  • sataran
  • sataran
22 Jan 2026 11:09
Bitfile or help – Mesa 6i25 + 7i74 (BiSS-C) + 8i20 + 7i70/7i87
Category: Driver Boards
i am not making any progress so let take a step back.
i use a bit file PIN_7I76_7I74BISS3D_34 With the biss signal assigned to a 7i74 plugged on the port P2 with the pin configuration :
        IOPortTag & x"00" & BISSTag  & BISSDataPin,             -- I/O 17    PIN 1
        IOPortTag & x"01" & BISSTag  & BISSDataPin,             -- I/O 18    PIN 14
        IOPortTag & x"02" & BISSTag  & BISSDataPin,             -- I/O 19    PIN 2
        IOPortTag & x"00" & NullTag & x"00",                    -- I/O 20    PIN 15
        IOPortTag & x"00" & BISSTag  & BISSClkPin,            -- I/O 21    PIN 3
        IOPortTag & x"01" & BISSTag  & BISSClkPin,            -- I/O 22    PIN 16
        IOPortTag & x"02" & BISSTag  & BISSClkPin,            -- I/O 23    PIN 4
I dont understand yet why we have 3 pin for data and 3 for clock but its fine.
the objective now is to get the system to produce at least a clock. with the cnc project running i tried to locate where the clock where available but nothing. I tested each port rj45 on my 7i74 and even the pin from the cable between my two card and nothing relevant. i got power (5v) some signal but no clock. do i need a command in hal/init /bit/god? to indicate that the signal should be active?
  • Hakan
  • Hakan
22 Jan 2026 10:36 - 22 Jan 2026 10:37
Replied by Hakan on topic Cia402 no connection
Category: EtherCAT
You still use hal files for simulation. Delete all hal files with sim in the name from the ini file.
  • Hakan
  • Hakan
22 Jan 2026 10:33 - 22 Jan 2026 10:34
Replied by Hakan on topic Kinko ECT coupler
Kinko ECT coupler
Category: EtherCAT
Try
          <pdoEntry idx="0x7020" subIdx="0x01" bitLen="8" halPin="out-byte-0" halType="bit"/>
Note the bit.
  • Hakan
  • Hakan
22 Jan 2026 10:30 - 22 Jan 2026 16:13
Replied by Hakan on topic Single LC10E-600W Driver Not Responding
Category: EtherCAT
Not obvious what's wrong.
Start linuxcnc, try to move, stop linuxcnc. Then show the output of the command "sudo dmesg | tail -30"
Also the output from the linuxcnc start command.
I see you asked for something different in the second post.
Take the ini file from one of the simulated machines and change the ini file to include the cia402.hal from: here github.com/dbraun1981/hal-cia402/tree/main/example
  • Hakan
  • Hakan
22 Jan 2026 10:22
StepperOnline A6 Servos: Sync Error when closing LinuxCNC
Category: EtherCAT
You can try with the syncToRefClock option
<masters>
<master idx="0" appTimePeriod="1000000" refClockSyncCycles="1" syncToRefClock="true">
or if you have an old version of lcec, a minus sign
<master idx="0" appTimePeriod="1000000" refClockSyncCycles="-1">
  • MaHa
  • MaHa
22 Jan 2026 09:59
Replied by MaHa on topic G-Code Schleifen
G-Code Schleifen
Category: Deutsch
Das Forum war gestern so laggy, da kam connection_timed_out bevor die aktuelle Datei hochgeladen war.
  • bobwolf
  • bobwolf
22 Jan 2026 09:44
[WIP] IO_decoder: A modular High-Density USB I/O system (up to 128 pins)
Category: Show Your Stuff
I've decided to release a 'Starter Edition' for Arduino Uno to let everyone test the driver's performance. Details and download link are available in the technical thread here:
forum.linuxcnc.org/27-driver-boards/5823...cal-feedback-request
  • bobwolf
  • bobwolf
22 Jan 2026 09:37
Solving the USB Latency Dogma for HMI/MPG: Technical Feedback Request
Quick update: I’ve just finished the 'io_decoder _eval' firmware for Arduino Uno.
I'm currently drafting a quick-start guide and a wiring diagram to make the testing process as smooth as possible for everyone.
I expect to release the package (firmware + documentation) this weekend.
Stay tuned!
  • prokopcio
  • prokopcio's Avatar
22 Jan 2026 07:19
Laser Head Height Sensor – Looking for a Beta Tester
Category: Plasma & Laser
To clarify, the suggestion was not to validate use with Aerotech controllers. The thought was just that it should be simple enough to configure the analog input/output to use the sensor with the existing system available. That would allow testing the sensor's functionality under different conditions, if that would be of use to you.
It seems that I may not have fully understood what you expect and how you would like to test it.
  • grandixximo
  • grandixximo's Avatar
22 Jan 2026 07:18 - 22 Jan 2026 07:21
Replied by grandixximo on topic LinuxCNC S-Curve Accelerations
it is compatible with mesa default setup, but you need add the jerk parameters in the ini file, look at the axis_mm_scurve.ini file
I wanted some feedback from the community about s-curve, there a few considerations to make, not just jerk spikes
I think there are some choices to make, when trying to respect jerk limits, we can:
1 - Slow down at curvature changes: reduce Vel so the centripetal acceleration change is manageable. (this defeats high-speed machining)
2 - Modify the geometry: insert transition curves (clothoids, Bezier, splines) that have gradually changing curvature. This eliminates the discontinuity but changes the path. (when G64 Px is too small you will see jerk spikes)
3 - Accept the spike: the programmed path has a curvature discontinuity, so the motion will too.
There is no fourth option. You cannot maintain velocity, follow the exact programmed path, AND have smooth jerk. we need pick two.
  • cmorley
  • cmorley
22 Jan 2026 05:12
Replied by cmorley on topic Generating a own Popup
Category: Qtvcp
ok let's try this:
Since your handler isn't modified, replace it with the one I supplied. It's ok to keep your modified ui file in the config folder.
Of course you still need the INI changes.
If you do want to modify the original handler for other reasons, that can be done, you just need to add most of the code in the handler I supplied.
Just to be complete Qtvcp will use the default handler and ui files unless it find either or both in your config folder.
In the case of the handler file, it's possible to make a special handler file that loads the original and then extend it.
This is nice as if the handler gets updated in linuxcnc, you will get those changes and then the local changes are added on top.
  • yrsiddhapura
  • yrsiddhapura
22 Jan 2026 05:10
Replied by yrsiddhapura on topic LinuxCNC S-Curve Accelerations
Does it compatible with mesa based setup ??
  • MaHa
  • MaHa
22 Jan 2026 00:10 - 22 Jan 2026 00:37
G-Code Schleifen
Category: Deutsch
Neulich war ja die Rede von einem Parameterprogram für Vieleck, mit Eckverrundung. Meine Inspiration von gestern hat tatsächlich zu einem Ergebnis geführt.Es können die Anzahl Durchläufe pro Eckprofil, oder Anzahl Ecken mit Erhöhung um 1 bis Max Anzahl Ecken eingstellt werden, und natürlich der Eckradius und Umkreis.Nach der Sternchenlinie würde ich nicht zwingend etwas ändern. Drehzahl brauchte es bei mir, um G1 zu simulieren.Die Aktuelle Einstellung geht von 3 bis 22 Ecken mit Eckradius 5
  • Lcvette
  • Lcvette's Avatar
22 Jan 2026 00:06
Replied by Lcvette on topic Probe Basic Stable error
Category: QtPyVCP
Check you hardware estop configuration
  • phino
  • phino
22 Jan 2026 00:05
Hi, Unfortunately, I have no experience with Aerotech.
As I mentioned, the sensor was developed for my own needs, but I would like it to be easy to use also in open-source control systems such as LinuxCNC.
Trying to use it at this stage in closed, good working solutions does not make sense.
I appreciate your willingness to support me, but at this point it is not a good idea.
Understandable. I agree with the aim of validating the functionality of the sensor with open source controllers like LinuxCNC.
Looking forward to seeing tests of this sensor by others with LinuxCNC-based laser systems.
Displaying 7501 - 7515 out of 13543 results.
Time to create page: 1.174 seconds
