11 years 6 months ago - 11 years 6 months ago #57554 by todmorg
Replied by todmorg on topic Gmoccapy - A new screen for linuxcnc
I found what I was looking for, using a M61Q# instead of a M6T# does just what I want.
Todd
Last edit: 11 years 6 months ago by todmorg.
11 years 6 months ago - 11 years 6 months ago #57555 by todmorg
I am transitioning over from Axis to Gmoccapy and over all I am very happy with the way Gmoccapy works using a touchscreen with no mouse or keyboard.
One item that I miss from Axis is the ability to dynamically rotate the screen without using a mouse. Axis has an option box that looks like a little teepee, that lets you rotate using a touchscreen, this option box is missing in Gmoccapy. Is there a workaround or way to incorporate this option in Gmoccapy?
One other thing that throws me off is the colors of the turtle/rabbit selector, they seem like they are reversed. Green seems like it should mean go fast, and red or yellow for slow.
Todd
11 years 6 months ago #57563 by andypugh
Replied by andypugh on topic Gmoccapy - A new screen for linuxcnc
todmorg wrote: I found what I was looking for, using a M61Q# instead of a M6T# does just what I want.
G10 might also work.
11 years 6 months ago #57583 by newbynobi
Replied by newbynobi on topic Gmoccapy - A new screen for linuxcnc
I will check, what does axis if you click the "tepee" button and if it is posible to translate to gmoccapy.
Fast is more dangerius than slow, so are the colors selected. You can easy change that, just edit the icons from /usr/share/gmoccapy
Norbert
11 years 6 months ago #57585 by jbunch
Replied by jbunch on topic Gmoccapy - A new screen for linuxcnc
Norbert,
Is there any way to center the output when using a potmeter with a mid point detent so that the mid detent point is 100%?
Jim
11 years 6 months ago #57586 by jbunch
Norbert,
I am getting an error when going from forward to reverse on the spindle.
Found an error! The following information may be useful in troubleshooting: Traceback (most recent call last): File "/usr/bin/gmoccapy", line 2781, in on_rbt_reverse_clicked self._set_spindle( "reverse" ) File "/usr/bin/gmoccapy", line 2819, in _set_spindle rpm_out = rpm / self.stat.spindlerate ZeroDivisionError: float division Found an error! The following information may be useful in troubleshooting: Traceback (most recent call last): File "/usr/bin/gmoccapy", line 2789, in on_rbt_stop_clicked self._set_spindle( "stop" ) File "/usr/bin/gmoccapy", line 2819, in _set_spindle rpm_out = rpm / self.stat.spindlerate ZeroDivisionError: float division
GMOCCAPY Preferences
[DEFAULT] unlock_way = no rel_color = black max_messages = 10.0 show_preview_on_offset = False jump_to_dir = /home/tman show_keyboard_on_offset = True x_pos_popup = 45.0 homed_color = green height = 750 system_name_g92 = G92 system_name_g59.1 = G59.1 system_name_g59.2 = G59.2 system_name_g59.3 = G59.3 mouse_btn_mode = 4 audio_error = /usr/share/sounds/ubuntu/stereo/dialog-question.ogg log_actions = False view_tool_path = True offset_axis_x = 0.0 scale_max_vel = 1000.0 show_keyboard_on_edit = True open_file = abs_color = blue show_offsets = False dro_digits = 4 gremlin_view = rbt_view_p system_name_g59 = G59 width = 979 show_keyboard_on_mdi = True spindle_start_rpm = 8000.0 view_dimension = True turtle_jog_factor = 20 scale_spindle_override = 10.0 system_name_tool = Tool system_name_g54 = G54 system_name_rot = Rot system_name_g56 = G56 system_name_g58 = G58 unlock_code = 123 hide_axis_4 = False x_pos = 40 dtg_color = yellow message_font = sans 10 unhomed_color = red screen1 = fullscreen dro_size = 28 use_keyboard_shortcuts = True spindle_bar_max = 24000.0 use_auto_units = True spindle_bar_min = 8000.0 enable_dro = False audio_alert = /usr/share/sounds/ubuntu/stereo/bell.ogg hide_turtle_jog_button = False opstop = True show_keyboard_on_file_selection = False grid_size = 1.0 scale_feed_override = 10.0 use_frames = True system_name_g55 = G55 y_pos_popup = 55.0 show_dtg = False run_from_line = no_run gtk_theme = Follow System Theme system_name_g5x = G5x logo = False system_name_g57 = G57 hide_cursor = False y_pos = 30 width_popup = 250.0 show_keyboard_on_tooledit = False show_dro_btn = False blockdel = False scale_jog_vel = 10.0 view = p
INI File
# Generated by PNCconf at Sun Mar 29 11:35:54 2015 # If you make changes to this file, they will be # overwritten when you run PNCconf again [EMC] MACHINE = test-x-02 DEBUG = 0 [DISPLAY] DISPLAY = gmoccapy POSITION_OFFSET = RELATIVE POSITION_FEEDBACK = ACTUAL MAX_FEED_OVERRIDE = 5.000000 MAX_SPINDLE_OVERRIDE = 5.000000 MIN_SPINDLE_OVERRIDE = 0.500000 INTRO_GRAPHIC = linuxcnc.gif INTRO_TIME = 5 PROGRAM_PREFIX = /home/tman/linuxcnc/nc_files INCREMENTS = .1in .01in .001in POSITION_OFFSET = RELATIVE POSITION_FEEDBACK = ACTUAL DEFAULT_LINEAR_VELOCITY = 0.250000 MAX_LINEAR_VELOCITY = 1.000000 MIN_LINEAR_VELOCITY = 0.010000 DEFAULT_ANGULAR_VELOCITY = 0.250000 MAX_ANGULAR_VELOCITY = 1.000000 MIN_ANGULAR_VELOCITY = 0.010000 EDITOR = gedit GEOMETRY = xyz PREFERENCE_FILE_PATH = gmoccapy_preferences [FILTER] PROGRAM_EXTENSION = .png,.gif,.jpg Greyscale Depth Image PROGRAM_EXTENSION = .py Python Script png = image-to-gcode gif = image-to-gcode jpg = image-to-gcode py = python [TASK] TASK = milltask CYCLE_TIME = 0.010 [RS274NGC] PARAMETER_FILE = linuxcnc.var [EMCMOT] EMCMOT = motmod COMM_TIMEOUT = 1.0 COMM_WAIT = 0.010 SERVO_PERIOD = 1000000 [HOSTMOT2] # **** This is for info only **** # DRIVER0=hm2_pci # BOARD0=5i25 [HAL] HALUI = halui HALFILE = tman-router.hal HALFILE = custom.hal POSTGUI_HALFILE = postgui_call_list.hal SHUTDOWN = shutdown.hal [HALUI] [TRAJ] AXES = 3 COORDINATES = X Y Z LINEAR_UNITS = inch ANGULAR_UNITS = degree CYCLE_TIME = 0.010 DEFAULT_VELOCITY = 1.2 MAX_VELOCITY = 10 [EMCIO] EMCIO = io CYCLE_TIME = 0.100 TOOL_TABLE = tool.tbl #******************** # Axis X #******************** [AXIS_0] TYPE = LINEAR HOME = 0.0 FERROR = 0.005 MIN_FERROR = 0.0005 MAX_VELOCITY = 8 MAX_ACCELERATION = 1.9 # The values below should be 25% larger than MAX_VELOCITY and MAX_ACCELERATION # If using BACKLASH compensation STEPGEN_MAXACCEL should be 100% larger. STEPGEN_MAXVEL = 15 STEPGEN_MAXACCEL = 2.5 # these are in nanoseconds DIRSETUP = 1000 DIRHOLD = 20000 STEPLEN = 500 STEPSPACE = 4000 STEP_SCALE = 10000.0 MIN_LIMIT = -0.001 MAX_LIMIT = 50.0 HOME_OFFSET = 0.0 #******************** # Axis Y #******************** [AXIS_1] TYPE = LINEAR HOME = 0.0 FERROR = 0.005 MIN_FERROR = 0.0005 MAX_VELOCITY = 8 MAX_ACCELERATION = 2.0 # The values below should be 25% larger than MAX_VELOCITY and MAX_ACCELERATION # If using BACKLASH compensation STEPGEN_MAXACCEL should be 100% larger. STEPGEN_MAXVEL = 10 STEPGEN_MAXACCEL = 2.5 # these are in nanoseconds DIRSETUP = 1000 DIRHOLD = 20000 STEPLEN = 500 STEPSPACE = 4000 STEP_SCALE = 10000.0 MIN_LIMIT = -0.001 MAX_LIMIT = 8.0 HOME_OFFSET = 0.0 #******************** # Axis Z #******************** [AXIS_2] TYPE = LINEAR HOME = 0.0 FERROR = 0.005 MIN_FERROR = 0.0005 MAX_VELOCITY = 1.667 MAX_ACCELERATION = 2.0 # The values below should be 25% larger than MAX_VELOCITY and MAX_ACCELERATION # If using BACKLASH compensation STEPGEN_MAXACCEL should be 100% larger. STEPGEN_MAXVEL = 2.1 STEPGEN_MAXACCEL = 2.5 # these are in nanoseconds DIRSETUP = 1000 DIRHOLD = 20000 STEPLEN = 500 STEPSPACE = 4000 STEP_SCALE = 10000.0 MIN_LIMIT = -0.001 MAX_LIMIT = 8.0 HOME_OFFSET = 0.0 #******************** # Spindle #******************** [SPINDLE_9]
Hal FIle
# Generated by PNCconf at Sun Mar 29 11:35:53 2015 # If you make changes to this file, they will be # overwritten when you run PNCconf again loadrt abs names=abs_spindle_feedback loadrt encoder num_chan=1 loadrt trivkins loadrt [EMCMOT]EMCMOT servo_period_nsec=[EMCMOT]SERVO_PERIOD num_joints=[TRAJ]AXES loadrt probe_parport loadrt hostmot2 loadrt hm2_pci config=" num_encoders=0 num_pwmgens=0 num_3pwmgens=0 num_stepgens=5 sserial_port_0=2000xxx " setp hm2_5i25.0.watchdog.timeout_ns 10000000 addf encoder.capture-position servo-thread #addf encoder.update-counters base-thread addf hm2_5i25.0.read servo-thread addf motion-command-handler servo-thread addf motion-controller servo-thread addf hm2_5i25.0.write servo-thread addf hm2_5i25.0.pet_watchdog servo-thread #******************* # AXIS X #******************* # Step Gen signals/setup setp hm2_5i25.0.stepgen.00.dirsetup [AXIS_0]DIRSETUP setp hm2_5i25.0.stepgen.00.dirhold [AXIS_0]DIRHOLD setp hm2_5i25.0.stepgen.00.steplen [AXIS_0]STEPLEN setp hm2_5i25.0.stepgen.00.stepspace [AXIS_0]STEPSPACE setp hm2_5i25.0.stepgen.00.position-scale [AXIS_0]STEP_SCALE setp hm2_5i25.0.stepgen.00.step_type 0 setp hm2_5i25.0.stepgen.00.control-type 0 setp hm2_5i25.0.stepgen.00.maxaccel [AXIS_0]STEPGEN_MAXACCEL setp hm2_5i25.0.stepgen.00.maxvel [AXIS_0]STEPGEN_MAXVEL net x-pos-fb axis.0.motor-pos-fb <= hm2_5i25.0.stepgen.00.position-fb net x-pos-cmd axis.0.motor-pos-cmd => hm2_5i25.0.stepgen.00.position-cmd net x-enable axis.0.amp-enable-out => hm2_5i25.0.stepgen.00.enable # Step Gen signals/setup for tandem axis stepper setp hm2_5i25.0.stepgen.01.dirsetup [AXIS_0]DIRSETUP setp hm2_5i25.0.stepgen.01.dirhold [AXIS_0]DIRHOLD setp hm2_5i25.0.stepgen.01.steplen [AXIS_0]STEPLEN setp hm2_5i25.0.stepgen.01.stepspace [AXIS_0]STEPSPACE setp hm2_5i25.0.stepgen.01.position-scale [AXIS_0]STEP_SCALE setp hm2_5i25.0.stepgen.01.step_type 0 setp hm2_5i25.0.stepgen.01.control-type 0 setp hm2_5i25.0.stepgen.01.maxaccel [AXIS_0]STEPGEN_MAXACCEL setp hm2_5i25.0.stepgen.01.maxvel [AXIS_0]STEPGEN_MAXVEL net x2-pos-fb <= hm2_5i25.0.stepgen.01.position-fb net x-pos-cmd => hm2_5i25.0.stepgen.01.position-cmd net x-enable => hm2_5i25.0.stepgen.01.enable # ---setup home / limit switch signals--- net x-home-sw => axis.0.home-sw-in net x-neg-limit => axis.0.neg-lim-sw-in net x-pos-limit => axis.0.pos-lim-sw-in #******************* # AXIS Y #******************* # Step Gen signals/setup setp hm2_5i25.0.stepgen.02.dirsetup [AXIS_1]DIRSETUP setp hm2_5i25.0.stepgen.02.dirhold [AXIS_1]DIRHOLD setp hm2_5i25.0.stepgen.02.steplen [AXIS_1]STEPLEN setp hm2_5i25.0.stepgen.02.stepspace [AXIS_1]STEPSPACE setp hm2_5i25.0.stepgen.02.position-scale [AXIS_1]STEP_SCALE setp hm2_5i25.0.stepgen.02.step_type 0 setp hm2_5i25.0.stepgen.02.control-type 0 setp hm2_5i25.0.stepgen.02.maxaccel [AXIS_1]STEPGEN_MAXACCEL setp hm2_5i25.0.stepgen.02.maxvel [AXIS_1]STEPGEN_MAXVEL net y-pos-fb axis.1.motor-pos-fb <= hm2_5i25.0.stepgen.02.position-fb net y-pos-cmd axis.1.motor-pos-cmd => hm2_5i25.0.stepgen.02.position-cmd net y-enable axis.1.amp-enable-out => hm2_5i25.0.stepgen.02.enable # ---setup home / limit switch signals--- net y-home-sw => axis.1.home-sw-in net y-neg-limit => axis.1.neg-lim-sw-in net y-pos-limit => axis.1.pos-lim-sw-in #******************* # AXIS Z #******************* # Step Gen signals/setup setp hm2_5i25.0.stepgen.03.dirsetup [AXIS_2]DIRSETUP setp hm2_5i25.0.stepgen.03.dirhold [AXIS_2]DIRHOLD setp hm2_5i25.0.stepgen.03.steplen [AXIS_2]STEPLEN setp hm2_5i25.0.stepgen.03.stepspace [AXIS_2]STEPSPACE setp hm2_5i25.0.stepgen.03.position-scale [AXIS_2]STEP_SCALE setp hm2_5i25.0.stepgen.03.step_type 0 setp hm2_5i25.0.stepgen.03.control-type 0 setp hm2_5i25.0.stepgen.03.maxaccel [AXIS_2]STEPGEN_MAXACCEL setp hm2_5i25.0.stepgen.03.maxvel [AXIS_2]STEPGEN_MAXVEL net z-pos-fb axis.2.motor-pos-fb <= hm2_5i25.0.stepgen.03.position-fb net z-pos-cmd axis.2.motor-pos-cmd => hm2_5i25.0.stepgen.03.position-cmd net z-enable axis.2.amp-enable-out => hm2_5i25.0.stepgen.03.enable # ---setup home / limit switch signals--- net z-home-sw => axis.2.home-sw-in net z-neg-limit => axis.2.neg-lim-sw-in net z-pos-limit => axis.2.pos-lim-sw-in #******************* # SPINDLE S #******************* # ---digital potentionmeter output signals/setup--- #setp hm2_5i25.0.7i76.0.0.spinout-minlim [SPINDLE_9]OUTPUT_MIN_LIMIT #setp hm2_5i25.0.7i76.0.0.spinout-maxlim [SPINDLE_9]OUTPUT_MAX_LIMIT #setp hm2_5i25.0.7i76.0.0.spinout-scalemax [SPINDLE_9]OUTPUT_SCALE net spindle-vel-cmd => hm2_5i25.0.7i76.0.0.spinout net machine-is-enabled => hm2_5i25.0.7i76.0.0.spinena net spindle-ccw => hm2_5i25.0.7i76.0.0.spindir # ---setup spindle control signals--- net spindle-vel-cmd-rps <= motion.spindle-speed-out-rps net spindle-vel-cmd-rps-abs <= motion.spindle-speed-out-rps-abs net spindle-vel-cmd <= motion.spindle-speed-out net spindle-vel-cmd-rpm-abs <= motion.spindle-speed-out-abs net spindle-on <= motion.spindle-on net spindle-cw <= motion.spindle-forward net spindle-ccw <= motion.spindle-reverse net spindle-brake <= motion.spindle-brake net spindle-revs => motion.spindle-revs net spindle-at-speed => motion.spindle-at-speed net spindle-vel-fb => motion.spindle-speed-in net spindle-index-enable <=> motion.spindle-index-enable # ---Setup spindle at speed signals--- sets spindle-at-speed true
Jim
Moderators: newbynobi, HansU
Time to create page: 0.826 seconds
