  • depronman
  • depronman
08 Feb 2026 22:23
current latest download of LinuxCNC V2.9.8 will not install GRUB on several PC's
Category: Installing LinuxCNC
I downloaded the 2.9.8 latest version from the first link in the download page
Burned this iso to a pen drive under windows using Rufus latest version
Live preview works fine
Graphic install consistently fails at the point of installing GRUB
         - this happened on numerous older PC typically inter dual core with 4GB to 8GB of RAM and installing to an SSD
As a trial I installed 2.7.4 which I had on a pen drive without issue
It should be noted the 2.9.8 installed perfectly onto a much newer NUC PC using the same pen drive
I have installed 2.9.7 without any issues and will (Debian 13) and will look to update to 2.9.8 tomorrow when time allows
Please advise if any more info is required
Regards,  Paul
  • Isleape
  • Isleape
08 Feb 2026 22:14
Mesa 7i90HD no comunication/ update erprobte on 2nd mesa (Solved)
Category: Driver Boards
Hello, with the update and after doing a sudo install mesaflash the board is found and its working...
Also mesaflash is now reporting 3.5.16...
So I guess I was too sloppy with my version I build and what I was actually using...
Sorry for bothering you with these basics... and thanks for the responsive help.
Saved me from swapping EEproms...
sudo mesaflash --device 7I90HD --addr 0x378 --epp --verbose
EPP device 7I90HD at 0x0378:0x0778
Communication:
  controlled by FPGA
Board info:
  Flash size: 16Mb (id: 0x14)
  Connectors count: 3
  Pins per connector: 24
  Connectors names: P1 P2 P3
  FPGA type: 6slx9tqg144
  Number of leds: 2
  • PCW
  • PCW's Avatar
08 Feb 2026 21:47
Replied by PCW on topic Configuration Problems 7i92 PnCConf
Category: PnCConf Wizard
Mesa configurations do not use pin numbers but channel numbers for things like stepgens and pwmgens
As long as you have the correct firmware, the order of these channels typically matches the breakout
For GPIO, GPIO numbers are used (the connector pin == GPIO mapping is in the readhmid printout)
  • rodw
  • rodw's Avatar
08 Feb 2026 21:15
Considering a Full Rewire on a Working Schaublin 125 CNC
Category: Turning
Good weather for welding :) Nice progress.
Not on this side of the world where the the temp is hitting 40 deg c and beyond! We holidayed in Canada over Xmas so went from -20c to plus 40c which took a week to get back accustomed to!
  • rodw
  • rodw's Avatar
08 Feb 2026 21:04
Technical questions about CIA402 and homecomp.comp on A6
Category: EtherCAT
The original component by dbraun was designed with home to index in mind but today many drives home to an external switch. The problem is that the drive moves while not being commanded  by linuxcnc which linuxcnc interprets as a following errors. The secret is to sync linuxcnc's commanded position and its feedback while its moving like this which the original cia402.comp does not do. some people have modified the component to support this.  I have been working on an enhanced cia402 component but it needs more work.
  • mooser
  • mooser
08 Feb 2026 20:07
Adding Feed Rate (IPM or IPR) to the lathe screen
Category: AXIS
Thanks. I'll see if I can get that to work. I keep thinking it's time to put together a new computer and move up to 2.9 but when it's working it's working.
(Slowly gathering parts for a cnc router running 2.9.x so maybe it's time to get them both at the same "level"
Thanks again
M
  • andrax
  • andrax's Avatar
08 Feb 2026 20:01
Replied by andrax on topic StepperOnline A6 Servo
Category: EtherCAT
No,
4x FN 2090-4-06
  • Finngineering
  • Finngineering
08 Feb 2026 19:59
Replied by Finngineering on topic XHC WHB04B development?
I have loops set to 10 and timeout to 3.
  • markbaenen
  • markbaenen
08 Feb 2026 19:34
Configuration Problems 7i92 PnCConf was created by markbaenen
/homeI am not a dense person. I have read A LOT on configuring. I have set up a couple other machines with StepConf.
Why does this:
look absolutely nothing like this:
when trying to configure this:
  • DerKlotz
  • DerKlotz
08 Feb 2026 19:20
Need to install newest Linux Debian Bookworm with the newest Linuxcnc preempt-rt
I want to install Probe_Basic. I already had Trixie installed but i couldn't get Probe_Basic to work. Than i got the hint from a community member that Probe_Basic needs Debian Bookworm as the homepage mentions.
  • BIBIGUL
  • BIBIGUL
08 Feb 2026 19:19 - 08 Feb 2026 19:32
Replied by BIBIGUL on topic 403 Forbidden
403 Forbidden
Category: Forum Questions
Phone - 401 Unauthorized
08 Feb 2026 19:07
Replied by tommylight on topic 403 Forbidden
403 Forbidden
Try from a phone or tablet, or another PC.
  • bobwolf
  • bobwolf
08 Feb 2026 18:56
Solving the USB Latency Dogma for HMI/MPG: Technical Feedback Request
Hi everyone,
I’ve just released version 1.1.0 of the io_decoder driver. This update focuses on architectural stability and addressing initial feedback from the community.
What's new in v1.1.0:
Asynchronous Threading: I have moved the keyboard emulation logic (uinput) out of the Real-Time HAL thread and into a dedicated user-space thread. This ensures that any system-level delay in processing keystrokes will never interfere with the real-time performance of the CNC HAL components.
Config File Optimization (Credits to COFHAL): Following COFHAL's feedback regarding parsing errors with comments and blank lines, I have refined the io_decoder-keymap.cfg structure. I've implemented a stricter formatting requirement to keep the driver lightweight and added clear instructions within the config file to prevent GUI warnings.
Full English Translation: The source code and all comments have been fully translated to English for better accessibility.
Clean Exit: Improved the cleanup routine to ensure proper thread termination and resource release upon hal_exit.
You can find the updated source code, documentation, and the new pre-packaged ZIP on GitHub and the project landing page:
GitHub Repository: github.com/bobwolfrst/io_decoder-linuxCNC Project Page & Downloads: bobwolfrst.github.io/io_decoder-linuxCNC/
A big thanks to COFHAL for the valuable feedback. I’m looking forward to hearing from more testers about how the new threading model performs on different hardware setups!
Happy milling!
  • andypugh
  • andypugh's Avatar
08 Feb 2026 18:46
Replied by andypugh on topic Cannot JOG Plus/Minus move in TeleOp mode
Category: Basic Configuration
Which GUI are you using? I seem to recall that Axis needs to be on the manual tab for jogging to work.
Can you share your HAL file?
  • NT4Boy
  • NT4Boy
08 Feb 2026 18:42
Replied by NT4Boy on topic HURCO KMB-1 Control Update
Category: Milling Machines
Crumbs I was sure that the angle used in M19, was the angle after an index pulse, but can see now its after the enable edge. Guess I cannot get the index to trigger the enable. Pulling oneself up by the bootlaces I expect.
I've been wondering whey I never really followed the logic behind how those on the forum have got tool changing to work.
So what is orient intended to do as I cannot picture what it can do if not related to a fixed point on the spindle.
A index relatable orient sounds like what I'd like, but not really got a clue how to start looking at that. Perhaps a bolt on python bit, a language I'm completely unfamiliar with. I'll do some research.
Thanks Andy.
Displaying 6526 - 6540 out of 13542 results.
Time to create page: 0.304 seconds
