  • my1987toyota
  • my1987toyota's Avatar
31 Dec 2025 14:26
Replied by my1987toyota on topic Fusion 360 Win 10 EOL
Category: CAD CAM
So it's December 31st 2025 and I am curious if Fusion 360 will actually stop working on my Windows 10
machine at 12:00am January 1st 2026.  As I write this message it's 3:20 pm and currently Fusion 360 is
still operational.  I will keep it logged on to Linuxcnc and Fusion 360 and update on my findings.
With that said I am sure it is already January 1st somewhere in the world . Has any one tried seeing if
Fusion 360 still works for them on Win 10?
  • Surmetall
  • Surmetall's Avatar
  • Thllll
  • Thllll
31 Dec 2025 14:14
Freelancer wanted to get tool sensor working (software)
Category: User Exchange
Still looking for a freelancer to help get a tool sensor setup in software
  • RotarySMP
  • RotarySMP's Avatar
31 Dec 2025 13:56
Retrofitting a 1986 Maho MH400E
Category: Milling Machines
Thanks guys. I am collecting up the wisdom of the crowd, and will try to work through everything systematically.
  • Thllll
  • Thllll
31 Dec 2025 13:54
Replied by Thllll on topic QT Dragon Unable to Set Tool Height
Category: Qtvcp
Doesnt work in sim either
  • Joco
  • Joco's Avatar
31 Dec 2025 13:51 - 01 Jan 2026 01:51
MonoKrom - QtPyVCP GUI for PlasmaC and Mill
Category: QtPyVCP
That bug should be resolved in recent builds of the framework.  Its not a monokrom bug. It came out due to an errant print statement.
"What's the first rule?  Do NOT use print statements in the code.  Use LOG.debug"
  • Robin123
  • Robin123
31 Dec 2025 13:44
Replied by Robin123 on topic 7i97t Mesaflash Problem
I'm talking about the PWM value. So this value is a voltage value? Like 17V? I know how to limit this value. But I never measure this value on the Mesa. It's always only 0.35V as soon as I enable it.
  • PCW
  • PCW's Avatar
31 Dec 2025 13:40
Replied by PCW on topic 7i97t Mesaflash Problem
The output voltage should be PWMvalue/PWMscale
  • Thllll
  • Thllll
31 Dec 2025 13:31
How to setup a tool sensor was created by Thllll
Category: Gmoccapy
How do you setup a tool sensor exactly? I cant seem get it right after a week of trial and error of setups, parameters changes. This is not a wiring issue or a debounce issue but a setup issue.
Current Setup:
LinuxCNC 2.9.4
2" tool sensor on the bed
Attached is my setup files
From this document  linuxcnc.org/docs/stable/html/gui/gmocca...uto-tool-measurement  I cant tell if I am doing something wrong or where the discrepancy is.
[TOOLSENSOR]
X = 10
Y = 10
Z = -20
MAXPROBE = -20
This example setup would cause the Z axis to come down to get to the -20 setpoint. This results in a crash into the probe and a "Probe tripped during a non-probe move" would appear. The solution to this was to set the Z to 0 so the probing search would start immediately
For this next issue is touch off x and y (not z because the document says to press "Block Height") I immediatly get a error when pressing x or y touch off.
"G-code error in change.ngc near line 76, file ended with no percent sign(5) or program end (m2)"
Now if I just ignore these errors I get the same error when doing a tool change after it probes it.
  • RoKoTer
  • RoKoTer's Avatar
31 Dec 2025 13:23
Ethercat installation from repositories - how to step by step
Category: EtherCAT
@rodw Thanks for the guide, it really helped me! And some Claude assistance ;-)
  • RoKoTer
  • RoKoTer's Avatar
31 Dec 2025 13:14
Replied by RoKoTer on topic JMC Servo in PP mode
Category: EtherCAT
joshualee777,
Not sure if my Quick Reply was successful, so sorry for the duplicate post.
Hi! I've just successfully completed my initial test setup with a single JMC IHSV57. See github.com/rokoter/LinuxCNC/tree/main/ethercat/ihsv-homing. Hope it helps!
Launch LinuxCNC with cia402-ihsv-home-variant.ini
The Z startup error can safely be ignored :-)
  • Robin123
  • Robin123
31 Dec 2025 13:13
Yes, the value comes from the PID. My power amplifier is a -10/+10V. Is the value a voltage value? If the value is, for example, 17, I measure at the Mesa only 0.35V.
  • RoKoTer
  • RoKoTer's Avatar
31 Dec 2025 13:08
Category: EtherCAT
  • PCW
  • PCW's Avatar
31 Dec 2025 13:06
Yes, in the hal file, the analog outputs are all controlled by PWM values.
The actual PWM value shoudl be set by the output of a PID component that
in turn reacts to the difference in the encoder position to LinuxCNCs
commanded position.
  • Thllll
  • Thllll
31 Dec 2025 12:55
Replied by Thllll on topic Probe Error causes Jog lockout
Category: QtPyVCP
It wont let you change the mode, its gets locked out. I gave up on getting probe basic to work
Displaying 9496 - 9510 out of 11220 results.
Time to create page: 0.769 seconds
