  • Hakan
  • Hakan
28 Mar 2026 08:09
Replied by Hakan on topic Ethercat Setup help needed for beginner
Category: EtherCAT
It's easy when you know it.
The problem is to come to know enough.
Anyway, it's not that hard and there is virtually no difference between
setting up stepper drives or servo drives with EtherCAT.
The cia402 layer makes them look the same.
The example I gave is a starting point.
You can copy the files to your installation, change the HALFILE=cia402.hal in the ini file
and give it a try.
But you are going to need to adopt and edit the files to your specific setup.
Number of drives, what number/name they have. And you need to add other
functions like spindle. That's in the sim file. So you need to mix them together
and take the motion part from cia402.hal and the other functions spindle, limits etc
from the sim config.
  • Hakan
  • Hakan
28 Mar 2026 08:02
Replied by Hakan on topic Ethercat boards and hardware
Category: Driver Boards
Don't use EtherCAT if you want to use a step/dir driver.
There are advantages to skip the intermediate step with
step/dir for steppers and analog +-10V for servos.
The right way is to have a EtherCAT drive that controls the
motor directly, skipping that middle step.
I have built an EtherCAT board that gives step/dir signals.
But it's not the right way to go.
  • ts
  • ts
28 Mar 2026 03:14
Replied by ts on topic Jog troubles
Jog troubles
Category: Flex GUI
Hi, Rodw! Glad to see you in this topic)
Jog before homing.. hmmm.. for example, edm machine , some emergency, estop pressed or power loss.. and mechanical of the machine stucked. I have to move before homing, because homing may broke everything on the work table
  • ts
  • ts
28 Mar 2026 03:10
Jog troubles
Category: Flex GUI
Yes, it will work. But only after homing.
Before homing its work as 3rd number (all axus numbers are 0-1-2-3 )
  • ts
  • ts
28 Mar 2026 03:05 - 28 Mar 2026 03:08
Ext hard buttons duplicate Power_PB and Reset
Category: Flex GUI
Thanks for your answer.
I will try it
An what about External power button to switch ServoOn? I need separately button to send command the same as power_pb ib flexgui
TS
28 Mar 2026 02:44
Replied by tommylight on topic Differential encoder hard crashes the PC MESA7i77
See if you can disable this in BIOS, it is usually enabled by default
www.google.com/search?client=firefox-b-l...ssive+power+managent
Also, if you are using any kind of PCI-E riser or cable, se the PCI-E speed/mode to GEN1
  • NWE
  • NWE's Avatar
28 Mar 2026 02:05
Replied by NWE on topic Ethercat boards and hardware
here is some info on a cheap ethercat stepper drive. But it is not as cheap as your A4988.
4 axis stepper drive
  • PCW
  • PCW's Avatar
28 Mar 2026 01:55 - 28 Mar 2026 02:09
You could try  setpci and verify if the [disabled] goes away from the lspci listing
  • grossm5000
  • grossm5000
28 Mar 2026 01:08
Replied by grossm5000 on topic Differential encoder hard crashes the PC MESA7i77
the options in my BIOS PCI Subsystem Settings are:
Above 4G Decoding (enable/disable)
SR-10V Support (enable/disable)
and in BIOS Onboard Device Configuration
PCIEX1_1 Mode (auto) <--but i think this only refers to speed. I have this selection/option for all the PCI slots on the board
I tinkered with all of these earlier today to no result. I do have an ASUS A520M motherboard...BIOS options seem pretty generic.
  • grossm5000
  • grossm5000
28 Mar 2026 00:53 - 28 Mar 2026 00:53
I do have access to some BIOS PCI settings, but not sure if I can screenshot them. I am afraid the best I can do is take a picture.
I did some searching...will this command do anything for me?
sudo setpci -s 04:00.0 COMMAND=0x02
supposedly enables the memory space, but I am certainly not a software wizard...
  • PCW
  • PCW's Avatar
28 Mar 2026 00:49
The problem is this:
Region 0: Memory at fce00000 (32-bit, non-prefetchable) [disabled] [size=64K]
Which is likely something the BIOS did so may be fixable if you have access to BIOS PCI settings
I will take a look into what is needed to get mesaflash to re-enable the memory region (lLinuxCNC does this)
  • rodw
  • rodw's Avatar
28 Mar 2026 00:44
Latency, error finishing read, and IRQ affinity
Ran into an issue with IRQ balance after updating to trixie
Late to the party but currently best practice is not to use irqbalance. the balancing is now managed internally in the kernel so adding a second balancer can confuse things.... but it worked here....
  • grossm5000
  • grossm5000
28 Mar 2026 00:41
Here we are! I super appreciate it...so does my wife   Ive been trying to make this work all day
  • rodw
  • rodw's Avatar
28 Mar 2026 00:35
Replied by rodw on topic Probe Active before non-probe move
I once set a digital input in my probing sequence that was and2'd to the probe signal to stop this.
I think a better way would be to use motion.motion-type = 5 to signify probing was in use and disable the signal if this is false.
Displaying 4321 - 4335 out of 13576 results.
Time to create page: 1.227 seconds
