  • Hakan
  • Hakan
23 Dec 2025 02:16 - 23 Dec 2025 02:17
Ver 2.9.4 iso clean install Trouble when disabling EOE
Category: EtherCAT
Hello Mr tar_san,
the output of dmesg was very helpful. We need to fix all issues appearing,
the first one is your drive is a EoE-capable drive. Ethernet over Ethercat.
Unfortunately linuxcnc doesn't support that.
The best way is to disable eoe in the ethercat mastyer.
Remove the installed ethercat master.
Then download ethercat master from the official site
Configure using the --disable-eoe=true option
git clone https://gitlab.com/etherlab.org/ethercat
./bootstrap
./configure --sysconfdir=/etc --disable-eoe=true
make all modules
... and so on, continue to build and configure your system. Instructions are here.
gitlab.com/etherlab.org/ethercat/-/blob/stable-1.6/INSTALL.md
There is another possibility to disable EoE, but that disables EoE in the drive, and I would think
you need EoE for communication with some Yaskawa tuning software. Guessing, but not unlikely.
Test with the new ethercat master, the EoE messages should now be gone.
Let's see how many of the other messages are still there and then we act on them.
Referring to my previous post. Please add on the master line
<master idx="0" appTimePeriod="1000000" refClockSyncCycles="1" syncToRefClock="true">
If syncToRefClock gives an error because it is not supported (yet), use the following syntax:
<master idx="0" appTimePeriod="1000000" refClockSyncCycles="-1">
Note the minus sign.
Let's see how far you come with those modifications. If there are still problems,
please show the output of dmesg again, and any errors from linuxcnc.
  • Nator
  • Nator
23 Dec 2025 02:10
Replied by Nator on topic Mesa Card Basics
Mesa Card Basics
Category: Driver Boards
HI PCW,
thank you for your Answer!
But for a better understanding. How is the communication between LinuxCNC and the Card done? With the LPT "communication" the LinuxCNC software gets a command to go 3mm in X direction, so "itself" sends the pulses on the LPT in the (hopefully) correct speed.
Does LinuxCNC still sends "pulses" when it has a mesa card and the card only corrects the jitters? Or is there some kind of communication so that LinuxCNC just sends go 3mm in that speed and the card does the pulses? LinuxCNC then know how long it takes for that movement and after this time it send the next command.
With the second approach it would probably be really hard to do something like probing.
Thanks !
  • cmorley
  • cmorley
22 Dec 2025 23:26
Replied by cmorley on topic qtdragon_hd updated handler issue
Category: Qtvcp
I checked 2.9.7 and 2.9.3. I see no jogging with screen buttons issue.
I'm assuming you mean the screen buttons.
It could be a key repeat issue.
I would suggest updating your whole system to 2.9.7 before I'd suggest updating the handlerfile, but we should see if it's a system problem first.
  • Thllll
  • Thllll
22 Dec 2025 21:24
Probe Error causes Jog lockout was created by Thllll
Category: QtPyVCP
2.9.4, Probe Basic
Probing failure either a g38.2 or g38.3 locks out the jog,
Estop cycle , machine power cycle , probe on or off, homing, locks out jogging in all directions. Any way to reset this without restarting Linuxcnc?
  • EW_CNC
  • EW_CNC's Avatar
22 Dec 2025 20:57
Ohmic Probe + Material Height Feature Request
Category: Plasmac
Ok, Sounds Good.
I'll update and give it a try.
Thanks!
  • snowgoer540
  • snowgoer540's Avatar
22 Dec 2025 19:35
Replied by snowgoer540 on topic Ohmic Probe + Material Height Feature Request
Category: Plasmac
I finally got this to the finish line.  Thank you for what you provided, but from a qtplasmac standpoint all development on 2.9 has ceased.  I have pushed this update, and book ended it with some bug fixes, but to the master branch only (2.10).
github.com/LinuxCNC/linuxcnc/commit/4e26...712bc80a993377610a37
Your way seems like it would work though.
All that said, I would encourage you to move to 2.10 and test these features if your production risks allow it.  There have been a fairy amount of bug fixes/feature updates since 2.9.
  • PCW
  • PCW's Avatar
22 Dec 2025 18:43
7i84 doesn't fault LInxuCNC when SSerial is interrupted
LinuxCNC should report the error
If you need LinuxCNC to do a specific response to the error
you would need to set that up in the hal file
  • Sirfrimfram
  • Sirfrimfram
22 Dec 2025 18:12
Hello,
I'm using a 7i96S with a 7i84U daughter board. Everything is working reasonably well except that when the smart serial fails Linuxcnc doesn't fault. I can manually restart the 7i84 by toggling the smart serial run pin but I was wondering if I missed something since linuxcnc continues to run with whatever the last values of the I/o pins on the 7i84.
  • PCW
  • PCW's Avatar
22 Dec 2025 17:44 - 22 Dec 2025 17:45
Replied by PCW on topic Mesa Card Basics
Mesa Card Basics
Things like probe inputs are sampled at the servo thread rate ( typically 1 KHz )
by LinuxCNC's motion component. Typically probing ( and homing ) is done in
two steps with a higher velocity search motion followed by a lower velocity latch
motion. You would normally choose a latch velocity low enough that the 1 ms
(max) sampling uncertainty causes a minimal position error when probing.
Mesa hardware does have the capability of latching encoder or stepgen counts
at probe activation, but this is currently not supported by LinuxCNC.
  • tar_san
  • tar_san
22 Dec 2025 16:41
Category: EtherCAT
Thank you so much, Mr. Hakan. I really appreciate your kind reply.
I'm using LinuxCNC 2.9.5 and 3axis machine, and I want to replace servomotors to YASKAwA servo systems.  ( I think I can upgrade LinuxCNC to the newest if needed)
Now, I deleted SDO description, but I still get A12 Error. Xml configuration for lcec is very simple. (attached ethercat.xml)
So, EtherCAT basic communication is wrong. ( I have to solve it before SDO error. )
This is sudo dmesg output(dmsg_alarm_a12_2).
I can see a lot of WARNINGS and Errors, but How can I fix these problems for YASKAWA Servo?
  • Nator
  • Nator
22 Dec 2025 16:25
Mesa Card Basics
some more questions from me:
Assuming using a 3D probe with one signal to use (NC or NO does not matter to me). How is this handled inside a Mesa Card? Is it just read and then put through to linuxCNC and then LinuxCNC is reacting on this saying "stop"? How does LinuxCNC knows where it is? Or is there some kind of interrupt going on and the fpa itself is stopping the movement and "sending" back some information to LinuxCNC how much steps it did to reach this position?
How fast is the Data Transfer through ethernet? And isn't it a problem for the probe process itself when the Card does all the stepping stuff? How does LinuxCNC knows how much steps have been done?
regards Han
  • aDm1N
  • aDm1N's Avatar
22 Dec 2025 15:58 - 22 Dec 2025 16:01
LatheEasyStep – experimental QtVCP macro for step-by-step lathe programming
Category: Qtvcp
So, it seems I've managed to get the contour pretty well right. It's coming along slowly. It took me quite a while to get it to this point.
  "op_type": "contour",
  "params": {
    "start_x": 0.0,
    "start_z": 0.0,
    "coord_mode": 0.0,
    "segments": [
        "mode": "xz",
        "x": 15.0,
        "z": 0.0,
        "x_empty": false,
        "z_empty": false,
        "edge": "radius",
        "edge_size": 5.0,
        "arc_side": "auto",
        "arc_side_raw": ""
        "mode": "xz",
        "x": 15.0,
        "z": -15.0,
        "x_empty": false,
        "z_empty": false,
        "edge": "none",
        "edge_size": 0.0,
        "arc_side": "auto",
        "arc_side_raw": ""
    "name": "radius"
  "primitives": [
      "type": "line",
      "p1": [
        0.0,
        0.0
      "p2": [
        10.0,
        0.0
      "type": "arc",
      "p1": [
        10.0,
        0.0
      "p2": [
        15.0,
        -4.999999999999999
      "c": [
        10.0,
        -5.0
      "ccw": false
      "type": "line",
      "p1": [
        15.0,
        -4.999999999999999
      "p2": [
        15.0,
        -15.0
  "params": {
    "start_x": 0.0,
    "start_z": 0.0,
    "coord_mode": 0.0,
    "segments": [
        "mode": "xz",
        "x": 15.0,
        "z": 0.0,
        "x_empty": false,
        "z_empty": false,
        "edge": "chamfer",
        "edge_size": 5.0,
        "arc_side": "auto",
        "arc_side_raw": ""
        "mode": "xz",
        "x": 15.0,
        "z": -15.0,
        "x_empty": false,
        "z_empty": false,
        "edge": "none",
        "edge_size": 0.0,
        "arc_side": "auto",
        "arc_side_raw": ""
    "name": "Fase"
  "primitives": [
      "type": "line",
      "p1": [
        0.0,
        0.0
      "p2": [
        10.0,
        0.0
      "type": "line",
      "p1": [
        10.0,
        0.0
      "p2": [
        15.0,
        -5.0
      "type": "line",
      "p1": [
        15.0,
        -5.0
      "p2": [
        15.0,
        -15.0
  • DerKlotz
  • DerKlotz
22 Dec 2025 09:42
SolidCAM 2021 remove remaining material was created by DerKlotz
Category: CAD CAM
Hello,iI am just starting to use SolidCAM.
Attached is a picture of a part that I would like to mill. The other picture shows the part after tool simulation. Material remains on the bevel. How can I remove the remaining material for example with a 3 mm ball end mill? SolidCAM has the standard milling cutters, and I added a 3 mm ball end mill manually.
  • Hakan
  • Hakan
22 Dec 2025 09:12
Replied by Hakan on topic leadshine R3EC
leadshine R3EC
Category: EtherCAT
Check the last say 10-20 lines of the output of "sudo dmesg".The ethercat master
always tells why (in a not so obvious way) why slaves won't go OP.
  • Ahmed.emara
  • Ahmed.emara
22 Dec 2025 09:01
leadshine R3EC was created by Ahmed.emara
leadshine R3EC
Category: EtherCAT
hello guys
i really need help with configuring R3EC IO coupler + R3 1600 DI + R3 0016-P DO ,to my etherCAT system,
i wrote XML file but when i check the status of the slaves all the drivers are in OP mode except the R3EC is in SAFEOP and it does not switch to OP mode,
here is the XML section for the R3EC i used :
<slave idx="6" type="generic" vid="0x00004321" pid="0x61400025" configPdos="true">
<!-- SM2: Outputs -->
<syncManager idx="2" dir="out">
<pdo idx="0x7000">
<pdoEntry idx="0x7000" subIdx="0x01" bitLen="16" halType="complex">
<complexEntry bitLen="1" halPin="do-01" halType="bit"/>
<complexEntry bitLen="1" halPin="do-02" halType="bit"/>
<complexEntry bitLen="1" halPin="do-03" halType="bit"/>
<complexEntry bitLen="1" halPin="do-04" halType="bit"/>
<complexEntry bitLen="1" halPin="do-05" halType="bit"/>
<complexEntry bitLen="1" halPin="do-06" halType="bit"/>
<complexEntry bitLen="1" halPin="do-07" halType="bit"/>
<complexEntry bitLen="1" halPin="do-08" halType="bit"/>
<complexEntry bitLen="1" halPin="do-09" halType="bit"/>
<complexEntry bitLen="1" halPin="do-10" halType="bit"/>
<complexEntry bitLen="1" halPin="do-11" halType="bit"/>
<complexEntry bitLen="1" halPin="do-12" halType="bit"/>
<complexEntry bitLen="1" halPin="do-13" halType="bit"/>
<complexEntry bitLen="1" halPin="do-14" halType="bit"/>
<complexEntry bitLen="1" halPin="do-15" halType="bit"/>
<complexEntry bitLen="1" halPin="do-16" halType="bit"/>
</pdoEntry>
</pdo>
</syncManager>
<!-- SM3: Inputs -->
<syncManager idx="3" dir="in">
<pdo idx="0x6000">
<pdoEntry idx="0x6000" subIdx="0x01" bitLen="16" halType="complex">
<complexEntry bitLen="1" halPin="di-01" halType="bit"/>
<complexEntry bitLen="1" halPin="di-02" halType="bit"/>
<complexEntry bitLen="1" halPin="di-03" halType="bit"/>
<complexEntry bitLen="1" halPin="di-04" halType="bit"/>
<complexEntry bitLen="1" halPin="di-05" halType="bit"/>
<complexEntry bitLen="1" halPin="di-06" halType="bit"/>
<complexEntry bitLen="1" halPin="di-07" halType="bit"/>
<complexEntry bitLen="1" halPin="di-08" halType="bit"/>
<complexEntry bitLen="1" halPin="di-09" halType="bit"/>
<complexEntry bitLen="1" halPin="di-10" halType="bit"/>
<complexEntry bitLen="1" halPin="di-11" halType="bit"/>
<complexEntry bitLen="1" halPin="di-12" halType="bit"/>
<complexEntry bitLen="1" halPin="di-13" halType="bit"/>
<complexEntry bitLen="1" halPin="di-14" halType="bit"/>
<complexEntry bitLen="1" halPin="di-15" halType="bit"/>
<complexEntry bitLen="1" halPin="di-16" halType="bit"/>
</pdoEntry>
</pdo>
</syncManager>
</slave>
i appreciate your help guys i have been stuck with this problem since two weeks!
Displaying 9871 - 9885 out of 11222 results.
Time to create page: 0.480 seconds
