  • Ismacr63
  • Ismacr63
27 Dec 2025 17:36
Replied by Ismacr63 on topic VFD configuration help
Category: Turning
I received the Suswe SU-600 VFD today. I started by getting the motor to rotate. I configured it in Advanced Vector Control with the parameters from the motor's nameplate, but it's not producing any torque. What parameters would I need to configure to get good torque at low RPMs? The motor is rated at 0.86 kW, 380 V, 2.1 A, and 1000 RPM.
  • RotarySMP
  • RotarySMP's Avatar
27 Dec 2025 17:29
How to install simplescreenrecorder on old version of Debian?
I am sticking with LCNC 2.7, as it will be a risk to update to 2.9, given the switch to joints, and the gearbox comp I have working.
I really just want simpescreenrecorder. I use this on both my lathes. I just have little clue of how to get the repository working.
I also tried this method, but it also failed.
  • rodw
  • rodw's Avatar
27 Dec 2025 17:09 - 27 Dec 2025 17:10
Well you could try upgrading to Trixie which has linuxcnc 2.95 and simplescreen recorder as standards. 2.97 is included in testing so you can use APT pinning to get 2.9.7
packages.debian.org/search?keywords=simp...e=trixie§ion=all
  • NWE
  • NWE's Avatar
27 Dec 2025 16:45
DIY CNC Mill - Random Limit Switch Errors
Category: Milling Machines
I think I got it!
  • Use ferrites/EMI filters on the lines coming in and out of the VFD - this solved my problem!
I'm happy to hear of your success!
I want to add a clarification to that one bullet point: EMI filters are very good for the input side of VFDs, but don't try them on the output side unless they are listed for such use. The output side of a VFD produces such a high level of harmonics, a common emi filter will smoke. Ferrites are fine for input and output side.
  • tlightus
  • tlightus
27 Dec 2025 16:33
calling subroutine from G54, G55, G56, but it acts weird
Category: O Codes (subroutines) and NGCGUI
i did notice you use machine zero as the G54 offset. try setting it off that and run the test.
  • zippoffs
  • zippoffs's Avatar
27 Dec 2025 16:06
Replied by zippoffs on topic DIY CNC Mill - Random Limit Switch Errors
I think I got it!
I tried moving the AC lines by the BOB, but that didn't work, probably because I didn't move them far enough. Last night I added a ferrite on the AC lines, and I was able to run the program without failing. This morning I removed the earth ground because it was temporarily through my window, and ran the program again. It did fail.
When I started building it I had installed an EMI filter on the main power coming in, before the breaker box. I now realize that anything coming in is negligible compared to what the VFD produces. So I moved the filter to the VFD 220v lines. I think that fixed it! I have now run the program three times without fail! (see pic)
Thank you everyone for your help!
For those looking at this later, here is what I learned:
  • Interference is a BIG ISSUE
  • Separate AC and DC lines as much as possible
  • Use shielding on low voltage signal lines (maybe fine without if 24v)
  • Use a shielded spindle cable and keep it short!
  • Ground all shielding, but only at one end
  • Avoid ground loops - only have one ground connection for each component
  • Ferrites may help stop interference - try putting them if other things don't work
Do these things from the beginning! It will save you a huge headache.
  • grandixximo
  • grandixximo's Avatar
27 Dec 2025 15:44
Replied by grandixximo on topic Ethercat random jitter fix
Category: EtherCAT
github.com/linuxcnc-ethercat/linuxcnc-et...631ab668516b649fcaaf
Posted the PR
Will be happy to get some feedback, thanks
  • dann1324
  • dann1324
27 Dec 2025 13:46
Replied by dann1324 on topic 7c81 + 7i73
7c81 + 7i73
Category: Driver Boards
Okay,I did a dumb haha. I got a little too hung up on pncconf not picking up the 7i73. So I started linuxcnc and ran halcmd show pin | grep 7i73 and they're all there. I'm just going to set my pins in my hal file and it should be good to go
  • dann1324
  • dann1324
27 Dec 2025 13:09
7c81 + 7i73
Thanks for the quick response. I ran mesaflash --device 7c81 --addr /dev/spidev0.0 --spi --sserial and seems like it's communicating with the 7i73! I'm still not sure why pncconf isn't showing it? Is there some extra hal configuration that I need to do?
Here's the truncated output from the mesaflash command, just to show it is there
SSLBP port 0:
SSLBP Version: 1.43
SSLBP Channels: 2
SSLBP Baud Rate: 2500000
sserial device at channel 1: 7I73 (unit 0x130001F9)
SwRevision = 14
HwRevision = 1
NVBaudRate = 2.5Mb
NVUnitNumber = 0x130001F9
NVWatchDogTimeout = 50ms
  • RotarySMP
27 Dec 2025 12:31
I could but that is a pretty huge overhead on a old pc.
27 Dec 2025 12:22
No idea, but you can always use OBS-Studio
sudo apt install obs-studio
27 Dec 2025 12:20
Replied by tommylight on topic Bluetooth Mouse on Linuxcnc
Category: Basic Configuration
2.9.4 is based on Debian 12 so might have better luck asking on Debian forums.
  • MaHa
  • MaHa
27 Dec 2025 11:16
  • Lili
  • Lili
27 Dec 2025 10:57
Bluetooth Mouse on Linuxcnc was created by Lili
i installed Linuxcnc 2.9.4 , and would like to use Mouse with bluetooth(logitech m350s).
kommand sudo apt update shows that adding this repository is not safe and disabled by default.
WHAT TO DO ?:)
  • RotarySMP
27 Dec 2025 10:16
Hi All,
My Maho 400E is still running an old version of Debian, with XFCE, that would have been the live CD back in about 2019. For my videos, I need to install simplescreenrecorder, as pointing a camera at the screen is lame.
I have tried:
sudo apt-add-repository ppa:maarten-baert/simplescreenrecorder
sudo apt update
sudo apt install simplescreenrecorder
This fails with "unable to locate simplescreenrecorder."
Please help with this. I seem to forget all linux knowledge the instant whatever I was trying to do gets done :/
Cheers,
Mark
Displaying 8581 - 8595 out of 13507 results.
Time to create page: 3.400 seconds
