- Thank you received: 3
- LAIR82
newbynobi wrote: That is not part of the GUI Programming, so it is out of my reaches at the moment.
But for two cases of beer.... I should think about that:lol: :woohoo:
Norbert
I wasn't being sarcastic either
My boss said he would make make it a pickup truck bed full!!!
RIck
LAIR82 wrote: I wasn't being sarcastic either
See my earlier post. You might owe that to Dewey.
- mariusl
I found these small problems in 4 axis mill mode running on production and v1.5.2
1: I cannot use the macro function at all as the files are not found no matter where I place them.
2: The selected mode button does not hold the selected colour if the button has focus. As soon as you put focus on another item ( like in the vcp buttons panel) , then the selected colour shows up on the last selected mode button.
3: If I am running in full screen mode and use ngcgui with the popup keyboard, the keyboard does not stay on top. I.E. if you touch the screen elsewhere by accident the keyboard will move to the background with no way to return it to the top. Well unless you change the screen mode and then it jumps back up. It wuld seem to be a problem only in full screen mode but I have not tested the others.
Regards
Marius
www.bluearccnc.com
- newbynobi
- Thank you received: 394
The files must be in the directory you specify in your INI [RS274NGC] Section. For details see the WIKI.1: I cannot use the macro function at all as the files are not found no matter where I place them.
I do know that! The reason is, that I do change the color for gtk.STATE_ACTIVE so if the button is active it is yellow. If the mouse hover over the button, the state is gtk.STATE_PRELIGHT witch on normal theme is grey. If you use a touch screen, the "mouse" will hoover over the widget, until you do touch the screen on a different place. If I do change also the color of gtk.STATE_PRELIGHT the button will change color, even if it is not active, causing confusion for mouse users, i.e. Manual is active, but the mouse hoover over MDI, showing both button active2: The selected mode button does not hold the selected colour if the button has focus. As soon as you put focus on another item ( like in the vcp buttons panel) , then the selected colour shows up on the last selected mode button.
So feel free to submit solutions?
To all touch screen users: Do you hide the mouse cursor? If so, I could add the color stuff to the settings handling for cursor hiding.
No solution for that, except my suggestion to get the keyboard back using <ALT><TAB> on a normal keyboard. I am not using ngcgui at all.3: If I am running in full screen mode and use ngcgui with the popup keyboard, the keyboard does not stay on top. I.E. if you touch the screen elsewhere by accident the keyboard will move to the background with no way to return it to the top. Well unless you change the screen mode and then it jumps back up. It wuld seem to be a problem only in full screen mode but I have not tested the others.
Norbert
- jbunch
I vote for the touch screen fix. Also check what you did for the spindle for,rev,stop as these seem to work ok.
jim
- newbynobi
do you hide the cursor?
On spindle stuff I have not made changes, did you update meanwhile?
Norbert
