Thank you very very much for your time and help!
All the best
Tom
Displaying 3331 - 3345 out of 13628 results.
Time to create page: 0.391 seconds
