  • sorokin_pro
  • sorokin_pro's Avatar
26 Dec 2025 21:44 - 26 Dec 2025 21:45
Replied by sorokin_pro on topic Mesa 6i25 not working?
Category: Driver Boards
Looks like LinuxCNC detects the board:
user@denc:~$ linuxcnc
LINUXCNC - 2.9.7
Machine configuration directory is '/home/user/linuxcnc/configs/BenchtopX5'
Machine configuration file is 'BenchtopX5.ini'
Starting LinuxCNC...
Note: Using POSIX realtime
Found file(REL): ./BenchtopX5.hal
hm2_pci: loading Mesa AnyIO HostMot2 driver version 0.7
hm2_pci: discovered 5i25 at 0000:02:00.0
hm2/hm2_5i25.0: Low Level init 0.15
hm2/hm2_5i25.0: Smart Serial Firmware Version 43
hm2/hm2_5i25.0: 34 I/O Pins used:
hm2/hm2_5i25.0: IO Pin 000 (P3-01): StepGen #0, pin Direction (Output)
hm2/hm2_5i25.0: IO Pin 001 (P3-14): StepGen #0, pin Step (Output)
hm2/hm2_5i25.0: IO Pin 002 (P3-02): StepGen #1, pin Direction (Output)
hm2/hm2_5i25.0: IO Pin 003 (P3-15): StepGen #1, pin Step (Output)
hm2/hm2_5i25.0: IO Pin 004 (P3-03): StepGen #2, pin Direction (Output)
hm2/hm2_5i25.0: IO Pin 005 (P3-16): StepGen #2, pin Step (Output)
hm2/hm2_5i25.0: IO Pin 006 (P3-04): StepGen #3, pin Direction (Output)
hm2/hm2_5i25.0: IO Pin 007 (P3-17): StepGen #3, pin Step (Output)
hm2/hm2_5i25.0: IO Pin 008 (P3-05): StepGen #4, pin Direction (Output)
hm2/hm2_5i25.0: IO Pin 009 (P3-06): StepGen #4, pin Step (Output)
hm2/hm2_5i25.0: IO Pin 010 (P3-07): IOPort
hm2/hm2_5i25.0: IO Pin 011 (P3-08): IOPort
hm2/hm2_5i25.0: IO Pin 012 (P3-09): IOPort
hm2/hm2_5i25.0: IO Pin 013 (P3-10): IOPort
hm2/hm2_5i25.0: IO Pin 014 (P3-11): IOPort
hm2/hm2_5i25.0: IO Pin 015 (P3-12): IOPort
hm2/hm2_5i25.0: IO Pin 016 (P3-13): IOPort
hm2/hm2_5i25.0: IO Pin 017 (P2-01): IOPort
hm2/hm2_5i25.0: IO Pin 018 (P2-14): IOPort
hm2/hm2_5i25.0: IO Pin 019 (P2-02): IOPort
hm2/hm2_5i25.0: IO Pin 020 (P2-15): IOPort
hm2/hm2_5i25.0: IO Pin 021 (P2-03): IOPort
hm2/hm2_5i25.0: IO Pin 022 (P2-16): IOPort
hm2/hm2_5i25.0: IO Pin 023 (P2-04): IOPort
hm2/hm2_5i25.0: IO Pin 024 (P2-17): IOPort
hm2/hm2_5i25.0: IO Pin 025 (P2-05): IOPort
hm2/hm2_5i25.0: IO Pin 026 (P2-06): IOPort
hm2/hm2_5i25.0: IO Pin 027 (P2-07): IOPort
hm2/hm2_5i25.0: IO Pin 028 (P2-08): IOPort
hm2/hm2_5i25.0: IO Pin 029 (P2-09): IOPort
hm2/hm2_5i25.0: IO Pin 030 (P2-10): IOPort
hm2/hm2_5i25.0: IO Pin 031 (P2-11): IOPort
hm2/hm2_5i25.0: IO Pin 032 (P2-12): IOPort
hm2/hm2_5i25.0: IO Pin 033 (P2-13): IOPort
hm2/hm2_5i25.0: registered
hm2_5i25.0: initialized AnyIO board at 0000:02:00.0
Found file(REL): ./custom.hal
link (updating variable file): No such file or directory
No option 'tto_g11' in section: 'DEFAULT'
No option 'show_program' in section: 'DEFAULT'
No option 'show_rapids' in section: 'DEFAULT'
No option 'program_alpha' in section: 'DEFAULT'
No option 'show_live_plot' in section: 'DEFAULT'
No option 'show_tool' in section: 'DEFAULT'
No option 'show_extents' in section: 'DEFAULT'
No option 'show_offsets' in section: 'DEFAULT'
No option 'grid_size' in section: 'DEFAULT'
No option 'show_machine_limits' in section: 'DEFAULT'
No option 'show_machine_speed' in section: 'DEFAULT'
No option 'show_distance_to_go' in section: 'DEFAULT'
No option 'dro_large_font' in section: 'DEFAULT'
No option 'block_delete' in section: 'DEFAULT'
No option 'optional_stop' in section: 'DEFAULT'
note: MAXV max: 25.000 units/sec 1500.000 units/min
note: LJOG max: 25.000 units/sec 1500.000 units/min
note: LJOG default: 6.000 units/sec 360.000 units/min
note: AJOG max: 180.000 units/sec 10800.000 units/min
note: AJOG default: 12.000 units/sec 720.000 units/min
note: jog_order='XYZA'
note: jog_invert=set()
Would be great if mesaflash also could detect it.
  • Routercnc
  • Routercnc
26 Dec 2025 21:24 - 27 Dec 2025 11:23
Replied by Routercnc on topic Probe panel for Axis GUI
Category: AXIS
Olá a todos.
Tentei usar o EasyProbe na minha fresadora CNC. Instalei seguindo o vídeo do Talla83, mas ao calibrar, aparece a seguinte mensagem: "A sonda já está ativada" ao iniciar o comando G38.2 ou G38.3, e ao zerar manualmente, aparece outra mensagem: "Código M desconhecido usado: M130..."
Anexei os arquivos .hal, .ini e Probe_postgui.
O que estou fazendo de errado?
File Name: Probe_postgui.hal
File Size:8 KB
File Name: eng-eth.hal
File Size:8 KB
File Name: eng-eth.ini
File Size:6 KB
  • PCW
  • PCW's Avatar
26 Dec 2025 19:48
Replied by PCW on topic Mesa 6i25 not working?
If you launch LinuxCNC from the command line, you will get a list as the hardware is discovered
which should help with debugging
The timer issue is possibly  that the installed firmware lacks a DPLL timer
(and pncconf always puts DPLL timer boilerplate in the hal file)
 You can work around this by deleting (or commenting out)  any lines that
mention "dpll" in the hal file
26 Dec 2025 19:43
No speed control on xhc-wb04b-6 pendant on 3 axis router
Category: Basic Configuration
I'm still amazed a 10mA signal could smoke like that.
[/quote]
It is enough to start a chain reaction, same as throwing a wrench on any complicated machinery, no matter how small.
As for the subject, i used a Mesa 7i77 to drive a car power amplifier as a servo drive, so i had to limit voltage from going above +-2V and it worked pretty good, given the limited current those amplifiers can deliver (it will trigger over current on any faster move), but i forgot how i did the limiting in hal, pretty sure it was the MAX and MIN OUTPUT set to 2, but fuzzy on what else.
I also did 0 to +5V and it also worked, but tried with those arduino PWM drives and that did not work as analog and PWM are not the same, you can do analog from PWM easily with an RC, but not vice versa.
This was probably 10 or more years ago...
  • aDm1N
  • aDm1N's Avatar
26 Dec 2025 19:41
LatheEasyStep – experimental QtVCP macro for step-by-step lathe programming
Category: Qtvcp
I know the macros, and I think they are useful. But my goal is something more holistic, closer to the way I’m used to working.I want to create a program, work through it step by step, and be able to go back at any time to change something or reuse individual steps. That’s how I’ve always worked on industrial machines. At work, I actually always wanted to use Heidenhain controls, but in reality I mostly ended up with Siemens. Both are good systems, but they offer a structured, process-oriented way of programming that goes beyond single, isolated macros.As far as I know, LinuxCNC doesn’t really offer something like this out of the box. That’s why I started writing it myself, and I will continue developing it until it reaches a level where I’m satisfied with the result – no matter how long that takes.The existing macros are good, but they usually solve only one small task at a time. For me, that’s not enough. I’m looking for a workflow-oriented solution, not just individual helpers.I’m primarily writing this for myself, because I plan to actually work with it later. I do think other people could benefit from it as well, but that’s just my personal opinion. For that reason, I’ve already made the current state partially functional and public. It is clearly not finished.If there is a better, complete solution available, I’m happy to look at it. If not, I will carry this project through to the end, because in the end I need a tool that fits my way of working.If you know of existing concepts, examples, or similar approaches, feel free to point them out. I’m always open to ideas.
  • NWE
  • NWE's Avatar
26 Dec 2025 19:15 - 26 Dec 2025 19:17
and sometimes with smoke signals...
Ouch! been there done that. I'm still amazed a 10mA signal could smoke like that.
26 Dec 2025 19:06
A friendly warning, Mesa 7i77 can output negative voltages up to -10V, and most VFD's will complain about it vigorously and sometimes with smoke signals, so it would be advisable to wait for someone more experienced on how to limit the Mesa output going negative by probably editing the hal file and/or even using ABS component.
26 Dec 2025 19:02
Replied by tommylight on topic Mesa 6i25 not working?
The config generated by PncConf, edit the .hal file with a text editor (not libreoffice) and omit or delete the line containing DPLL timer, savem start the config again.
  • NWE
  • NWE's Avatar
26 Dec 2025 18:33 - 26 Dec 2025 18:44
DIY CNC Mill - Random Limit Switch Errors
Category: Milling Machines
BOB is probably grounded by parallel cable to pc. Check with ohm-meter. In that case do not ground BOB additionally. Also any shielded wires connected to BOB must be connected to BOB's frame ground but not to anything else.
Frame ground and DC voltage negative wire frequently not the same and might not be connected together, in that case shields preferably connect to frame ground, not DC-
  • sorokin_pro
26 Dec 2025 18:32
This is the part I did not figure out for now.
I tried loading the configuration from PnCconf, but LinuxCNC crashed because some timer was not found. I commented out two lines in the .ini file, and LinuxCNC launched, but I do not know where I can see if it found the card.
Should I just try running some G-code?
This is my first time with MESA and LinuxCNC, but I have experience with industrial CNC machines, 3D printers, Linux, software development, and electronics.
  • NWE
  • NWE's Avatar
26 Dec 2025 18:27
I have only ever experienced issues when the VFD is on.
I tried disconnecting everything from the BOB except for the 24v coming in and the parallel port and USB from the PC (I switched the VFD to manual control). LinuxCNC ran the program with out any trips even though the VFD was running, so the BOB itself can't be the issue. I tried reconnecting one of the stepper driver pulse/direction signal wires (the steppers were completely off) and ran the program again, and it did trip, even though that wire is shielded and grounded.
Sounds like effects of a ground loop. You have more than one ground connection from point A to point B at one or more points anywhere on the system. You want exactly one ground circuit from each 'groundable' piece to one single point. It is called single point ground aka star connection. Redundant ground paths create ground loops which powerfully amplify interference effects from the vfd, they behave as you described above.
Potential sources of redundant grounds:
1. shield grounded at both ends
2. motor cord have ground wire
3. additional frame ground to the machine when the motor is already in electrical contact with the machine
4. the machine may be in physical conductive contact with another machine that is also grounded
5. is the machine on a steel workbench that has a grounded outlet?
Interference mitigation can be a bit of an art because of the numerous variables involved. Usually not everything has to be perfect, you can cheat some, but if the BOB is within inches of any AC when there is also a VFD nearby then I say you will have trouble at least randomly.
  • PCW
  • PCW's Avatar
26 Dec 2025 18:18
Does LinuxCNC see the card?
  • Hakan
  • Hakan
26 Dec 2025 18:13
Ver 2.9.4 iso clean install Trouble when disabling EOE
Category: EtherCAT
Good. EoE has to go.
But you see automata's posts here? Do not be surprised if it still does not work.
Thankfully, automata has kindly posted the solution here.
Please report back how it goes and if there are problems with lcec
I hope automata will guide you to use his solution.
  • RotarySMP
  • RotarySMP's Avatar
26 Dec 2025 17:54 - 26 Dec 2025 18:49
Category: Qtvcp
Do you already know Andy's lathe macros?
forum.linuxcnc.org/41-guis/26550-lathe-macros
The graphical interface is fantastic.
Rather than reinventing the wheel, have you considered what it is which you are adding with you macros? Maybe you can coordinate with Andy to make them even more awesome.
Cheers,
Mark
  • ihavenofish
  • ihavenofish
26 Dec 2025 17:54
lemontart - a call for help with s curve, ui's, and all the cool toys
Blocking in the "make yer own" accessories. side arm ISO20 ATC, Stand, stainless chip pan, enclosure... Fun :)
Displaying 8626 - 8640 out of 13507 results.
Time to create page: 0.515 seconds
