13 Sep 2013 07:15 #38725 by jj89074
Replied by jj89074 on topic Gmoccapy - A new screen for linuxcnc
I did a quick search for gmoccapy.glade also, but nada.
13 Sep 2013 07:21 #38726 by jj89074
Yes, it is an installed version.
If I run the commands from the gmoccapy wiki in the terminal, I do get the latest version of gmoccapy to run (under rip-environment from the linuxcnc-dev folder).
I'm not able to find what files need to be transferred to run my configuration from the linuxcnc folder and not the linuxcnc-dev folder. I hope that makes sense.
13 Sep 2013 07:59 #38728 by cmorley
Replied by cmorley on topic Gmoccapy - A new screen for linuxcnc
The files I spoke of are missing in an installed version.
In a RIP version they are found in [RIP_FOLDER_NAME}/share/gscreen/skins/gmoccapy/
If you copied that file to /usr/share/gscreen/gmoccapy
Then it should work fine.
But better would be to wait for use to sort this out properly.
Chris M
13 Sep 2013 09:33 #38738 by jj89074
Chris,
I copied the skins folder like you suggested and the "sim" configuration of gmoccapy works as it should with no errors given...thank you!
Jim
13 Sep 2013 12:49 #38745 by cmorley
Great !
Thanks for trying that - now we can hopefully fix it quickly
Chris M
13 Sep 2013 16:48 #38757 by probamo
Replied by probamo on topic Gmoccapy - A new screen for linuxcnc
I would try to translate application in Serbian. Where can I find an English version, hence I can use the wording for translation?
Thanks,
13 Sep 2013 17:07 #38758 by andypugh
Replied by andypugh on topic Gmoccapy - A new screen for linuxcnc
I would try to translate application in Serbian. Where can I find an English version, hence I can use the wording for translation?,
The correct way to do it is according to:
wiki.linuxcnc.org/cgi-bin/wiki.pl?Internationalization
Gscreen seems to be using the _("english text here") format so it should all work according to that description just by creating a Serbian .po file.
13 Sep 2013 21:51 #38766 by newbynobi
Replied by newbynobi on topic Gmoccapy - A new screen for linuxcnc
Thanks,
That is really simple for gmoccapy, because all you need is on board!
Please go to
linuxcnc-dev/share/gscreen/skins/gmoccay/locale
Make a dir called cs (for Serbia) or es for Spain)
Copy gmoccapy.pot and gmoccapy.po to that dir,
change to that dir and
open that file with gtranslator (may you have to install it)
Normaly a doble click will open the file.
Now just translate all the strings and save the result as gmoccapy.po
Yes please override the po file!
No open the po file with poedit and just press Save.
After closing poedit there should be a new file called gmoccapy.mo
Make a folder named LC_MESSAGES and move the file gmoccapy.mo to that dir.
All done!
Do not delete the Po and pot files, because I I change code and you adapt the translation, we will need that files, so you do not need to translate everything again, but only the changes.
Would you please mail the translated files, so I will include them and they will be availible to everyone.
Norbert
There are also other ways, but that is the easiest IMHO.
13 Sep 2013 21:54 #38767 by newbynobi
gmoccapy 0.9.7.2 has been released
Marius,
that has been made only for you!
gmoccapy now works without homing if the INI file does include
NO_FORCE_HOMING=1
That is the only change, not exactly, I corrected also the release number ;-)
Norbert
The following user(s) said Thank You: mariusl
13 Sep 2013 22:57 #38773 by mariusl
Replied by mariusl on topic Gmoccapy - A new screen for linuxcnc
Thanks man, you are a champion.
Regards
Marius
www.bluearccnc.com
Moderators: newbynobi, HansU
Time to create page: 1.764 seconds
