  • Schaublin12
  • Schaublin12
14 Sep 2026 16:05 - 14 Sep 2026 16:11
Replied by Schaublin12 on topic EtherCAT Master Beckhoff slave not found
Category: Basic Configuration
I have tried lcec configgen xml
Now I have got a new xml file as attached, but LinuxCNC doesn't start.
  • tuxcnc
  • tuxcnc
14 Sep 2026 14:42
Replied by tuxcnc on topic Crash
Crash
Category: Plasmac
Typical of Python, the message is absolutely true and absolutely useless...
ValueError: invalid literal for int() with base 10: '' means that you are trying to use an empty string as an int variable, but it doesn't tell you where that empty string came from.
Of course, you can look for the cause for a long time and finally find that, for example, the disk is damaged...
I see that you have a very old Linux with Python 2.7 and instead of repairing this museum, you would be better off installing a new system on new hardware.
It may be easier, and it will definitely be better.
  • Jdog
  • Jdog
14 Sep 2026 12:14
Replied by Jdog on topic Crash
Crash
Category: Plasmac
Sorry about that. Ive attached pics here.
  • Marslukan
  • Marslukan
14 Sep 2026 11:12 - 14 Sep 2026 11:41
Replied by Marslukan on topic 7i98 and 5abobx3 firmware
Category: PnCConf Wizard
Спасибо большое. На плату залита прошивка с сайта mesa (7i98_5abobx3d.zip - bit and pin), хотя плата неоригинальная. Приложил файлы с фото платы и распиновкой: old - что сейчас пока установлено, new - как нужно. Свободные пины на P3 буду использовать по концевики,  HOME, Estop и переключатели.
  • my1987toyota
  • my1987toyota's Avatar
14 Sep 2026 10:07
Replied by my1987toyota on topic 7i76EU Availibility ?
Category: Driver Boards
I decided to wait for the next batch of boards to come out. Any estimation when they will be available?
14 Sep 2026 10:04
LinuxCNC + Mesa 7i92TF: motors barely move and ignore direction changes
-Use a DVM to check if the ground is properly connected.
-A quick test, make another config with PncConf, but invert all stepgen output pins.
Upload the config files here sop we can have a look, and some pictures of the wiring.
14 Sep 2026 09:57
Replied by tommylight on topic Crash
Crash
Category: Plasmac
Upload the pictures here, not on plasmaspider.
  • Keith3D
  • Keith3D
14 Sep 2026 06:35
Replied by Keith3D on topic Headless
Headless
I am using direct UDP to the board instead. Thanks for the input!
  • adamster112
  • adamster112
14 Sep 2026 05:54
Replied by adamster112 on topic Remora with STM32H753ZI
hi ive got this working flawlessly on my scylla btt board took 3 days drop us a message on here if u still looking .
  • RMJ fabrication
  • RMJ fabrication
14 Sep 2026 05:26
Replied by RMJ fabrication on topic Home switches stopping machine but not latching fully
Category: Plasmac
These are the limit switches I am using I believe they are connected to tb5 on the mesa 7i76e.
And here are my latch positions and velocities
  • rodw
  • rodw's Avatar
14 Sep 2026 01:54
Replied by rodw on topic Ethercat random jitter fix
Category: EtherCAT
1.44.0 is the latest version, also ethercat don't get from IGH, please uninstall IGH ethercat, and install the one from here instead
github.com/linuxcnc-ethercat/ethercat/releases
your devices will OP much quicker.
also note this new version needs an additional command in hal
lcec.activate
  • rodw
  • rodw's Avatar
14 Sep 2026 01:52
Replied by rodw on topic Notifications
Notifications
Category: Show Your Stuff
There seems to be a lot of systems like this recently.
The correct method is to use MTconnect  which is a standards based read only API now included in LinuxCNC master branch.
With MTconnect you can publish the same data to Home assistant which can then trigger automations
mtconnect.org/
This took me all  of 5 minutes to publish to Home Assistant (sorry Linuxcnc is not running right now...)
  • FabLabRacing
  • FabLabRacing
14 Sep 2026 01:42
Replied by FabLabRacing on topic Thinking of moving my Plasma from Masso to LinuxCNC
Category: Plasma & Laser
I just did the same thing, Please feel free to reach out if you need any help. I feel like I learned a fair bit along the way...
  • grandixximo
  • grandixximo's Avatar
14 Sep 2026 00:25
Replied by grandixximo on topic Ethercat random jitter fix
Category: EtherCAT
  • gomond
  • gomond
13 Sep 2026 23:06
Thanks Rod
Its a ripper, just what I was after,
Displaying 466 - 480 out of 13147 results.
Time to create page: 0.971 seconds
