- Thank you received: 3
- jbunch
11 years 6 months ago #57870
by jbunch
Replied by jbunch on topic Gmoccapy - A new screen for linuxcnc
Norbert,
I am having a problem with the spindle override using an outboard encoder.
In MDI if I set speed the encoder will move the speed up and down.
In auto mode it will move it up but not down below the base line. Also if it calls for 12000 RPM the base line is
now 235% not 100% and the speed will not go below that point. The min spindle speed is set to 8000 RPM.
I have another encoder on the Feed and that works correctly.
Jim
Jim
- nooob
11 years 6 months ago #57880
by nooob
Replied by nooob on topic Gmoccapy - A new screen for linuxcnc
is it possible to add an Programm run timer that shows the time the machine has needed to do an job?
- newbynobi
- Thank you received: 394
11 years 6 months ago #57903
by newbynobi
Replied by newbynobi on topic Gmoccapy - A new screen for linuxcnc
@Jim
to manually update, take from git:
Linuxcnc-dev/src/emc/usr_intf/gmoccapy/gmoccapy.py
copy that one to /usr/bin/ and replace gmoccapy
Please note, the file is loosing its extention .py and you need to make it exucatable!
take linuxcnc-dev/src/emc/usr_intf/gmoccapy/gmoccapy.glade
and copy that one to /usr/share/gmoccapy/
All change can be found in Linuxcnc-dev/src/emc/usr_intf/gmoccapy/release_notes.txt
Norbert
Norbert
- newbynobi
11 years 6 months ago #57904
by newbynobi
@dracozny,
I am working on the MDI isue, unfortunately it is not so easy, as gmoccapy is collecting all focus and I need to check all side affects. But I feel the same as you, as I do use also a lot of MDI stuff.
Norbert
Norbert
- newbynobi
11 years 6 months ago #57905
by newbynobi
@Jim,
I am not able to reproce that. Here spindle override is working fine using an external encoder.
Could you please send me your config folder?
Does that happen on every program, or also if you just are in Auto Mode??
Norbert
Norbert
- newbynobi
11 years 6 months ago #57906
by newbynobi
@nooob,
yes it is, but at the moment I am not planing to introduce such a program, as you can do that quiet easy using a custom panel and hal connections.
Norbert
Norbert
Moderators: newbynobi, HansU
Time to create page: 1.275 seconds
