11 years 6 months ago #57656 by LAIR82
Replied by LAIR82 on topic Gmoccapy - A new screen for linuxcnc
gmills46 wrote: Can I remap my T command to an ngc file for each of the 8 tool stations? I would prefer to issue tool change commands in the standard T0101 method used in industrial CNC controls, but T1M6 would be alright for now.
Any help would be greatly appreciated
Gary Mills
Mills Enterprises CNC
Hello Gary,
As for the mpg selections , I'm not sure on those, we do all selecting on the mpg, not the screen or keyboard, as for the tool change command, this is exactly what you are looking for.
linuxcnc.org/index.php/english/forum/20-...fset-patch?start=100
Take a look at the last post on this thread, I started this a long time ago, and we finally got it working late last year, and it works flawlessly
Rick
11 years 6 months ago #57659 by andypugh
Replied by andypugh on topic Gmoccapy - A new screen for linuxcnc
Yes. Have a look at the sim/axis/lathe-fanucy sample configuration. That does (almost) exactly that, and the "almost" can be fixed with tweaks to the G-code subroutine.
11 years 6 months ago #57666 by newbynobi
Replied by newbynobi on topic Gmoccapy - A new screen for linuxcnc
@Garry,
Remap is a linuxcnc isue and will not affect the gui. It will work.
Hal pins for jogging no problem, just see the WIKI or the included documentation for the pin offered.
If you need other button, you can add a custom panel with the buttons you need.
Norbert
11 years 6 months ago #57686 by jbunch
Replied by jbunch on topic Gmoccapy - A new screen for linuxcnc
Norbert,
I am feeling dumb today. How do I update to the latest 1.5.3.x of GMOCCAPY using GIT on version 2.6.7.
Does it need to be compiled compiled into 2.6.7 or can I just move the files over from Linuxcnc-dev.
If they can be moved what files and to where.
Thank you Norbert
Jim
11 years 6 months ago #57691 by dracozny
Replied by dracozny on topic Gmoccapy - A new screen for linuxcnc
MDI issues. I use the MDI allot, at least atm, I also use a physical keyboard for this purpose and one frustration I have is when I am reusing a command from the history my enter key will not execute the command. So instead I have to press the very small return button on the screen which is so small I worry about pressing something else.
Thanks all.
11 years 6 months ago #57696 by LAIR82
Gary, take a look at my last post on my "Tool Offset Patch" thread mentioned above.
It should clear, things up,
Also let's move the conversation over to that thread any way, so we don't get this thread off topic.
Rick
Moderators: newbynobi, HansU
Time to create page: 1.668 seconds
