  • Aciera
  • Aciera's Avatar
28 Feb 2026 07:40
Replied by Aciera on topic QTPYVCP+VISMACH+LINUXCNC ROLLED INTO ONE?
Category: QtPyVCP
For an example on how to implement toolpath plotting in work coordinates using vtk see:
github.com/Sigma1912/vtk-vismach
'Capture()' embeds an invisible actor in the model that can then be used to track the transformation matrices for the tooltip and the work which can then be used to plot the toolpath.
  • amanker
  • amanker
28 Feb 2026 07:16
Replied by amanker on topic QTPYVCP+VISMACH+LINUXCNC ROLLED INTO ONE?
Category: QtPyVCP
Yes, You are absolutely right. Vismach is not important at all. I also think so. Thats why really few persons are using this.
If you can just give me initial lead which files I should look for? I tried to find vtk_backplot.py file in instalaltion but didnt find.
  • Finngineering
  • Finngineering
28 Feb 2026 07:08
Replied by Finngineering on topic XHC WHB04B development?
I'm fairly sure I fixed the 0.0035% bug I mentioned in the last post. Swapping two lines in the code should have been enough. Right now, I'm not aware of any real bugs in my firmware. I will continue using it with the dongle/pendant on the mill. But unless something comes up, I consider it good enough.
Unfortunately, I was mistaken about the bootloader version where the dongle firmware can more easily be read out. It is possible for versions before 2.40, but not with version 2.40 or 2.50. So right now there is no easy way to read out the whole firmware from the dongles.
  • rodw
  • rodw's Avatar
28 Feb 2026 02:44
Replied by rodw on topic CiA 402 Folder Missing
Category: EtherCAT
Take care. Mine is an adaptation, the original is here github.com/dbraun1981/hal-cia402/tree/main
  • rodw
  • rodw's Avatar
28 Feb 2026 02:40
Just When You Couldn't Hate Government More
Why could I guess the author from the topic?
Interesting concept but its not a kernel function so how are they going to lock it in? Just uninstall the library
  • rodw
  • rodw's Avatar
28 Feb 2026 02:32
Separating CiA402 Logic from EtherCAT (lcec): Modular Adapter + Drive Stub Valid
Category: EtherCAT
The bare bones CIA402 state machine looks like this:
// uncomment pins if enabled
/* --- CiA 402 Controlword Commands --- */
#define CMD_SHUTDOWN                0x0006 // Transition to Ready to Switch On
#define CMD_SWITCH_ON               0x0007 // Transition to Switched On
#define CMD_DISABLE_VOLTAGE         0x0000 // Disable power stage
#define CMD_QUICK_STOP              0x0002 // Emergency deceleration
#define CMD_DISABLE_OPERATION       0x0007 // Disable motor drive
#define CMD_ENABLE_OPERATION        0x000F // Enable motor drive (Power On)
#define CMD_FAULT_RESET             0x0080 // Reset fault on rising edge
/* --- CiA 402 Statusword States --- */
// Masked with 0x006F to extract the specific state bits
#define STATE_NOT_READY             0x0000
#define STATE_SWITCH_ON_DISABLED    0x0040
#define STATE_READY_TO_SWITCH_ON    0x0021
#define STATE_SWITCHED_ON           0x0023
#define STATE_OPERATION_ENABLED     0x0027
#define STATE_QUICK_STOP_ACTIVE     0x0007
#define STATE_FAULT_REACTION_ACTIVE 0x000F
#define STATE_FAULT                 0x0008
uint16_t update_cia402_state(config_data_t *d) {  // receives status.word ( d->status.raw)
	unsigned short currentState = d->status.raw & 0x006F; // removes all the bits we are not interested in
    switch (currentState) {
        case STATE_SWITCH_ON_DISABLED:
            d->control.raw = CMD_SHUTDOWN;
            break;
        case STATE_READY_TO_SWITCH_ON:
            d->control.raw = CMD_SWITCH_ON;
            break;
        case STATE_SWITCHED_ON:
            d->control.raw = CMD_ENABLE_OPERATION;
            break;
        case STATE_OPERATION_ENABLED:
            // Drive is active. Keep it enabled.
            return 1;
            break;
        case STATE_FAULT:
            // Attempt to clear the fault
            d->control.raw = CMD_FAULT_RESET;
            break;
        case STATE_QUICK_STOP_ACTIVE:
            // Move back to disabled if quick stop was triggered
            d->control.raw = CMD_DISABLE_VOLTAGE;
            break;
        default:
            // For any unknown or intermediate state, default to a safe "Voltage Disable"
            break;
    return 0;
You should add some timeouts for error handling
  • rodw
  • rodw's Avatar
28 Feb 2026 02:17
Thinking of moving my Plasma from Masso to LinuxCNC
Category: Plasma & Laser
Damn, I thought I may have had a thcad here in Brisbane but I looked and I don't.
If you have a THC that generates an up/down signal, you could use it if you set the right mode in qtplasmac. Looks like the pokeys may do that.
Totally untested but I do think my hypersensing component would probably be able to be modified to do ohmic and voltage sensing it does sense arc voltage but the scale is only 24.5 volts so it just stays on. with better scaling you probably could do both.
  • tar_san
  • tar_san
28 Feb 2026 00:48
Ver 2.9.4 iso clean install Trouble when disabling EOE
Category: EtherCAT
Thanks a lot !
They also mentioned, "if you put this newest ESI , some of this problem will fixed."
( But LinuxCNC (IgH master) desn't have this function. And Yaskawa tools doesn't have upload ESI function to drive as default.)
They said also, this ESI file contains fixture for all versions of firmware.
In this case, do you think It is possible for TwinCAT to fix default ESI in ServoDrive , to make LinuxCNC work ?
I know I have to do it with my own risk and I may not need to do it if I found another solutions.
But I'm happy if I could get some hints for it...
  • gomond
  • gomond
28 Feb 2026 00:38
Hi all my name is Greg I have been watching this forum for years and this is my first post.
I built a CNC plasma 2 years ago and I used a Masso CNC v3 with their DTHC, as I couldn't get the after market ones to play nicely with it.
I have had nothing but trouble with this machine, yet I have a CNC router and a CNC mill using Masso's and they work great.
The Plasma on Masso is just immature and failure prone. I have built many Plasma cutters for friends using MyPlasm and it is about 1/8 the price and flawless .
I have been watching Rods videos and am very impressed with his results. So I bought a Mesa 7i96 card but I am now retired and a pensioner so I don't have the income like when I was working hence my question , can I implement THC and OHMIC on the existing board or use the ProKeys Fibre linked THC that I have from the Masso experiments and the CNC4PC Ohmic also left over?
Thanks Heaps for any advice
Cheers Greg.
Arthurs Creek, Vic.
  • tar_san
  • tar_san
28 Feb 2026 00:32
Replied by tar_san on topic Cannot JOG Plus/Minus move in TeleOp mode
Category: Basic Configuration
Sorry. Let me fix, I used 2.9.5 and 2.9.8.
I'm sure 2.9.5 have some bugs for jogs.
  • NWE
  • NWE's Avatar
27 Feb 2026 23:48
Replied by NWE on topic Robot Arm and Controller
Category: CNC Machines
This reminds me of how a lot of industrial CNC machines add a linear scale encoder feedback for increased accuracy. Technically, on such a machine the servomotor feedback encoder equates to your input encoder, and the linear scale is what you call the output encoder.
The idea of measuring torque by measuring the difference between the two encoders sounds really neat, never before heard of that.
  • Dudelbert
  • Dudelbert
27 Feb 2026 22:13
Considering a Full Rewire on a Working Schaublin 125 CNC
Category: Turning
Thank you for the offer, but I already ordered them, and I suspect that postage for you would probably be more than the €4 for five pieces delivered from the other side of the planet. I still don’t understand how these prices are possible.
  • RotarySMP
  • RotarySMP's Avatar
27 Feb 2026 22:05 - 27 Feb 2026 22:54
Category: Turning
Oh, I already ordered some of those board from JCLPCB years ago. I can send you a couple.
  • NWE
  • NWE's Avatar
27 Feb 2026 20:54
Category: EtherCAT
Thanks!
I have not studied internals of CiA402 very deeply. However, I have some EtherCAT hardware here, I'd be willing to test your component on my drives once you get to that stage of the project.
  • andrax
  • andrax's Avatar
27 Feb 2026 20:14
Technical questions about CIA402 and homecomp.comp on A6
Category: EtherCAT
No, I haven't.I posted a query about this on the German sps forum. The response was arrogant, and I don't expect any help.We're on our own. If you have working code to test, I'd be happy to help
Displaying 5626 - 5640 out of 13548 results.
Time to create page: 1.961 seconds
