  • Plasmanfm
  • Plasmanfm
02 Apr 2026 11:01
Replied by Plasmanfm on topic China Spindel Drehzahl passt nicht!
Category: Deutsch
Hallo StephanCNC
Also wir haben eine 0-10 V Regelung….
Was ist die Max des FU ?
Wenn er bei 5 V 18000 aus gibt müsste er 36000 bei 10 V haben
und bei 2,5 V 6000
wenn das so ist passe doch die Einstellungen der Mesa-Karte an…
Gruß
Juergen
  • motionmasterupgrade
02 Apr 2026 05:11
Replied by motionmasterupgrade on topic MotionMaster Upgrade
This is the swivel head that I want to insstall. It comes with Yaskawa servos and digital drives. The rotaries that I intend to install will also have digital drives so I think I will be using the analog drives and servos that come with the machine on one Mesa card, and doing all these more modern stuff on a second card with a 3rd handling all the sensors.
Question: The current setup with the 16hp columbo spindle is about 100ish lbs. This AC head is another 100ish lbs. I wanted to sell the columbo, and just install a spindle that is closer to what I need... about 6hp (max). The machine comes with an air piston that reduces the load on the Z axis servo drive. I'm not sure how much weight it can handle. I image this is a function of air pressure, gaskets, and how the thing is built. If this air lift thing is calibrated right, there should not be any additional load on the Z axis servo, so I'm going to assume that problem away. I sort of have no doubts that the gantry and bearings can take the extra weight... been climbing up there to check stuff out, and its just built solid, don't know what else to say. I think this was welded together as a bridge, and then machined to get a flat surface. I will need some sort of an L bracket and some hackery to stiffen that Z axis. This L bracket will put a moment arm on the linear guides, so I was wondering if I needed a counter weight. I know I will also have to alter the position of the tool changers because the swivel head will push the spindle a little further forward. That's no big deal. I wanted to add more tool holders anyway.
Do you guys see any major concerns? I know all this stuff is mechanically stressful which is why I bought this machine to upgrade instead of rolling my own joint with extruded aluminum. I think I don't have to worry about mechanical integrity, but again, I've never done this before. Thoughts?
Will have all the faceplates and schemes up tomorrow, then I want to order this swivel head parts once I am sure that I can make this work.
  • spumco
  • spumco
02 Apr 2026 04:50
Replied by spumco on topic CSS/G96 for other than X-axis?
UPDATE
I have switchkins working.  I have not yet tested CSS, but the axis/joint swap works with a couple of M-codes.
  • Normal mode:
    • jogging/g-code/MDI axis "V" moves the parting slide (joint-3)
    • jogging/g-code/MDI axis "X" moves the real X-axis (joint-0)
  • Switched mode
    • jogging/g-code/MDI axis "X" moves the parting slide
    • jogging axis V and joint-0 is disabled
    • Pre-switch V-axis G54 offsets are written to the virtual X
    • Appropriate max/min limits and accel/velocity are written to the virtual X
  • Switched back to normal
    • All jogging/g-code/MDI work normally
    • X-axis position goes back to pre-switch position (G53 X0)
    • Same for V-axis
Remaining issues
  • Axis GUI screen buttons can still jog joint-0/V-axis when in switched mode
    • I don't plan to use Axis once I'm done configuring & sorting out the lathe, but I don't know how to stop NML background messages from a GUI from moving the true X-axis.  Any ideas how to no-kidding stop an axis from being moved without disabling the drive? like DEACTIVATE_JOINT or something?
    • Bad Things will happen if the real X-axis moves when I've got the main and sub-spindles both clamped on a part.
  • Jogging the slide while in switched mode results in half the motion I'd expect.
    • i.e. the DRO doesn't match the physical distance the slide moves.
    • This may be due to a scale component I've got in the X-axis jogging logic so I can jog in diameter mode.  Maybe I need to get rid of that and change the joint-0 scale.
Not posting config or other files until I've tested CSS and sort out the jog motion issue.
Big thanks to @Aciera for the help.
  • Hakan
  • Hakan
02 Apr 2026 04:45
Replied by Hakan on topic Ethercat SDOS to XML
Category: EtherCAT
Any clues in syslog?
  • rodw
  • rodw's Avatar
02 Apr 2026 04:44
Replied by rodw on topic Ethercat SDOS to XML
Category: EtherCAT
So in summary, this slave won't let you set SDO's again after they are set. Power cycling the slave resets all the SDO's to zero and allows linuxcnc to set them as per the ethercat xml file
  • rodw
  • rodw's Avatar
02 Apr 2026 04:36
Category: EtherCAT
Weird. I was right all along. !!!
After powering the IO board on and off, the SDO's are set to zero.
Restarting Linuxcnc again in this state linuxcnc opens without reporting any errors.
But if you close Linuxcnc and restart it, it reports errors on all of the SDO's.
I've never seen that before.
Thanks for the help. At least I can proceed to actually test on the spindle now!
  • Hakan
  • Hakan
02 Apr 2026 04:30
Category: EtherCAT
I also set them in xml. But troubleshoot and experiment on the command line.
  • rodw
  • rodw's Avatar
02 Apr 2026 04:23
Category: EtherCAT
answer no they don't
  • rodw
  • rodw's Avatar
02 Apr 2026 04:21
Category: EtherCAT
I've always set the SDOs in the xml
So I had a play when I worked out I needed to use 0x3000 and despite all of linuxcnc's complaining, the entries were set correctly.
Do SDO's persist on power cycles?
  • spumco
  • spumco
02 Apr 2026 04:20
Replied by spumco on topic Need help with Bash M-code
Solved.
Short answer(s) for anybody in the future reading this:
  1. No, do not need to change (INI_FILE_NAME)
  2. Yes, yes, and I no longer care what "catch" does.
  3. Yes.  You can just write each hal command line out in a readable form.
  4. Yes, the way it's written permits changing "x y z" at the top and everything below gets sorted out.  Clever, but miserable for us Luddites to unravel.
  • Hakan
  • Hakan
02 Apr 2026 03:41
Category: EtherCAT
Strange. If it's in the sdos listing I have always been able to read the value with
ethercat upload -p 0 0x3000 2
for example.
  • rodw
  • rodw's Avatar
02 Apr 2026 03:20
Category: EtherCAT
yeh, I tried 0x3000 and had no more luck (it is a hex value)
  • Hakan
  • Hakan
02 Apr 2026 03:18
Category: EtherCAT
0x3000 perhaps? Try upload to read the register.
  • rodw
  • rodw's Avatar
02 Apr 2026 03:06
Category: EtherCAT
cnc@linuxcnc:~/linuxcnc/configs/catioa$ ethercat slaves
0  0:0  PREOP  +  IMC IO MODEL with EtherCAT
cnc@linuxcnc:~/linuxcnc/configs/catioa$ ethercat download -p 0 3000 2 0x1000 -t uint16
SDO transfer aborted with code 0x06020000: This object does not exist in the object directory
Apparently not. Looks like I have to lug a spindle into my office. Is the syntax right?
  • Hakan
  • Hakan
02 Apr 2026 02:35
Category: EtherCAT
Does it work when you set the values with ethercat download/ethercat upload?
Displaying 4141 - 4155 out of 13575 results.
Time to create page: 0.550 seconds
