  • m0602232
  • m0602232
26 Mar 2026 10:13
too long hm2_7i97.0.read.tmax or something else?
Category: Driver Boards
00:1f.6 Ethernet controller: Intel Corporation Ethernet Connection (7) I219-V (rev 10)
DeviceName: Onboard - Ethernet
Subsystem: Lenovo Ethernet Connection (7) I219-V
Flags: bus master, fast devsel, latency 0, IRQ 120
Memory at b1000000 (32-bit, non-prefetchable) [size=128K]
Capabilities: <access denied>
Kernel driver in use: e1000e
Kernel modules: e1000e
eee was already off, not sure about gro, lro or tso but I will try with them disabled also.
  • rodw
  • rodw's Avatar
26 Mar 2026 09:45
thanks, 6 core PC with one isolated = 5 available so that's right. i5 should be fine
What network card? is it Realtek?
I've been researching this today. Here are a few more obscure settings that may help where eno1 is the NOC name from ip a
sudo sysctl -w net.core.busy_read=50
sudo sysctl -w net.core.busy_poll=50
sudo sysctl -w kernel.sched_rt_runtime_us=-1
sudo ethtool --set-eee en01 eee off
sudo ethtool -K eno1 gro off lro off tso off
  • rodw
  • rodw's Avatar
26 Mar 2026 09:30
THC not getting active even when "all seemingly needed" requirements are met
Category: Plasmac
Its an odd looking voltage plot.
I would look at the time after arc ok the THC is activated. To me it looks like it needs to be 2 seconds. I just can't see the setting I'm looking for.
Early activation could be disabled by the big fluctuations in voltage.
  • Aciera
  • Aciera's Avatar
26 Mar 2026 09:17
Replied by Aciera on topic Where is discussion for my new comp
Use the 'Add a comment' box at the end of the 'Conversation' tab in the PR page:
github.com/LinuxCNC/linuxcnc/pull/3877
  • rodw
  • rodw's Avatar
26 Mar 2026 09:11 - 26 Mar 2026 09:12
Replied by rodw on topic Where is discussion for my new comp
The discussion should occur on the PR. its up to the dev team, not forum users so you neet to convince the gatekeepers. Personally 80 files in one commit is too much to clearly understand and debug build errors.  Perhaps the component is in one PR and the sim in another.
  • Plasmanfm
  • Plasmanfm
26 Mar 2026 09:01 - 26 Mar 2026 09:03
  • RotarySMP
  • RotarySMP's Avatar
26 Mar 2026 08:35
Replied by RotarySMP on topic Toolchanger HAL Component project
Category: HAL Examples
What aspects of Andy's carousel.comp have you identified as needing improvment, and/or what other features/funtions are you adding with this comp?
Do you have a github repository, or just keeping the current version of code uploaded to the initial post in this thread?
My Schaublin tool changer is extremely simple, with just a single input to open the tool change pneumatic valve, for a fixed duration, and then checking the next feedback pin went high. Cycling through until the target position is reached. I don't need much of the code like tool unlock, tool lock as that is all pneumatically sequenced.
I am not sure what to do about motion to a tool change position. Given the excessive size of my carousel, relative to the lathe envelope, and wide variety of tool geometries, tail stock etc I suspect it is safer to not automatically move to a tool change position. Do you have thoughts on that?
Cheers
Mark
  • m0602232
  • m0602232
26 Mar 2026 08:16
PCW: Thanks for that, I'll consider changing kernel, or maybe trying with another pc.
rodw: processor: Intel(R) Core(TM) i5-8400T CPU @ 1.70GHz, echo $(nproc) prints 5.
  • Hakan
  • Hakan
26 Mar 2026 07:50 - 26 Mar 2026 07:54
Replied by Hakan on topic El5101 Config
El5101 Config
Category: EtherCAT
pos is of course the number of rotations since zeroing on index. This is the main driver for
the synchronized move, the z-axis is being forced to follow pos.
Rotational speed isn't mandatory, but convenient to have.
You use rotational speed for the at-speed pin and is displayed in the gui.
I guess enc-frequency-scale should be set to 1/2000, so 0.0005, for rps.
For rpm 1/(2000*60) = 8.333333e-6.
  • tom3p
  • tom3p
26 Mar 2026 07:42
Hello,
Is the Forum where discussion of new hal comp takes place?
On Github, on my fork there is a Discussion button
On Github in LinuxCNC.linuxcnc there is no button.
Google said the Forum was the main location for discussion.
Where is proper place to discuss?
My case is
  problems with package creation and a new comp.
 My comp builds and runs fine locally,
but a PR fails during package creation.
I hope a new push will fix the packahe creation error.
  • rodw
  • rodw's Avatar
26 Mar 2026 07:27
Replied by rodw on topic El5101 Config
El5101 Config
Category: EtherCAT
I'm not sure on that. pos = position so it implies reading a linear scale when you have a spindle, you want to measure RPM or RPS which a frequency resolves to with appropriate scaling.
  • Nathan40
  • Nathan40
26 Mar 2026 03:55
Integrating a BCL-AMP capacitive sensor to LinuxCNC
Category: Plasma & Laser
Hi All,
The ohmic enable gets randomly triggered when laser is enabled. The wiring is as follows to the 7c81 board: 5v from bob , signal to 7c81 encoder pin direct, pins 3 and 4 to gnd of bob. Please help!
  • rock861261
  • rock861261
26 Mar 2026 03:07
Replied by rock861261 on topic El5101 Config
El5101 Config
Category: EtherCAT
doesnt enc-pos provide an accurate speed.
26 Mar 2026 02:05
Replied by tommylight on topic Review Request for Arc Volt Sensor Schematic
I have these:
www.ti.com/product/LM331
but i never bothered to use them as the time is worth more than the price of THCAD.
Easy to use and can be plugged to parallel port with a single optocoupler.
  • Hakan
  • Hakan
26 Mar 2026 01:23
Yes, inverting and decoupling.
Wouldn't be surprised if there is a similar isolated SPI component.
Best if the ADC has some kind of free run mode. Otherwise the reading of a value can take too much time.
Was looking for a new value every millisecond, with as many bits of resolution as possible.
Have also used ADS1014 with similar good result.
Displaying 4426 - 4440 out of 13578 results.
Time to create page: 0.745 seconds
