  • andrax
  • andrax's Avatar
16 Jan 2026 17:38
Replied by andrax on topic StepperOnline A6 Servo
Category: EtherCAT
Hello,
since my problems persist and one Y-axis does not move during homing, and I don't give up so easily, I tried “dmesg” and “ethercat slaves -v” again.I see two errors in the output:[  459.958251] EtherCAT WARNING 0-1: Slave did not sync after 5000 ms.[   13.362825] EtherCAT ERROR 1: Failed to calculate bus topology.Otherwise, everything is OK and the drives go to OP.Where could the problem be?I also don't understand why I have to turn off the servos and Linuxcnc and restart them for homing to work.
  • slowpoke
  • slowpoke
16 Jan 2026 17:18
Cloning LinuxCNC - Axis and Mesa 7196s was created by slowpoke
Category: Installing LinuxCNC
I'm putting together my third LinuxCNC system. Using Axis and a Mesa 7i96s
This one will be an almost direct copy of a previous installation I did for my small lathe, this time for a new lathe.
To get started I ran the PCNConf wizard skipping over some of the configuration just to get to the point where LinuxCNC will launch.
Now I'm hoping to simply substitute in a copy of the hal files from my old installation (basically replace the hal files PcnConf made with my old tried and true hal files).
Does this sound like a viable plan?
Possible wrinkles:
One possible wrinkle is that I needed more I/O on the previous 7i96s and I did some sort of "firmware upgrade" to the 7i96s to get more encoders via the expansion port so I will need to do that again. need to see if I can find my notes for that. Also not sure if the old upgrade file is still viable?
Both setups use a Lenovo Yoga, however the latest one  (Chromebook C340) requires a USB-C to dock to get an Ethernet connection. I picked up a dock from Amazon (UGREEN) and have managed to get the Mesa card recognized by LinuxCNC but the mouse (also connected to the dock) seems to go to sleep (often) and I have changed the power saving setting to stop this, but they don't seem to be preventing mouse sleeps. My concern is that the entire dock might be going to sleep including the Ethernet port.
Any advice is welcome.
  • Unlogic
  • Unlogic
16 Jan 2026 16:18
Replied by Unlogic on topic I got a medal!
I got a medal!
Congratulations!
  • Aciera
  • Aciera's Avatar
16 Jan 2026 15:39
Replied by Aciera on topic Terminal Display
Terminal Display
Category: Basic Configuration
Looks like you have a print statement that prints the current axis position somewhere in your code.
  • wildcam45
  • wildcam45
16 Jan 2026 14:29
StepperOnline A6 Servos: Sync Error when closing LinuxCNC
Category: EtherCAT
Hi
I got tree Stepperonline A6 servo motors up and running in XYZ mode using the attached files. When I close LinuxCNC, however, all three drivers show error ErC 1.1, i.e. Sync Error. When I start LinuxCNC again, the errors disappear. So it is not a big deal, but it is ugly to see that the program was not terminated in a decent way.
I suppose that there must be some appropriate commands in the shutdown.hal file. I tried a lot of things, but none of them worked. Dies anyone know what to put in the shutdown.hal file to prevent the sync error or is there an other way to prevent this error?
File Name: Basic_2026...16-2.hal
File Size:5 KB
File Name: EtherCat_2...1-16.ini
File Size:3 KB
File Name: ethercat-conf.xml
File Size:6 KB
16 Jan 2026 13:48
Replied by tommylight on topic Can my account and post history be deleted please
Category: Forum Questions
Frankly I don't see the point of deleting 1000+ posts and leave god knows how many threads disjointed even if I could think of an easy way to do it.
Same here, especially now that i know you were the one doing huge moral support when i built my second shop.
  • jschulze
  • jschulze
16 Jan 2026 12:54
Replied by jschulze on topic For a full-fledged Press Brake GUI
Category: Other User Interfaces
I've got a press retrofit in progress and this sounds great.  I've got quite a bit of work to do hardware wise, but I'd be happy to test when I get things moving.
  • timo
  • timo
16 Jan 2026 09:29
Trying to move from UCCNC to Linuxcnc and using 7i96s but having trouble
Category: StepConf Wizard
ChatGPT is not particularly useful with Linuxcnc. I worry when I ask AI a question and it quotes into I wrote on this forum back to me.
And then knowing the ratio between "dangerous half knowledge" and "expertise" for a fact makes it even scarier.
Suddenly your own work hypothesis becomes a fact and "best expert advise" one can find on the internet.
  • amanker
  • amanker
16 Jan 2026 08:54
I will try changing SPI cable with LAN cable. Which might work better in shielding external interference.
I have already tried STM32F4xx-PIO and STM32H7xx-PIO branches. H7xx works ok on SKR3 board.
But F4xx branch is not working with tmc5160 but working in step/dir mode. I have tested ben-jacobson branch github.com/ben-jacobson/Remora-STM32F4xx-PIO.git who is orginal developer of F4xx branch. I have posted issue on GIT about this but didnt got reply. Didnt tested remora-cnc branch which 28 commits less than ben's branch. and since it was forked out of ben's branch so didnt thought that it will work on remora-cnc branch.
for configuring tmc5160 via spi I have to change jumpers on board for SPI. Other option is, I should remain board jumpers in step/dir mode and run external spi wires connected to stepsticks (daisy chain) to RPI, which will make really mess.
  • Aciera
  • Aciera's Avatar
16 Jan 2026 08:23
All I can offer is to delete your user profile.
  • juliankoenig87
  • juliankoenig87
16 Jan 2026 05:33
Replied by juliankoenig87 on topic 4th axis scale factor (steps per degree)
Category: PathPilot
It is normal, that a HD doesnt have the exact 50 to 1 ratio. This is just a "rounded" number.
It depends on the "gears" and normally a 100 to 1 for example is 101 to 1. This is because the drive axis rotates in the opposite direction of the driven axis. So the difference is always +1
Best regards
Julian
  • NWE
  • NWE's Avatar
16 Jan 2026 05:22
Replied by NWE on topic For a full-fledged Press Brake GUI
But if you made something in flexGUI, it's probably not that hard to re-imagine it in Gladevcp or Qtvcp afterwards.
That is wonderful news. I am familiar with Gladevcp. I was reading lately how glade is outdated and Qt5/6 related is the way to go. I had made up my mind this is the project where I'll learn flexGUI. My enthusiasm failed me after I dived into it yesterday. I will happily continue with Gladevcp. I will learn FlexGUI eventually, but not in time for this project.
  • tcbmetalworks
  • tcbmetalworks
16 Jan 2026 02:27
Freelancer wanted to get tool sensor working (software)
Category: User Exchange
I have no experience with this particular issue and have never used linux cnc for milling/turning but I found Cursor a extremely valuable program for making custom software that operates with linux cnc. It still takes a ton of time and hassle but is still faster then becoming a expert in programing. Very likely is possible to modify dragon qt to have the features that you would like.
16 Jan 2026 00:51
WEMAS MT 32 CNC Lathe -> LinuxCNC - Mesa or EtherCAT?
Category: Turning
OK, lathe, so not my strong suite, so:
First, i am pretty sure it is doable, i am also pretty sure some of the forum users did manage to make this work fine and never bothered to report back on how they did it, and there are some with mixed success still active here.
Second, probably yes but never actually did that, although i would not mix manual and auto modes as inadvertently humans will mix those modes and on big machine that is always expensive.
As for turret/no turret pin, again most probably yes with some hal wizardry, might be quite easy i think.
Any way you look at it, almost anything within reason should be doable, although it is much easier to have 2 separate configs (not installations, just a config folder) and switch between them. I would like to insist on making this work first, then make another config for mixing and testing mixed mode.
  • Doc_emmet
  • Doc_emmet
16 Jan 2026 00:31
Terminal Display was created by Doc_emmet
Terminal Display
Hello, when I start LinuxCNC in the terminal and an axis of the machine moves, I get the following lines in the terminal:
3.446259842519685, 6.10236220472441, 6.399631496062992, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0], [3.302834645669291, 2.6091732283464566, 6.399631496062992, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0
Does anyone know how I can disable this?
Displaying 7741 - 7755 out of 13510 results.
Time to create page: 0.348 seconds
